Old 03-17-2015, 12:35 AM   #99
Amir Ghadiri
Amir Ghadiri's Avatar
So I got a decent bit done today. I finally honed the cylinders, then I gapped and installed the rings for cylinders 2 and 4. I ran out of time to do them today, but I have cylinders 1 and 3 ready to go tomorrow.
I did a fair amount of research on how our rings should be gapped for certain boost levels, and I decided to go with the following specs:
Top ring: bore x .0055"
Bottom ring: bore x .0060"
I am a little on the conservative side, but I think we should be okay. I'm planning on running 18-20PSI boost.
I had planned to just lap my valves in when I installed the new valve springs, but I felt that the valves weren't seating properly before the tear down. I did a leak down test on them and sure enough, 9/16 valves weren't seating properly!! So instead of just lapping them in, I'll be sending them out to my machinist for a proper valve job.
Stay tuned!!
Size:  200.6 KBName:  ImageUploadedByTapatalk1426566660.043141.jpg
Size:  193.0 KBName:  ImageUploadedByTapatalk1426566726.079040.jpg
Amir Ghadiri is offline   Reply With Quote
The Following User Says Thank You to Amir Ghadiri For This Useful Post:
mit_peid (03-26-2015)
Old 03-18-2015, 09:49 PM   #100
BboyKidKoda
BboyKidKoda's Avatar
Drives: Scion Frs
Question
If i was running about 6-8psi and i had a bunch of bolt ons and good tune. do you think i could make around 280-300hp with this kit and daily drive it safely? i just dont have alot of money to replace if something bigger happens. Thank you!!
BboyKidKoda is offline   Reply With Quote
Old 03-20-2015, 12:33 AM   #101
Amir Ghadiri
Running 6-8 psi you'll make maybe 250-275 WHP. It should be pretty reliable, 6-8 psi is not much at all. At 10psi it took heavy track use for me to start having problems!
The Following 2 Users Say Thank You to Amir Ghadiri For This Useful Post:
2013GTRNate (02-13-2016), pward08 (03-25-2018)
Old 03-20-2015, 06:36 AM   #102
BboyKidKoda
Drives: Scion Frs
Okay cool. I rea appreciate it. What weight oil do you use btw?
Be original don't copy!
Old 03-20-2015, 01:49 PM   #103
Amir Ghadiri
I'm personally using 5/30 but honestly don't know if I should be. I'm going to do some more research and see if I should go with something higher
Old 03-20-2015, 02:15 PM   #104
BboyKidKoda
Drives: Scion Frs
Yeah I would definitly go higher haha
Old 03-22-2015, 12:16 AM   #105
Amir Ghadiri
Heads are on! Car should be done this Friday
Size:  233.6 KBName:  ImageUploadedByTapatalk1426997704.187739.jpg
Size:  229.5 KBName:  ImageUploadedByTapatalk1426997729.819628.jpg
Oh yeah, an alignment may be in order
Size:  249.0 KBName:  ImageUploadedByTapatalk1426997810.476603.jpg
Old 03-24-2015, 01:42 AM   #106
Amir Ghadiri
Resprayed the engine bay today! Engine should be in by the end of tomorrow
BboyKidKoda (03-24-2015)
Old 03-24-2015, 12:02 PM   #107
CAMBAM_6
CAMBAM
CAMBAM_6's Avatar
Drives: '13 Whiteout FRS
I loved the APR splitter, but I really wanted a front lip. Why not have both?
When you had the front lip and the APR splitter did you have to do anything to install the splitter or is it adjustable for lips?
Think I want to do that but not sure if anything needs to be cut...How did you like that setup when you had it? Any problems?
If you think the FRS/BRZ isn't fast enough, the roads you're driving on are too straight.
CAMBAM_6 is offline   Reply With Quote
Old 03-24-2015, 12:30 PM   #108
Amir Ghadiri
I just made new brackets to hold the APR splitter and it was good to go, didnt need to modify anything. I really liked the setup, it looked worked and looked great! I actually really miss it now, I'll be getting a new splitter soon though!
CAMBAM_6 (03-24-2015)
Old 03-25-2015, 02:35 AM   #109
Amir Ghadiri
Installing the motor today was wishful thinking, but I have it assembled and ready to drop in first thing tomorrow. Just need to pick it off the engine stand and bolt on the clutch, then we'll be rollin! Friday is coming closer and closer but I think I'll be able to make it
Size:  275.9 KBName:  ImageUploadedByTapatalk1427265294.717478.jpg
Old 03-25-2015, 10:48 AM   #110
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
Sooo clean!
"Don't be a don'ter, do be a doer" - Johnny Wu
ap5512 is offline   Reply With Quote
The Following User Says Thank You to ap5512 For This Useful Post:
Amir Ghadiri (03-26-2015)
Old 03-26-2015, 12:41 AM   #111
Amir Ghadiri
Originally Posted by ap5512 View Post
Sooo clean!
Thanks, I really appreciate it!! I can't wait to finish and get back on the road!
Old 03-26-2015, 12:51 AM   #112
Amir Ghadiri
Lowered. Boosted. Jdm. Its so shiny it hurts my eyes
I still don't have the motor in
I ordered new spark plugs from the auto parts store yesterday, and they brought me the wrong ones today. I won't have the correct plugs until the morning, so motor won't go in until tomorrow. Thats okay though, I made some progress on other parts! Brake booster, ABS, clutch master, brake master, and fenders are all back on. Also tucked away a few wires behind the firewall while I was there! Suspension is all bolted in and ready for the alignment. Cam sensors & solenoids are on the motor along with direct injectors, rails, etc. Wiring harness is back on and plugged in. Hopefully I'll be able to install and fire the motor tomorrow, we'll see!
And yes, I know that alternator pulley is installed in the wrong place. My friend tried to play a joke on me
How Shiny Are the Work Kiwami GTS Silver bobsacamenoh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 11-01-2014 08:34 PM
how to make polyurethane shiny DarkestBuddha Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 05-04-2014 01:26 AM
FR-S? BRZ? Premium? Limited? 10 Series? My brain hurts! oldpueblo Scion FR-S / Toyota 86 GT86 General Forum 36 01-02-2014 10:14 PM
Winter hurts. Superhatch BRZ First-Gen (2012+) — General Topics 33 02-07-2013 08:29 PM
shiny wheels jarviz Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 08-21-2012 03:23 PM
