Old 04-23-2014, 03:10 PM   #99
JarredH
JarredH's Avatar
Drives: Scion frs
Originally Posted by cjsporl1996 View Post
Question: did you need to lug nuts and extended studs?
Nope! Used a simple set of 35 tuner lugs and they fit perfectly
JarredH is offline   Reply With Quote
Old 05-07-2014, 08:00 PM   #100
JarredH
JarredH's Avatar
Drives: Scion frs
coils installed, 2 inch drop
Old 05-08-2014, 06:59 PM   #101
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Merged @JarredH's topic = same wheel w/ same spec
Old 01-29-2015, 01:40 AM   #102
Docmattic
Drives: GT 86
Hey Guys,
I'm looking at getting some hyperblack 18/9.5 + 35 Rota Torque wheels.
Are these suitable to pop on the 86 without any mods or fender rolling?
Also, would 225/45/18 Michelin tyres fit on these rims? I already have these so it would be nice not to have to throw them away.
And, in what way would these changes to the wheels affect the speedometer? If it does affect the cars current settings, are wheel shops able to reconfigure?
Sorry if these questions seem dumb i'm quite new to buying wheels and none of the suppliers around town have rota wheels.
Docmattic is offline   Reply With Quote
Old 03-01-2015, 10:19 PM   #103
Sugi
Sugi's Avatar
Drives: 2015 FR-S - Halo
Do you have rubbing issues? Do you have an alignment done in front and rear?
Sugi is offline   Reply With Quote
Old 03-02-2015, 05:10 PM   #104
JarredH
JarredH's Avatar
Drives: Scion frs
Full alignment done. zero caster and toe. camber is -2 rear and -1 for the front. Fenders aren't rolled.
In this picture, I am running 235/40/18 front and 245/40 rear. I rub all the time on cornering and im 2" lowered on bc coils. If you want to not rub, and have perfect fitment, use 225/40/18 front and 235/40/18 rear (for stance/stretch) or 245/35/18 (for a meatier tire for power and optimized handling. Im picking up a set of 245/18 pilot super sports, finally out of the stance game? lol It all depends really what suspension you are running. Are you planning on slamming your frs with coils? or stock suspension? or 1 inch springs? etc... what are you planning on doing with your frs. daily driver, track, stance game etc...
When I plasti dipped my wheels orange.
Old 03-02-2015, 05:43 PM   #105
Sugi
Sugi's Avatar
Thanks for the reply. I'm running Tein street flex coils and want to go as low as I can without rubbing. I use my car as a DD so I drive her to hard, but like to take corners from time to time. I'm worried that these rims poke to much and if I hit a pot hole that they will damage my car or suspension. If I do keep the rims, I might run 245/35/18. I too am going to plasti dip the rims grey or black. I bought them of a fellow member and the original color is white.
Old 03-03-2015, 09:13 AM   #106
JarredH
JarredH's Avatar
Drives: Scion frs
I'd suggest 225/40/18s if you want to stretch and go low with average cornering ability, if you are running forced induction and still want a bit of stretch, I recommend 235/35s. If you want to drop it fully, go with a stretched set for sure, 245/35s will rub if slammed, 225/40s and 235/35s should be fine with slamming your car. As for damaging your car, Ive never had a problem with these wheels and its been a year. I live in Ontario, Canada where the roads are absolutely brutal, pot holes, man holes, cracks, rocks, lets just say they don't call ontario, "onterrible" for no reason lol. back on track, i know someone with these wheels with exact specs on his frs, 225/40/18x9.5 squared, and he is slammed on BC coils, he doesnt rub at all. So ideally 225/40/18 on a 18x9.5 +35 wheel with no spacers is perfect for slamming, is decent for cornering, and good for dding.
Old 03-16-2015, 05:32 AM   #107
thien
Drives: Scion FRS
Will 18x9.5et+35 wrapped with 245/35/18 square rub if I'm lowered on h&r sport springs? I'm new to this but everyone seems to be running coils. Are springs going to clear? The spring should be 1" in front and 1.2" rear. What are the benefits of running coils? Thanks in advance and sorry if these are dumb questions. Lol
thien is offline   Reply With Quote
Old 03-22-2015, 01:08 AM   #108
Sugi
Sugi's Avatar
No dumb questions here. Running springs should be good and I believe you will not rub. Most people go with coils over springs for the adjustment ability. I personally went with Tein street flex coils because I use my car as a DD (daily driver) but wanted an all in one system. It really self preference on if you go coils or springs. I've read pros and cons on both sides.
Old 04-27-2015, 08:25 PM   #109
JarredH
JarredH's Avatar
Drives: Scion frs
hopefully this is not too late, but you will rub because you dont have any camber adjustability. If I were you, I would go 225/40 front & 235/40 rear. You will not rub, I am positive about that. I am running BC racing coils, and I have my dampening (stiff/softness) set to the softest ride quality. I absolutely love my coilovers. I personally would just save up and wait for the coilovers, you will end up wanting to find the perfect wheel gap, ride comfortability, for fuction or form, etc... Everyone I know on springs, ends up selling them and buys coilovers. Where they could have save more money by just going straight for coilovers.
Old 05-12-2015, 05:05 PM   #110
thien
Drives: Scion FRS
Thank you so much! It wasn't too late haha. I will look into getting coils..hmm.....
Old 06-04-2015, 09:31 PM   #111
thien
Drives: Scion FRS
I ended up going 215 in front and 235 in the back
Sent from my SM-G920T using Tapatalk
Old 06-06-2015, 09:15 PM   #112
DCStorm
DCStorm's Avatar
Drives: 2013 FR-S (RIP), 2017 Toyota 86
Post up some pics!
DCStorm is offline   Reply With Quote
Wheel Directory: Rota Grid 18x9.5 +38 Sandman3zb Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 67 06-20-2017 01:41 AM
The FRS torque curve smbrm Scion FR-S / Toyota 86 GT86 General Forum 29 06-30-2016 04:10 PM
Wheel Directory: Rota Torque 17x9.0 +30 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 113 09-09-2013 10:19 PM
It has more power, but less torque. white_knight Scion FR-S / Toyota 86 GT86 General Forum 9 08-09-2012 01:46 AM
Torque App ZetaVI Other Vehicles & General Automotive Discussions 4 12-02-2011 12:22 AM
