Old 01-15-2015, 08:14 PM   #267
sissupr
sissupr's Avatar
Drives: 2014 BRZ Premium - SWP
quick question... it seems my tensioner bolt is loose... how do you re-tighten it. Apologize if this is stupid question.
Vortech SC V3 // 3.12 Pulley // Moto-East Tune (93oct,e40-50,e85)
sissupr is offline   Reply With Quote
Old 03-17-2015, 09:22 PM   #268
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
I have the car in sixth and the pulley is not quite locked in place. It turns quite a bit and its scaring me how much if any play should it have? I've put a bit of force on it so far and nothing...
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
Old 03-18-2015, 12:04 AM   #269
CoupedUpSubie
Drives: 2013 BRZ Limited
Before or after install? Approximately how much of a full turn? If you are getting 1/4 turn then it is probably just how everything stopped as fars as gears and engine internals go. Push the clutch in and roll the car forward a bit and let the clutch out to stop it. Then see how much movement you get.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
The Following User Says Thank You to CoupedUpSubie For This Useful Post:
Strife26 (03-18-2015)
Old 03-18-2015, 12:23 AM   #270
Strife26
Strife26's Avatar
Thanks I got it. I was about to give up because the socket slipped and was going to strip and I was frustrated. I tried one more time and it came off. Top speed pulleys installed!
Thanks
Old 03-18-2015, 12:57 AM   #271
CoupedUpSubie
It can take a decent length breaker bar at times, it took me a bit to get mine free. Hope you were using a 6 point socket, 12 point sockets like to eat bolt heads.
Old 03-18-2015, 05:27 AM   #272
Strife26
Strife26's Avatar
I had a breaker but it scared me. It was a makeshift bar. I made it from cheap ass Walmart lamp haha. Half if it slipped off so I have up on the breaker. The ratchet was pretty big on its own. And it was 12 point it was all I had . I got it though. Easy install!
Old 03-18-2015, 10:55 AM   #273
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Taking the spare out of the trunk will make about a 10X difference compared to losing 4lbs from the pulley.
This is a little OBE and OT but I wanted to highlight this because I missed it the first time you posted it.
Absolutely correct. That's why I took the spare, toolkit, and stock muffler off. Before I passed the first month with my car. The pulley was a further optimization on the front end. Where things are a lot harder and more expensive to make lighter. I wish I could figure out how folks have gotten the DI covers off. Those things weigh a couple pounds each but they're both obstructed. Granted, I was fiddling with them when it was 20 degrees F out and now that it's warmer I might be able to get them done.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 03-18-2015, 10:57 AM   #274
phobos512
phobos512's Avatar
Get a six point set and a real breaker bar. I used a 24 inch breaker bar and it came right off, but I'm not a small person. I braced against my STB with my left hand and pulled with my right. Drivetrain gave slightly and then pop. Never use a torque wrench to loosen things, and try not to use a ratchet - you'll mess up the calibration of the torque wrench and you'll potentially screw up the ratcheting mechanism (it'd be not unlike rounding off a bolt head).
The Following User Says Thank You to phobos512 For This Useful Post:
Imperius (11-10-2016)
Old 03-18-2015, 11:33 AM   #275
stugray
Drives: 2013 GBS BRZ Limited
There was a thread on here where someone removed the DI fuel rail shields.
MANY people (including myself) advised against that.
With those shields removed it would only take a minor accident to have >1500 PSI fuel spraying around the hot engine bay.
Old 03-18-2015, 11:38 AM   #276
phobos512
phobos512's Avatar
Yeah, I know. It's about risk acceptance. There are a couple threads where it's mentioned and pics of them having been removed, but none actually documenting how it was done. @Anthony had the best detail but I must be missing something.
Old 03-18-2015, 03:28 PM   #277
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Are you the one who asked me about it a while back?
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 03-18-2015, 04:06 PM   #278
phobos512
phobos512's Avatar
Yep. I bow to your lightweighting greatness!
Old 03-18-2015, 04:23 PM   #279
Anthony
Weight Nazi
Anthony's Avatar
Haha thanks. That was a long time ago though. I can't imagine what must be stopping you.
Old 04-27-2015, 03:46 PM   #280
bensims1
Drives: Very Black
crank pulley bolt removal tip
i saw this [ame="https://www.youtube.com/watch?v=7G-adEVjfWI"]video[/ame] on youtube for a cheeky tip to get the crank pulley bolt off by starting the engine while having a breaker bar not the bolt and wedged someone it won't move.
I don't know if this is much use or even a wise thing to do but i thought ill post it anyway.
bensims1 is offline   Reply With Quote
The Following 3 Users Say Thank You to bensims1 For This Useful Post:
Anthony (04-27-2015), Marrk (04-27-2015), Trap63 (05-03-2015)
brz, crank pulley, diy, frs, perrin, raceseng
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 07-07-2012 10:24 PM
