Old 03-19-2015, 06:59 PM   #337
alpax
alpax's Avatar
Drives: 2013 Subaru BRZ AT JRSC
Simplified explanation Open loop/Closed loop fueling
Thanks, I believe I read that in one of your links.
BTW, I was thinking about MAF scaling, but I probably shouldn't do that if there is a chance that there is just something wrong in the system.
alpax is offline   Reply With Quote
Old 03-19-2015, 07:23 PM   #338
steve99
Drives: FT86
yes definitely need to eliminate intake/exhaust leaks or crook damaged 02 sensors dirty maf sensors ect, also check the gasket on maf sensor ect.
Old 03-19-2015, 08:01 PM   #339
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
So, went to the local drag strip last night for the first time with this car. Best time I clicked off was a 14.8 @ 94. Here's logs from my 3 runs. Anyone see any spots that can be improved AFR/Tune wise?? I feel like it could be fine tuned out.
Run 1
Run 2
Run 3
itsjustdavep is offline   Reply With Quote
Old 03-21-2015, 02:34 AM   #340
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Here's the timing I had to pull on 91 Shell. If I was running a bit richer I wouldn't have to pull timing, but I'm not sure how to adjust that.
Anyways IAM hasn't gone below .98 yet which is good.
Couple logs... knock still exists, but very minor.
http://datazap.me/u/phantobe/91shell...5?log=0&data=1
http://datazap.me/u/phantobe/91shell31915krev5
@JB86'd
Probably gonna run a couple more tanks of 91 make sure I'm not getting significant knock, then switch to E85.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
The Following User Says Thank You to Phantobe For This Useful Post:
2much (03-31-2015)
Old 03-21-2015, 04:29 AM   #341
steve99
Drives: FT86
You can adjust primary open loop fuel table here, yours may be different
Old 03-21-2015, 07:46 PM   #342
Phantobe
Phantobe's Avatar
Doesn't this table only effect AFR when in open loop (full throttle), what about partial throttle?
Old 03-21-2015, 08:51 PM   #343
steve99
Drives: FT86
in closed loop its used as base values, offsets can be applied, look under the closed loop fueling area in romraider, but it my understanding that abover table is used as base values for both ol\ cl.
in cl ecu tries to target values plus offsets using reading from 02 sensor in feed back loop and stores fuel trims it needs to do so.
in ol ecu tries to target the values using maf sensor to calculate fueling and the fuel trims learned in closed loop. 02 sensor reading not used.
Old 03-23-2015, 10:26 PM   #344
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
This is my first datalog and i'm mainly doing this because since switching over to E85 and running a stage 2 OFT EL map, i've been hearing this raspy sound whenever i'm revving in the 3.5-4k range or so. Maybe it's normal?
This is on stock headers, first tank of E85
Anyways, here is the datalog I uploaded:
http://www.datazap.me/u/aztec/first-...p?log=0&data=1
And here is a sound of it. (phone quality )
https://dl.dropboxusercontent.com/u/...%20-%20FRS.m4a
Aztec is offline   Reply With Quote
Old 03-23-2015, 10:49 PM   #345
tracerit
Drives: '13 SSM BRZ Limited 6MT
Look up vvt rasp 4k. There's a huge thread (Althiugh old now) with more info. It's normal. It's a discouraging noise imo and was told e85 would minimize it but it didn't. Then it turns out an uel header will definitely get rid of it so here I am waiting for the ofh to be delivered haha.
tracerit is offline   Reply With Quote
Old 03-23-2015, 10:55 PM   #346
Aztec
Aztec's Avatar
That's really comforting to be honest! I thought it was running extra lean or something haha.
I should be getting my UEL header in a week, so i'm in the same boat
Thanks
Old 03-24-2015, 01:30 PM   #347
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
would someone mind having a look at my log?
this is my 4th go at maf scaling, i think the scaling could be better still..
thoughts / advice welcome as always.
http://www.datazap.me/u/danklvr/203-...-6-7-8-9-10-13
NA - 91 oct - stg 2
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 03-24-2015, 02:06 PM   #348
Koa
NA - 91 oct - stg 2
Since you have no knock and trims look very good (can always manually edit the 2.0-2.2mafv/1-1.2load zone where you're dipping a bit in the LTFTs), I'd suggest you move over to maximizing timing and onset where you can, pick up as much power as possible while still giving ya enough buffer against knock
Old 03-24-2015, 02:11 PM   #349
steve99
Drives: FT86
NA - 91 oct - stg 2
You have not done a run over the rpm range log is just 2000-3000 rpm.
also are they the parameters your using for maf scaling ?? as your logging "injection mode" which is port/direct injection, you need to log fuel system status for open/closed loop.
Old 03-24-2015, 02:30 PM   #350
Danklvr
Danklvr's Avatar
normally i get a good log - normal cruise driving, then manually filter out my data from the log. once i have my filtered closed loop data, i fill "injection mode" collumn with "2".
I'll switch my paramater to include "fuel system status", and remove "injection mode", and report back with a better log based on the feedback you gave
once nailed down CL, I'll start on OL, then move on to timing...
Again, thanks Steve99, and KOA!
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 02:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 10:27 AM
