Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 02-07-2015, 04:54 AM   #43
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
After having said that my brake fluid's still OK in my previous post in December (above), and after another 3 track days since then, I've decided that it's time for a change because it's started feeling quite spongy.
Previously I've used Endless RF650, but I found some Motul RBF660 in Nelspruit at less than half the price of Endless and the specs look very similar, so I'm going to give it a try.
Claimed boiling point 325°C dry, 205°C wet vs Endless RF650 which claims 323°C dry, and 218°C wet.
Anyone got experience with this product?
Fish Eagle is offline   Reply With Quote
The Following 2 Users Say Thank You to Fish Eagle For This Useful Post:
FT_86_SM_GP (02-07-2015), sav (02-09-2015)
Old 02-07-2015, 10:08 AM   #44
Vic_RSA
The voice of reason...
Vic_RSA's Avatar
Drives: 2012 Toyota 86 6MT Standard
Heard good things about the Motul product especially with regards to performance vs. price compared to Endless. Formula Friction in Edenvale recommend a Ferodo alternative.
Vic_RSA is offline   Reply With Quote
The Following User Says Thank You to Vic_RSA For This Useful Post:
Fish Eagle (02-07-2015)
Old 02-09-2015, 08:24 AM   #45
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Yep, we always use Motul in the bikes. RBF600 I think, I'm assuming 660 would be even better. The best part is that you can buy it from pretty much any bike shop.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 02-09-2015, 08:47 AM   #46
Fish Eagle
Platinum Member
Fish Eagle's Avatar
That's where I got it.
Old 02-09-2015, 09:05 AM   #47
sav
sav's Avatar
Cool!
95RON SAV Tuned
Old 03-19-2015, 03:56 AM   #48
Fish Eagle
Platinum Member
Fish Eagle's Avatar
I felt that my brakes were on their last legs on Sunday, so I did a front brake pads change yesterday.
They only just lasted the day and smeared a bit at the end.
Not a surprise because those pads have done 5 or 6 hard track days already...
I thought it would be a good time to re-iterate the most important thing that I've learned about brakes, which is -
DON'T GO ONTO A RACETRACK WITH STOCK BRAKES
It's probably the most important safety upgrade you can do, and it's not expensive.
Feel free to contact me if you need more info.
See the pic of my caliper and disc to get an idea of the temperatures generated on track.
Here's an excellent article about brakes for track day use - http://www.powerbrake.co.za/tech_inf..._trackdays.htm
sav (03-19-2015), tm86 (03-19-2015)
Old 03-19-2015, 04:03 AM   #49
sav
sav's Avatar
YIKES!
BTW.
I don't have the link anymore but apparently it's possible to upgrade the Std spec's 277mm rotors to the High spec's 295mm by simple getting the High spec brackets. That should be a fairly substantial upgrade with a much bigger surface area.
So Powerbrake 295mm slotted rotors with Endless pads, fluid and High spec brackets then you're sorted.
95RON SAV Tuned
The Following User Says Thank You to sav For This Useful Post:
Fish Eagle (03-19-2015)
Old 03-19-2015, 04:14 AM   #50
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Thanks. Maybe I'll consider that when I need to replace my discs.
I'm actually very happy with my brakes as is, and I'm getting gentler on them as my experience grows. A typical noob trait is to overbrake into corners, and as driving skills improve one carries more and more speed into the corner.
Using a set of front pads every 5-6 track days, and rear pads every 8-9 track days seems normal to me. My discs don't have any bad cracks but they're getting quite worn and will need skimming or replacing in the not too distant future.
Old 03-19-2015, 05:01 AM   #51
sav
sav's Avatar
Cool, I agree - do it when you replace disks. I doubt the disks would be much more expensive. Not sure what those brackets cost.
95RON SAV Tuned
Old 03-19-2015, 06:45 AM   #52
tm86
Drives: 2013 Dark Grey 86B
Thanks Fish Eagle, you are a valuable resource of all things 86
How long do you take to replace the front pads?
tm86 is offline   Reply With Quote
The Following User Says Thank You to tm86 For This Useful Post:
Old 03-19-2015, 06:47 AM   #53
sav
sav's Avatar
That sounds like a challenge! I reckon 20-30mins from start to finish.
95RON SAV Tuned
Old 03-19-2015, 07:41 AM   #54
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Yep, 30mins is more than enough to change front pads.
Old 03-19-2015, 07:43 AM   #55
sav
sav's Avatar
Yep, and they've made it so easy - one bolt and that's it.
95RON SAV Tuned
Old 03-19-2015, 07:54 AM   #56
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Most of the work is jacking the car up, taking the wheel off, and putting the wheel back on.
Changing the actual pads is a cinch.
But you do need some strength to push the pistons back when fitting new pads (or a big tool)
gc8 4 pot brakes wholeeoh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 05-15-2022 04:38 PM
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 05:53 PM
GT to GTS brakes? Turdinator AUSTRALIA 30 01-12-2014 12:33 AM
OEM Brakes? marinjim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-20-2012 10:26 PM
GT brakes jello AUSTRALIA 2 06-10-2012 09:10 AM
