Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 03-19-2015, 08:01 AM   #57
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Originally Posted by Fish Eagle View Post
Most of the work is jacking the car up, taking the wheel off, and putting the wheel back on.
Changing the actual pads is a cinch.
But you do need some strength to push the pistons back when fitting new pads (or a big tool)
Exactly, always annoying when getting to the part you're working on is a bigger job than the "actual" job.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 03-19-2015, 10:41 AM   #58
FT_86_SM_GP
FT_86_SM_GP's Avatar
Drives: Lawn moweR
After having said that my brake fluid's still OK in my previous post in December (above), and after another 3 track days since then, I've decided that it's time for a change because it's started feeling quite spongy.
Previously I've used Endless RF650, but I found some Motul RBF660 in Nelspruit at less than half the price of Endless and the specs look very similar, so I'm going to give it a try.
Claimed boiling point 325°C dry, 205°C wet vs Endless RF650 which claims 323°C dry, and 218°C wet.
Anyone got experience with this product?
Great feedback and useful information @Fish Eagle
What was your take on the Endless brake Fluid Vs Motul?
Did your stock pads get cooked quicker with the Motul? Did you feel any significant differences on track days?
Thanks
FT_86_SM_GP is offline   Reply With Quote
Old 03-19-2015, 10:56 AM   #59
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
Thanks
The Motul fluid seems OK, and being 40% of the price, that actually means great
I say "seems" because my first track day with Motul was 100%. Sunday was my second day and I had a bit of spongy pedal feel near the end of the day, but not enough to get me worried. Probably caused by my front pads being poked. I'm going to give my brakes a light bleeding, and then see how it feels with new pads. I'll have to wait until the next time I'm on track cause there's no way you can create those levels of brake stress and heat on public roads. I'll let you know, but I think it'll be fine.
BTW, I don't have stock pads, and I don't think fluid has anything to do with pad life.
Fish Eagle is offline   Reply With Quote
Old 03-19-2015, 12:45 PM   #60
FT_86_SM_GP
Drives: Lawn moweR
Cool! Sorry didn't read the previous comments properly, you are running Endless Pads.
Are they expensive to replace? Average pricing?
I am assuming you are placing the front only?
Do you still have stock rear (Standard) break discs and pads?
Old 03-19-2015, 01:32 PM   #61
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Front - Endless MX72/PB05, approx R2500, last me 5-6 track days.
Rear - Bendix Ultimate, approx R1500, but stock pads are OK at the back, last me 7-8 track days.
I've ordered front and rear pads now, but the rears can do a few more track days before I change them.
Brake pads and tyres are the main consumables when you track your car, but it all depends how often you go on track, and how aggressive you are.
If you tootle around the track like an old lady, you're not going to wear out your tyres and pads, are you?
The Following 3 Users Say Thank You to Fish Eagle For This Useful Post:
FT_86_SM_GP (03-19-2015), JouMaSeHoes (03-20-2015), Vic_RSA (03-19-2015)
Old 06-25-2015, 08:48 AM   #62
Fish Eagle
Platinum Member
Fish Eagle's Avatar
I took off my worn Powerbrake front discs today, and put my almost brand new stock discs back on.
I understand that there's very little difference and I'm curious to see how the stock discs perform after I'm used to aftermarket.
Here's some pics of the Powerbrake discs. They've lasted as well (or better) than I could expect. They've done 16 track days, approx 700 track laps. They've got lots of surface cracks which are normal, and they're showing about 1.2mm wear either side (the ruler is 16th of an inch). I think that's probably as much as they can take - but I'm going to check with Powerbrake. Maybe they've still got some life left in them...
I've also added a pic of a what a plastic hub-centric ring looks like after a few sessions of track temps - LOL.
Actually, the plastic rings work fine until you try to take them off, then they disintegrate.
FT_86_SM_GP (06-25-2015), JouMaSeHoes (06-25-2015), sav (06-25-2015)
Old 07-15-2015, 10:12 AM   #63
FT_86_SM_GP
Drives: Lawn moweR
Would appreciate your guys advice on this.
I called Powerbrakes PTA today,
They said they are out of stock of Drilled and slotted brake disc's for the 86 until the end of August 2015,
They have Endless pads (For front pair) available for approx R2700, and Motul RBF660 for approx R500 a Litre,
What is your opinion on the following: (For mild use on Track)
1. Having stock brake pads and discs + with upgraded brake fluid (Motul)
(Approx R500)
2. Having stock brake discs + Endless Pads(Front only) + Motul RBF660
(Approx R3300)
Obviously option 2 will be better, but does the price difference justify the improved braking by having Endless pads + Stock discs combo.
Ie. Are aftermarket pads on Stock Discs effective?
Also another question, how many Liters of Brake fluid do you need to change your stock brake fluid?
I was also given "Safety Brake and Clutch" details in Edenvale to get pads and brake fluid changed, anyone dealt with them or have a trusted service center?
Or does everyone here change their pads and fluid on their own :-)
Old 07-15-2015, 11:17 AM   #64
Fish Eagle
Platinum Member
Fish Eagle's Avatar
(Approx R500)
(Approx R3300)
From the top down, here's my opinions - hope they help.
