Old 03-11-2015, 06:45 PM   #15
keen as
keen as's Avatar
Drives: 86 GT MT
Many thanks for a great update.
And may I ask again for option of temperature in Degrees Celcius?
Originally Posted by Shiv@Openflash View Post
Hi guys,
We have increased the max number of stored files from 10 to 20. Max time duration for each log is approx 20 minutes. So we are taking nearly 400 minutes of on-board data storage! We have also added a [space] button for naming the data files.
This update should be released to the public by Friday just in time for the weekend
keen as is offline   Reply With Quote
Old 03-11-2015, 07:20 PM   #16
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I haven't used or updated my oft in months, but now that spring is rolling around, I think I'll update and perform a checkup. It's nice to be able to know that everything is running right, instead of hoping everything is. Thanks for the updates
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 03-13-2015, 01:12 PM   #17
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
@Shiv@Openflash
Reading another thread gave me an idea for your next update...maybe add an autopatic pedal dance function that you can toggle on and off using the OFT? FT86Speedfactory sells a guy that goes in there but it takes away the OBD2 port for datalogging
if you could figure it out
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 03-13-2015, 02:26 PM   #18
Cop
Cop's Avatar
Drives: 2013 FRS
Hi guys,
Just to clarify, does that mean that OFT will not be able to record data past 20 minutes of driving time without needing to log a separate file?
Cop is offline   Reply With Quote
Old 03-13-2015, 06:18 PM   #19
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Silver Ignition View Post
@Shiv@Openflash
That should be doable. Maybe in the next update
Shiv@Openflash is offline   Reply With Quote
Old 03-13-2015, 06:19 PM   #20
Shiv@Openflash
Drives: 2013 FRS
This is correct
Old 03-14-2015, 09:20 PM   #21
tracerit
Drives: '13 SSM BRZ Limited 6MT
If I were to log past the 20 minute limit, will it auto create a new log or will it stop after 20minute on the first one?
I personally would've preferred a setup of 10 40-minute logs over the 20 20-minute logs. I suppose there's good reasoning to make it short though, I logged a 60-90 minute drive from work home this morning and it came out garbled.
tracerit is offline   Reply With Quote
Old 03-16-2015, 12:24 AM   #22
Nardi330
Nardi330's Avatar
Drives: 86
Has the update been released yet?
thanks.
Nardi330 is offline   Reply With Quote
Old 03-16-2015, 02:12 AM   #23
Shiv@Openflash
Drives: 2013 FRS
thanks.
The new software updates should be available late tonight via auto update. But a new version of the user software will also be needed in order to manage the multiple data log files format. This should be available and ready to download from our website on Tuesday.
Old 03-16-2015, 11:50 PM   #24
tracerit
got the new OFT update through OpenFlash Manaager but no OFM program update yet. Looks like only my first log (of two) are downloadable, my second log is still sitting there, hopefully.
Old 03-17-2015, 12:16 AM   #25
Shiv@Openflash
Drives: 2013 FRS
Yes, the other logs should still be there. I'll be back on the office on Wednesday (plane doesn't land until Tues night). Once I'm back, I'll quickly test the new version of OpenFlash Manager and post it up for everyone to download. I have it right here on my desktop but I really don't want to post anything up until I personally test it
Old 03-17-2015, 12:22 AM   #26
tracerit
if OFM only downloaded the first log, and there are no way to manage the multiple logs on the OFT, does that mean until a new OFM is released, i'll only be able to download the same first log over and over and not any of the new logs?
Old 03-17-2015, 12:27 AM   #27
Shiv@Openflash
Drives: 2013 FRS
I have not tested the new multi-log file firmware update with the old single-log file OFM. So i cannot be certain if the old OFM will only pull up the first or last log stored on the OFT. If I had to guess, I'd say it will store the first log in memory. But when the OFM is released (probably late tomorrow night/early wednesday), you should be able to recover all of the logs you have saved on the OFT.
Old 03-17-2015, 12:35 AM   #28
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Is there an updated template file for this yet? I'm able to save multiple files, but the save prompts don't come up as text just as #s.
Ex: Instead of saying "Would you like to save this datalog?" It would just come up as "6034".
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
OpenFlash Tablet will not connect to OpenFlash Manager rever5e Software Tuning 10 03-12-2022 10:17 AM
FS: Brand New Openflash Header AND Openflash Tablet combo FT86POWER Engine, Exhaust, Bolt-Ons 6 02-11-2015 02:56 PM
Openflash Tablet + Openflash Header smellslikecurry Engine, Exhaust, Bolt-Ons 9 12-01-2014 06:20 PM
OpenFlash Tablet: Enhanced Data Logging (Sneak Peek) Shiv@Openflash Software Tuning 51 06-03-2014 07:09 AM
OpenFlash Tablet v1.55b: BIN files added! Shiv@Openflash Software Tuning 525 04-09-2014 09:42 PM
