Old 03-05-2015, 08:45 PM   #1
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
OFT - Example alternate maps for AT, 98RON, E85, MAF Scales
Note:
I now have files hosted for all MY12-16 cals here.
- On my roms you can dial in AFR perfectly on stock intake IN ONE REVISION with alternate maf scales.
- All are cal hacked from A01G/A01I/B01C/B01D, thus logging and LC work for every rom on OFT.
- No issues with unmapped DTC's or E85 cranking.
- Includes FLEX FUEL for both 6AT and 6MT.
- I've done a few MY17's now, but I've no idea about the logging capabilities for those cars on OFT yet.
ADDRESS: http://www.wayneroms.com/
While the following examples may still be interesting to some, my current files make the majority unnecessary and obsolete.
Below examples represent easily between 200 flashes to my ECU. Some of the screens are current, some seem fairly rudimentary now, but they still make decent examples.
Please see the guide below for choosing a maf scale and load limits.
http://www.ft86club.com/forums/showthread.php?t=94822
WHAT TO LOG TO DIAL IN YOUR TUNE:
Engine Speed (rpm)
Throttle (percent)
MAF Voltage (volts)
MAF g/s
Engine Load (g/rev)
Ignition Advance / Total Timing (degrees)
AFR
Commanded AFR / Target AFR
STFT (percent)
LTFT (percent)
Fuel Sys Status (2 = CL, 4 = OL)
IAT / Intake Air Temp (F)
Advance Multiplier
FLKC / Fine Learning Knock Correction (degrees)
IT'S IMPORTANT TO DRIVE 100km/60mi AT PART THROTTLE UP TO 6000rpm THEN LOG THE ABOVE PARAMETERS AT WOT 2500-7200 rpm. ONLY THEN WILL YOU BE ABLE TO CHOOSE THE CORRECT AND/OR WORK ON A MAF SCALE.
SEE END OF POST FOR DEFINITIONS AND EXAMPLE ROMS
COMMON CHANGES
O2 SENSOR SCALE (NOTE: RESCALED AXIS)
OTS (top)
v86 (bottom)
Radiator fan activation when car is at operating temperature and under 70kph.
OTS/Stock (top)
v86 (bottom)
AT THROTTLE
All my maps now have a brand new AT throttle map. The MT throttle map is more linear but doesn't work as well between shifts on the AT with longer ratios.
v100 (left)
OTS/Stock (right)
LOAD LIMITS (NOTE: RESCALED AXIS)
(out of date)
STAGE 1
Stg1 98 v86 vs OTS BASE TIMING DIFF
Stg1 AND Stg2 98 TOTAL PORT INJECTOR RATIO (COLD/HOT/WARM) NOTE: RESCALED AXIS
This is useful for maf scaling. I recommend restoring port injection at 5000 rpm to be safe.
STAGE 2
Stg2 98 AND E85 QUIET COLD START
OTS (top)
v86 (bottom)
STAGE 2 PETROL
Stg2 98 MAF SCALE
(out of date)
OTS vs v86 DIFF (top)
v86 (bottom)
Stg2 98 LEAN VS RICH MAF SCALE
(out of date)
v86 LEAN based on Stg1 (top)
v86 RICH based on Stg2 (bottom)
Stg2 98 v100 vs OTS BASE TIMING DIFF
Stg2 vs Stg1 BASE TIMING DIFF
(out of date)
Stg2 IMRE 98 vs Stg2 98 BASE TIMING DIFF
Stg2 98 v86 vs OTS TOTAL TIMING CHANGES (3D) (Add +6 deg adv for total timing)
(out of date)
E85
E85 FUEL DASH DISPLAY
OTS/Stock (top)
v86 (bottom)
E85 CRANKING IPW
E85 CLOSED LOOP FUELING MAP
OTS (top)
v86 (bottom)
E86 OPEN LOOP FUELING MAP
OTS (top)
v86 (bottom)
E85 v86 vs OTS BASE TIMING DIFF
v99 E85 vs 98 v100 TOTAL TIMING DIFF
E85 v86 vs OTS TOTAL TIMING CHANGES (3D) (Add +6 deg adv for total timing)
Old 03-19-2015, 03:02 AM   #2
RelentlessGT
Drives: Toyota GT86 Manual
Thanks Wayno.
