Old 01-18-2015, 10:13 PM   #183
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
Where do people get the DI seals to replace? I'm inclined to try this myself. I haven't been able to find a part number for them.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 01-18-2015, 10:20 PM   #184
blown
Drives: ft86
dealer
blown is offline   Reply With Quote
Old 01-18-2015, 10:22 PM   #185
zkv476
zkv476's Avatar
Originally Posted by blown View Post
dealer
Anyone have a part number or do I just have to ask the parts guy to look it up? Thanks
Old 01-21-2015, 03:35 PM   #186
pleong
Drives: 2013 Whiteout FR-S
SU003-00322
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
Old 02-13-2015, 12:21 PM   #187
TEWwild
TEWwild's Avatar
Drives: 2015 Ultramarine FR-S MT
Installing seal onto the SST holder tip
First off, HUGE thanks @Dezoris for this video, not sure I would have tried it without seeing it. I replaced my seals about 2 weeks ago and my car has been running great since, no more firecrackers!! My #3(passenger side/rear) injector seal was gone and the other 3 were "burnt"/damaged... After fighting the seals onto the holder portion of the tool I came up with the following procedure to install them.
[ame]http://youtu.be/FLrM3X4WLCc[/ame]
I used this procedure for the last 2 seals and it actually made the process of moving the ring over the seal to reset it much easier as well because it resulted in no deformation of the seal.
Pic of the seal after using this procedure: Results.jpg
All 4: As they came out.jpg
#3: #3.jpg
#1: #1.jpg
Hope this makes the job a little less frustrating for everyone!!
TEWwild is offline   Reply With Quote
The Following 7 Users Say Thank You to TEWwild For This Useful Post:
DocWalt (12-31-2015), GhostOp86 (03-15-2015), juliog (03-11-2015), Lonewolf (02-13-2015), radroach (03-16-2015), RehabJeff86 (02-14-2015), Valentino (04-19-2015)
Old 02-13-2015, 04:37 PM   #188
Dezoris
Dezoris's Avatar
#3: #3.jpg
#1: #1.jpg
Great idea! Did you replace that injector looks very scorched.
Old 02-13-2015, 05:20 PM   #189
TEWwild
TEWwild's Avatar
Nope, cleaned it up and put it back in. Seems fine so far, no noticeable power loss even under "extreme" conditions.
Old 03-14-2015, 02:17 AM   #190
juliog
juliog's Avatar
Drives: 86
Does anyone have the all the part numbers for the DI seal replacement job? @Dezoris @whataboutbob
Want to make sure I don't leave any of these out:
Port Injector O-Rings
Direct Injector fuel lines (QTY2)
DI Backup Ring, Insulator, Primary Seal and O-rings
Got ahold of the service manual, reading the section regarding DI seals and writing down parts..
juliog is offline   Reply With Quote
The Following 2 Users Say Thank You to juliog For This Useful Post:
CSG Mike (03-14-2015), whataboutbob (03-16-2015)
Old 03-15-2015, 12:10 PM   #191
Dezoris
Dezoris's Avatar
I have the parts list from toyota in PDF if you want it.
The Following User Says Thank You to Dezoris For This Useful Post:
whataboutbob (03-17-2015)
Old 03-16-2015, 05:47 PM   #192
whataboutbob
AutoX-10/10ths every run
Here's the list of parts I used.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
juliog (03-16-2015)
Old 03-16-2015, 09:53 PM   #193
illmatic
illmatic's Avatar
Drives: BRZ Limited 6MT, 02 AW, 03PSM WRX
If you are going to go in there and replace, why not consider some aftermarket ones from autofactory.
http://www.autofactory.jp/product/to...=s&pm=t&seq=34
illmatic is offline   Reply With Quote
The Following User Says Thank You to illmatic For This Useful Post:
Old 03-16-2015, 11:41 PM   #194
juliog
juliog's Avatar
Drives: 86
Those are expensive ($50 per set, you want 3-4 sets per install as they are scratched easily), ordering would be a hassle, shipping would take too long, and I'm not sure they're proven.
If they are proven to last longer than OEM, I'd be in for a group buy... as I might need to do this again after 30 more track days
Old 03-16-2015, 11:41 PM   #195
juliog
juliog's Avatar
Drives: 86
Thanks a bunch @whataboutbob !
The Following User Says Thank You to juliog For This Useful Post:
Old 04-19-2015, 06:56 PM   #196
juliog
juliog's Avatar
Drives: 86
So I pull the injectors on the passenger side and find this:
One of the seals is completely gone! o.O
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 06:33 PM
Direct Injector Leaking Carwhisperer Issues | Warranty | Recalls / TSB 356 03-13-2020 12:35 PM
Direct Injector Failure Poll track_warrior Issues | Warranty | Recalls / TSB 553 01-12-2017 06:12 PM
Direct Injector's Leaking Carwhisperer Scion FR-S / Toyota 86 GT86 General Forum 1 05-11-2013 09:31 AM
