Old 03-17-2015, 01:34 AM   #1765
904FRSlow
904FRSlow's Avatar
Drives: '13 FR-S Whiteout
How reliable is the JRSC on an auto trans? Thinking of getting this and running low boost
904FRSlow is offline   Reply With Quote
Old 03-17-2015, 02:12 AM   #1766
CSG Mike
CSG Mike's Avatar
Just as good as the MT.
There is only one boost level available for the JRSC.
904FRSlow (03-17-2015)
Old 03-17-2015, 03:03 AM   #1767
904FRSlow
904FRSlow's Avatar
What is the boost on it? I really want something reliable that can achieve 240 whp. I'm at 192 with driveshaft/exhaust/tune right now.
Old 03-17-2015, 03:41 AM   #1768
nlopez
http://www.ft86club.com/forums/showp...postcount=1586
nlopez is offline   Reply With Quote
The Following User Says Thank You to nlopez For This Useful Post:
Old 03-17-2015, 03:46 AM   #1769
904FRSlow
904FRSlow's Avatar
Originally Posted by nlopez View Post
Sweet, thanks! Time to start saving up.
Old 03-17-2015, 08:45 AM   #1770
dp1
driving smoother faster
Drives: Sold
JRSC/catless P&L EL header/overpipe/hi-flow cat front pipe/Q300 can
Immediate neighbors know when I start the car in the (North East) winter, but moving right after the start helps bring noise down quickly. Quiet on cruise and noticeably louder but not too loud with some rasp on higher RPMs/WOT. Probably lost some baffling in 9mo of street/ax/track.
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
CSG Mike (03-17-2015)
Old 03-19-2015, 12:50 AM   #1771
alpax
alpax's Avatar
Drives: 2013 Subaru BRZ AT JRSC
I have a pretty stupid question (already out of ideas trying to fix those issues with fuel trims ).
The new high-performance PCV valve, which is installed into the PCV hose, is one direction. Do I understand correctly - it stops air blowing FROM intake manifold, but allows it in, right?
Here's the picture:
Are the arrows correct?
alpax is offline   Reply With Quote
Old 03-19-2015, 02:30 AM   #1772
sw20kosh
Drives: 2013 Black FR-S
Here's the picture:
Attachment 104888
Yes.
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
alpax (03-19-2015), CSG Mike (03-19-2015)
Old 03-19-2015, 02:45 AM   #1773
alpax
alpax's Avatar
Thank you for the confirmation @sw20kosh.
Can anybody post their data logs with JR SC & CARB tune please? I was told the tune may actually be at the richer side, but I don't have any data to compare.
Mine seems to run too rich. The fuel trims keep misbehaving. LTFT consistently drifts to -25 and below, and eventually causes P0172.
Old 03-19-2015, 09:32 AM   #1774
enivid
enivid's Avatar
Drives: WRB JR BRZED
Size:  163.4 KB check these hoses?
enivid is offline   Reply With Quote
The Following 2 Users Say Thank You to enivid For This Useful Post:
alpax (03-19-2015), Xuningshen (03-19-2015)
Old 03-19-2015, 02:18 PM   #1775
CSG Mike
CSG Mike's Avatar
I recommend you check all of your PCV system hoses to make sure none of them haven't inadvertently popped off. Additionally, double check your MAF O-ring. The kit includes a new one becaused used o-rings frequently are damaged.
alpax (03-19-2015)
Old 03-19-2015, 03:26 PM   #1776
alpax
alpax's Avatar
Yes, I already replaced the MAF connector O-ring, though I didn't find any leaks in that area.
Looked like there was a small leak in the vacuum cap where the vacuum tee was connected (on the MT cars there is a vacuum hose, on my automatic there is just a cap). The cap was slightly damaged I guess when I removed it to install the tee. I replaced it three days ago, but I wonder if there could be any permanent damage because of that leak being there for several months.
I will double-check the PCV hoses.
Old 03-19-2015, 05:16 PM   #1777
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
Had an uber odd issue with a JRSC kit equipped FRS yesterday...
Twice the car has come in with complaints of "rich" codes being triggered (CARB tune). I had already trapped the event happening at the onset of boost (transition from closed to open loop). I have seen this before and it can be as simple as rotating the MAF sensor housing.
Visit one: The car had the old silicone intake hose (instead of the new pipe). So first thing we did was clean the MAF and swap the tube for the pipe. Next we rotated the MAF (trying different positions). This helped some, and also made it worse depending on rotation. In the end the we were not pleased with the -20% fuel Long Term Learned fuel trim, but it was not throwing a code.
Visit 2: At the car would no longer communicate. 4 different lap tops and cables, 3 different scanners and my Solus. Nothing would talk. We requested JR send over the CARB tune in a zipped file so we could verify no corruption in the map and re-flash with the newest version of EcuTeK software.
Visit 3: The reflash appeared successful. Until we revved it up. Then the fuel trims went haywire again and the car was uber rich (-35%). So, after speaking with Oscar Sr and Jr we decided to remove all 4 aftermarket HID ballasts from the car. It worked. It would appear the RF interference from the DDM Tuning HID kits (4 of them) was causing corruption in the communication. The issue went away as soon as the HID's were disconnected.
I am now waiting for some feedback from the customer. He was planning on swapping out the HID's for LED's. He will continue to monitor the fuel trims and report back.
For now, any owners who might be experiencing odd issues like this might want to check the install of their aftermarket HID's (if so equipped).
Infamous Performance is offline   Reply With Quote
Old 03-19-2015, 05:45 PM   #1778
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
Yup. I remember CSG Mike telling me about this issue last time I visited.
ApolloSki is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