How hard is it to apply these same changes to the manual ZA1J___G ROMS (EU 6MT) roms?
Have you made any changes for your PSR Headers (or are they similar enough to the OpenFlash headers that they just work)?
RelentlessGT is offline   Reply With Quote
Old 03-19-2015, 03:15 AM   #3
Wayno
Wayno's Avatar
Yep, any G rom.
Most UEL are the same. The ethanol in our E85 is mixed with worse fuel than US though, so there's some timing taken out for knock a few people have logged at 6800rpm, even though our E% is higher.
Old 03-19-2015, 11:33 AM   #4
Koa
You the man @Wayno. Thx
Old 03-19-2015, 12:26 PM   #5
GT86meMR2
GT86meMR2's Avatar
Drives: MR Spyder/GT86
I dont get it so this is only for the the automatics? or can it be used for manuals?
GT86
Current Mods: Ace Header with 350 OP-Berk Frontpipe-Miltek Resonated Catback-OFT-k&n drop in filter
GT86meMR2 is offline   Reply With Quote
Old 03-19-2015, 04:20 PM   #6
steve99
Drives: FT86
The tables for fueling/timing/fan temps/IAT compensation ect are same for manual/auto just copy them across. Assuming you have same header type.
Throttle tables are different between auto/manual.
Their is an E85 G rom attached to the first post
Old 03-19-2015, 04:48 PM   #7
ztan
Drives: Toyota 86
Nice work Wayno.
ztan is offline   Reply With Quote
Old 03-26-2015, 07:39 AM   #8
Wayno
Wayno's Avatar
More work done to E85 tunes. OP updated.
Old 03-26-2015, 07:49 PM   #9
cawith
Drives: Toyota GT86 6M/T
Did you change all/most of the tables?
cawith is offline   Reply With Quote
Old 03-26-2015, 07:51 PM   #10
Wayno
Wayno's Avatar
Timing, fuel, cranking, do a compare with the old one if you downloaded it.
Old 03-30-2015, 03:13 AM   #11
Trettiosjuan
Drives: GT86
Good work.
I do wonder if there is any further discussion on long term effects of running lean even on low load but for extended times? What to look for when logging, what could go wrong? Target AFR 14.7? Is this both DI and indirect injection?
Also what happens during the warm up phase?
Sorry lots of questions
Trettiosjuan is offline   Reply With Quote
Old 03-30-2015, 03:39 AM   #12
steve99
Drives: FT86
Originally Posted by Trettiosjuan View Post
Good work.
Also what happens during the warm upv phase?
If you have a look at the stock rom fueling tables you will see it runs leaner than these tunes for higher rpm and loads.
The OL AFR fueling tables are the target afr, their are tables for the di\pi ratios but the overall target afr is determined by the ol fuel table and a couple of closed loop offset tables when running in closed loop.
Ethanol generally results in lower exhaust temps than petrol.
As always these tunes are provided free with no guarantee, run at your own risk.
@Wayno and myself have been running them for a few months and mine is running leaner tables than the ones posted here, however everyones fuel blends are different..
always check your tune is running reasnoble fuel trims less than 10%, your wot afr follows open loop fuel table and little or no knock and iam at 1.
by warmup phase assume you mean high rev cold start, as far as we know this is just to heat cats for emmisions purposes, you still need to give you car about 10 minutes to get coolant and oil to operating temps, regardless of what alterations you make to starup phase
Old 03-30-2015, 06:27 AM   #13
Trettiosjuan
Drives: GT86
Warm-up I usually drive very light throttle just under 3000rpm, I wondered how this could be affected by a leaner blend.
Old 03-30-2015, 07:07 AM   #14
steve99
Drives: FT86
stuff all i think, have not noticed any change
Help uploading 2.06 tunes to OFT Jimmy817 Software Tuning 3 12-28-2014 09:06 PM
Custom Az Tunes Juggles Arizona 13 11-08-2014 10:15 AM
EcuTek Tunes Rio Engine, Exhaust, Transmission 1 04-29-2014 12:10 AM
How long until *other tunes? ScionFrsFan Engine, Exhaust, Transmission 61 12-07-2012 05:34 PM
Speedhunters - TRD TUNES THE 86 quik1987 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 69 05-22-2012 04:26 PM