Stay away from drilled discs - they crack between the holes.
Slotted discs are better than stock but not that much better that you should drop the $$$ until you know you'll be tracking on a regular basis.
My slotted discs are worn out, so I'm currently on stock discs for a while again, and they're OK.
I'll be on stock discs on the 25th and 26th (I'm competing in the Michelin Cup at RSR on Sunday).
Yes, aftermarket pads on stock discs are effective, but...
Go for option 1 and just change your fluid for now. Motul 660 is good.
You might get it a bit cheaper at a motorbike shop though.
My local (Nelspruit) motorbike shop has it at R220/500ml.
If your techie doesn't waste fluid, you can do a change with 1 litre.
The PB aftermarket pads are good. I assume they quoted you for MX72/PB05 pads.
If you decide to track your car on a regular basis then it's a must have.
But you don't need them yet.
Just try to avoid using your ABS to much.
It's 100% OK to brake hard enough to make the ABS kick in, but learn from that and then try to contain your braking to just before it kicks in. Excessive ABS use will hammer your stock pads badly.
Also, be aware of pad fade.
If you start getting a spongy pedal or they just don't seem to be working properly, then go off the track, and let them cool down.
There are restrictions with stock pads, but you'll still be able to have a lot of fun without a problem or risk.
Just be alert to the warning signs.
Pad fade is progressive and gives you warning whereas cooking brake fluid is sudden and takes you by surprise.
Motul 660 won't cook, no matter how violent you are.
I change my own pads, but I get my tame tech to change my fluid.
One day I'll learn to do it myself.
Actually, I know how, I'm just too lazy and it's a k*k job
The Following User Says Thank You to Fish Eagle For This Useful Post:
FT_86_SM_GP (07-15-2015)
Old 07-15-2015, 11:44 AM   #65
Fish Eagle
Platinum Member
Fish Eagle's Avatar
If it's going to be your first outing on track, here's some excellent reading.
Read posts 1 to 4 and stop.
Ignore all the waffle after that.
A lot is drivel posted by idiots.
http://www.ft86club.com/forums/showthread.php?t=25485
Old 07-15-2015, 12:09 PM   #66
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Vari Racing
For those wanting brake upgrades, Vari Racing is now supplying upgrade kits and BBK kits for the 86 platform.
Ryan86 is offline   Reply With Quote
The Following User Says Thank You to Ryan86 For This Useful Post:
Old 07-15-2015, 12:16 PM   #67
Ryan86
Road Warrior
Ryan86's Avatar
Andy get yourself some Aluminum hub centric rings.
Fish Eagle (07-16-2015)
Old 07-15-2015, 01:03 PM   #68
FT_86_SM_GP
Drives: Lawn moweR
That looks like brake porn lol
Old 07-16-2015, 03:12 AM   #69
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Yep, I should do so, but I've still got a bag full of plastic rings and they're fine until you try to remove them.
Not an important part so I'm not fussed either way
Old 07-16-2015, 03:27 AM   #70
Dammod
Dammod's Avatar
Drives: .
(Approx R500)
(Approx R3300)
I'll throw my 2c in as well if thats ok...
Assuming we are talking about an N/A GT86:
I feel the 100% stock setup if great for the odd track day. This is my experience from my previous (heavier) Impreza as well as my BRZ and it comes down to two main points:
1. Brake later and harder once you are comfortable doing so: I find that a lot of people new to trackdays tend to brake faaaar too early and for longer periods of time as apposed to the more seasoned trackday enthusiast braking later and harder and for much shorter periods of time.
Shorter, harder braking is MUCH easier on your brakes then loooong drawn-out braking.
2. Dont do too many hotlaps: I cant give you an exact number for all tracks but I can use Killarney as an example.
My typical routine at Killarney would be one or two warm-up laps, followed by 3-4 hot-laps, a cool-down lap, 3 hot-laps again, then two cool-down and pit.
Banging out hot-lap after hot-lap KILLS brakes, especially if you are braking for extended periods of time as mentioned in point one.
My definition on a "cool-down" lap is doing a slow lap without or barely touching the brakes.
I was doing WRX laptimes with my N/A Impreza on 100% stock brakes, sticking to the above mentioned routine and I think I got slight brake fade once and that was because on one of my cool-down laps I decided to start "racing" someone again...
I'm not saying DONT upgrade your brakes, by all means, do it, it WILL be better then stock if done properly, but don't be scared to hit the track with stock brakes, just DONT do too many hotlaps and remember to let them cool down properly before pitting.
This is my experience.
Take it easy, dont "race" anyone, stay within your own limits and have FUN!
"Some will follow your footsteps, easier than they will your advice."
Dammod is offline   Reply With Quote
The Following 3 Users Say Thank You to Dammod For This Useful Post:
Alang (07-16-2015), FT_86_SM_GP (07-16-2015), qbzee007 (07-16-2015)
gc8 4 pot brakes wholeeoh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 05-15-2022 04:38 PM
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 05:53 PM
GT to GTS brakes? Turdinator AUSTRALIA 30 01-12-2014 12:33 AM
OEM Brakes? marinjim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-20-2012 10:26 PM
GT brakes jello AUSTRALIA 2 06-10-2012 09:10 AM
