#337 |
Drives: 2013 Subaru BRZ AT JRSC
#338 |
Drives: FT86
yes definitely need to eliminate intake/exhaust leaks or crook damaged 02 sensors dirty maf sensors ect, also check the gasket on maf sensor ect.
#339 |
Drives: Asphalt Scion FR-S
#340 |
Drives: 14 Ultramarine FR-S
Here's the timing I had to pull on 91 Shell. If I was running a bit richer I wouldn't have to pull timing, but I'm not sure how to adjust that.
Anyways IAM hasn't gone below .98 yet which is good. ![]() Couple logs... knock still exists, but very minor. http://datazap.me/u/phantobe/91shell...5?log=0&data=1 http://datazap.me/u/phantobe/91shell31915krev5 @JB86'd Probably gonna run a couple more tanks of 91 make sure I'm not getting significant knock, then switch to E85.
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD ![]() |
| The Following User Says Thank You to Phantobe For This Useful Post: | 2much (03-31-2015) |
#341 |
Drives: FT86
#342 |
Doesn't this table only effect AFR when in open loop (full throttle), what about partial throttle?
#343 | |
Drives: FT86
in cl ecu tries to target values plus offsets using reading from 02 sensor in feed back loop and stores fuel trims it needs to do so. in ol ecu tries to target the values using maf sensor to calculate fueling and the fuel trims learned in closed loop. 02 sensor reading not used. |
#344 |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
This is my first datalog and i'm mainly doing this because since switching over to E85 and running a stage 2 OFT EL map, i've been hearing this raspy sound whenever i'm revving in the 3.5-4k range or so. Maybe it's normal?
This is on stock headers, first tank of E85 Anyways, here is the datalog I uploaded: http://www.datazap.me/u/aztec/first-...p?log=0&data=1 And here is a sound of it. (phone quality )https://dl.dropboxusercontent.com/u/...%20-%20FRS.m4a |
#345 | |
Drives: '13 SSM BRZ Limited 6MT
#346 | |
I should be getting my UEL header in a week, so i'm in the same boat ![]() Thanks |
#347 |
would someone mind having a look at my log?
this is my 4th go at maf scaling, i think the scaling could be better still.. thoughts / advice welcome as always. http://www.datazap.me/u/danklvr/203-...-6-7-8-9-10-13 NA - 91 oct - stg 2
How ya gonna keep 'em down on the farm once they've seen Karl Hungus? |
#348 | |
#349 | |
Drives: FT86
also are they the parameters your using for maf scaling ?? as your logging "injection mode" which is port/direct injection, you need to log fuel system status for open/closed loop. |
#350 |
normally i get a good log - normal cruise driving, then manually filter out my data from the log. once i have my filtered closed loop data, i fill "injection mode" collumn with "2".
I'll switch my paramater to include "fuel system status", and remove "injection mode", and report back with a better log based on the feedback you gave once nailed down CL, I'll start on OL, then move on to timing... Again, thanks Steve99, and KOA!
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
