Old 11-30-2014, 07:39 PM   #659
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Originally Posted by texasbound972 View Post
Anyone use the ethanol gauge? Mine doesn't work. Figure it would with the delicious tuning flex fuel kit.
you mean you changed the fuel type in torque to E85?
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 11-30-2014, 09:54 PM   #660
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
I did.
texasbound972 is offline   Reply With Quote
Old 12-11-2014, 10:03 AM   #661
zoth
zoth's Avatar
I did.
Check with your to tuner, turned of.
Sent from my SM-N900T using Tapatalk
Old 12-13-2014, 12:41 PM   #662
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Nevermind fixed my problem
BRZZZZZZZZZZ is offline   Reply With Quote
Old 02-22-2015, 06:57 PM   #663
Kostamojen
I'm trying to upload a video from Track Recorder, but for some reason now my TorqueSync isn't uploading the RECENT videos its only showing old ones that were already encoded...
Anyone know whats wrong, or know where I can check for more info? Can't find a good resource for Track Recorder issues.
Old 03-16-2015, 02:10 AM   #664
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Do you guys think the boost reading would be correct even if I swapped the OEM MAP sensor (which I believe is Denso 2 bar) for an aftermarket kraftwerks 4-bar MAP sensor?
mit_peid is offline   Reply With Quote
Old 03-16-2015, 03:33 AM   #665
Kodename47
Kodename47's Avatar
Drives: UK GT86
If it's setup in the ROM correctly then it'll display correctly.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-16-2015, 09:17 AM   #666
mit_peid
Boosted Noob
mit_peid's Avatar
How can one tell if it is set up in the ROM correctly?
Old 03-16-2015, 02:04 PM   #667
Kodename47
Kodename47's Avatar
Drives: UK GT86
Ask your tuner.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-04-2015, 11:26 PM   #668
lxsedan
Drives: 2013 BRZ SWP
anyway to get the layout to fit a phone easily. Looks like it was laid out for tablet and when loaded on phone its much too big and doesn't fit screen.
lxsedan is offline   Reply With Quote
Old 04-07-2015, 08:22 AM   #669
TheVelourFog
Drives: 2015 BRZ
Are there any oil pressure sensors that can be used with Torque or do oil pressure sensors only hook up to physical gauges?
TheVelourFog is offline   Reply With Quote
Old 04-07-2015, 09:28 AM   #670
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
Which layout are you talking about - the general Realtime Gauge display? It should automatically scale to fit your screen. The layout looks the same on all my Android devices, from the 3.7" display on a Nexus One to the 7" display on a Nexus 7, just scaled larger or smaller to make things fit.
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
Old 04-07-2015, 09:32 AM   #671
codesplice
codesplice's Avatar
Not that I know of. The sensor would have to integrate with the rest of the OBD bus in the car, which isn't really going to happen unless it's something the system is already configured for. I think you're stuck with a physical gauge for anything practical.
Though it would be pretty awesome if someone could pull that off!
G+
The Following User Says Thank You to codesplice For This Useful Post:
Astroboy (04-07-2015)
Old 04-15-2015, 03:00 PM   #672
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Originally Posted by Synack View Post
I hope this gets updated in the OP because every time I wipe my phone or get a new phone I have to constantly re-figure out how to enable Fahrenheit in Torque for Oil Temperature.
Here is the real equation for the Oil Temp PID in Torque.
((AC-40)*1.8)+32
After that, go to Unit settings and enable Fahrenheit (or disable Celcius, whichever it is).
I tried it last night and I was hovering around 210-225 degrees on my turbo kit with casual driving. (no cooling mods)
Please please please add this to the original post in this thread so nobody has to dig and search deep for days just to convert to Fahrenheit like I did.
Quick update, I tried this formula and the readings were off since I read my temps in F. Removed everything besides "AC-40" and all worked once the car was turned on. Also set the last parameter to "auto"
.ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
