#183 |
Drives: 2014 SWP BRZ, MT
Where do people get the DI seals to replace? I'm inclined to try this myself. I haven't been able to find a part number for them.
The answer is racecar. Always.
#184 |
Drives: ft86
dealer
#185 |
Anyone have a part number or do I just have to ask the parts guy to look it up? Thanks
#186 |
Drives: 2013 Whiteout FR-S
SU003-00322
TEAM NEMESIS | NEM 86 | IG: @NEM_86 PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics The NEM86 Build Thread Last edited by pleong; 01-21-2015 at 04:21 PM. |
#187 |
Drives: 2015 Ultramarine FR-S MT
Installing seal onto the SST holder tip
First off, HUGE thanks @Dezoris for this video, not sure I would have tried it without seeing it. I replaced my seals about 2 weeks ago and my car has been running great since, no more firecrackers!! My #3(passenger side/rear) injector seal was gone and the other 3 were "burnt"/damaged... After fighting the seals onto the holder portion of the tool I came up with the following procedure to install them.
[ame]http://youtu.be/FLrM3X4WLCc[/ame] I used this procedure for the last 2 seals and it actually made the process of moving the ring over the seal to reset it much easier as well because it resulted in no deformation of the seal. Pic of the seal after using this procedure: Results.jpg All 4: As they came out.jpg #3: #3.jpg #1: #1.jpg Hope this makes the job a little less frustrating for everyone!! |
#188 | |
#189 |
#190 | |
Drives: 86
Does anyone have the all the part numbers for the DI seal replacement job? @Dezoris @whataboutbob
Want to make sure I don't leave any of these out: Quote:
#191 | |
I have the parts list from toyota in PDF if you want it.
#192 | |
AutoX-10/10ths every run
Here's the list of parts I used.
#193 | |
Drives: BRZ Limited 6MT, 02 AW, 03PSM WRX
http://www.autofactory.jp/product/to...=s&pm=t&seq=34 |
#194 |
Drives: 86
Those are expensive ($50 per set, you want 3-4 sets per install as they are scratched easily), ordering would be a hassle, shipping would take too long, and I'm not sure they're proven.
If they are proven to last longer than OEM, I'd be in for a group buy... as I might need to do this again after 30 more track days
#195 |
Drives: 86
Thanks a bunch @whataboutbob !
#196 |
Drives: 86
So I pull the injectors on the passenger side and find this:
![]() One of the seals is completely gone! o.O |
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
| Injector / seal failure or Miss-fire codes.. please post here | mad_sb | Engine, Exhaust, Transmission | 378 | 04-24-2020 06:33 PM |
| Direct Injector Leaking | Carwhisperer | Issues | Warranty | Recalls / TSB | 356 | 03-13-2020 12:35 PM |
| Direct Injector Failure Poll | track_warrior | Issues | Warranty | Recalls / TSB | 553 | 01-12-2017 06:12 PM |
| Direct Injector's Leaking | Carwhisperer | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 05-11-2013 09:31 AM |
