Old 05-18-2012, 09:01 PM   #1
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
MT Gear Indicator Issue
I was reading through the owners manual (no really, I was ) and I saw the steps to turn on the gear indicator for those with a manual transmission.
According to the book, while the key is turned to ACC, you press ODO until you see g-off.
I dont have that menu. I get ODO, Trip A, and Trip B. No gear indicator settings.
Has anyone been able to successfully set that up?
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 05-18-2012, 09:05 PM   #2
I don't have a MT, but I did read this earlier. Did you have the key in the ACC or LOCK position? Page 152 says it only shows in those positions.
Old 05-18-2012, 09:23 PM   #3
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Yep, had it in ACC.
Parting out HERE
Old 05-18-2012, 09:24 PM   #4
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Make sure it is in ACC (first click) and not ON (second click)
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
The Following 2 Users Say Thank You to Spaceywilly For This Useful Post:
civicdrivr (05-18-2012), ottoyu34 (03-12-2016)
Old 05-18-2012, 09:29 PM   #5
Yep, had it in ACC.
Hmm, don't know then. You can't turn it off on the AT, or I'd give it a try to see what happens. Might just try "off" if you haven't. The OD button does work in the OFF position.
Old 05-18-2012, 09:40 PM   #6
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Ill give that a try in a bit.
I guess while we're on the subject of the instrument cluster, is there any way to get the tach to do a fast sweep, like in this video:
[ame="http://www.youtube.com/watch?v=ki2JA-_Opn4&feature=channel&list=UL"]Subaru BRZ nav startup screen by PERRIN Performance - YouTube[/ame]
Mine goes up to where I set the rev warning, pauses, then goes back down.
Parting out HERE
Old 05-18-2012, 09:42 PM   #7
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
I'm sure there's a way, but I doubt it's just a setting.
IIRC it was a selling/debating point for a lot of the BRZ guys...
- The Ancient BRZ Sacrament
by Zaku
Old 05-18-2012, 09:56 PM   #8
Stryker Trailwood
Scion Guy
Stryker Trailwood's Avatar
Drives: Scions and a Harley
usually with these things, you don't keep pressing the ODO button repeatedly, they mean for you to press and hold the button down until you see the new setting pop up. but i don't have the car or manual to really know lol
gah sudden posts, now i see the manual above.
FAMILY FLEET
2010 Black Currant Scion xD2006 Nautical Blue Scion tC
2010 RS 7.O Murasaki Scion xB22015 Blue Crush Metallic RAV4
Daily Rider
2014 White Hot Denim Harley-Davidson V-Rod Muscle
Stryker Trailwood is offline   Reply With Quote
Old 05-18-2012, 10:02 PM   #9
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
I thought gauge s weep was only on the BRZ, not FRS ???
BRZGrincherhood
Zgrinch is offline   Reply With Quote
Old 05-18-2012, 10:09 PM   #10
Just went out to mine. What they mean is for you to push the button until the g-off display shows. You then hold the button in until it changes. Same with the REV light.
But it should come up just by pushing the button through 4 or less cycles, then is when you hold it down.
Old 05-19-2012, 07:44 AM   #11
AtlantaRock
"First86" Delivered
AtlantaRock's Avatar
Try this if you didn't get it to work yet. Put the key in the ignition and turn it to the first on position, then push the ODO/TRIP until it displays G-OFF, then press and hold the button and it will change to G-ON.
That should do it
FR-S Whiteout Manual
In my Garage
AtlantaRock is offline   Reply With Quote
The Following User Says Thank You to AtlantaRock For This Useful Post:
civicdrivr (05-19-2012)
Old 05-19-2012, 09:05 AM   #12
Cheddar
Saving them pennies...
Its says how to do it in step 4 of this procedure.
Cheddar is offline   Reply With Quote
The Following User Says Thank You to Cheddar For This Useful Post:
Old 05-19-2012, 03:27 PM   #13
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Still haven't had a chance to try out what was noted above. Once I do, Ill let you know if it works or not.
I also didnt see the 5 step process in the FR-S owners manual, we may not have the BRZs sweep function
Parting out HERE
Old 05-20-2012, 11:13 AM   #14
uneekvisions
purist
uneekvisions's Avatar
Drives: 08' 135i ///M
I really want a FR-S, but the little things are making me reconsider the BRZ :|
uneekvisions is offline   Reply With Quote
Gear indicator Slick CANADA 18 05-20-2012 10:14 AM
First 86 issue and advice Mr.Eightsix Scion FR-S / Toyota 86 GT86 General Forum 34 05-19-2012 11:49 AM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
Headrest issue? Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 11 12-01-2011 03:48 PM
Motor Trend, August issue. 1660 Scion FR-S / Toyota 86 GT86 General Forum 216 08-02-2011 06:43 PM
