Old 02-03-2015, 08:21 PM   #1
RickyBobby
Drives: 2013 Firestorm FR-S AT
Exhaust Tips for 2013/2014 Stock Exhaust Pipes
Due to the exhaust pipe diameter, 2 1/8", there's not a lot of choices for upgrading the puny 2013/2014 stock exhaust tips.
From cheap to expensive there's the Chinese made DC Sport tips that can be found at various auto part stores. There's also a black version of these.
EX-1010, 3.75" outer diameter
I purchased a pair of these for <$30. with a coupon code. Find coupon codes for Advance Auto here: http://www.retailmenot.com/view/advanceautoparts.com Order online, pickup at store. They are 9" long and I found that for me they stuck out too far. When I tried to push them back an inch or two I could not get them centered with the 3 bolts. Sold them on Craig's list for $30. If you don't mind them sticking out a few inches from the bumper then get them. Construction is not bad and they have a resonator which I don't know if it changes the exhaust sound or not since I never installed them. Maybe someone here that has them can answer that.
http://shop.advanceautoparts.com/p/d...rt+exhaust+tip
For a few bucks more there's the slightly larger outer diameter, 3.875", EX-1013.
Specs:
EX-1011
Description:
• DC SPORT SS BOLT-ON TIP
• UPC: 757558509010
• Weight: 1.8 lbs
• Dimension: 9"(H) x 3.9"(W) x 3.9"(L)
• Inlet: 2.875 inch
• Outlet: 3.75 inch
• Length: 9 inch
• Fits: 1.75 inch - 2.5 inch
• Resonated: Yes
• Cut: Straight
Product Features:
• Resonated Bolt on Tip
• Resonated tips are to enhance sound output
• 100 % Stainless Steel Mirror like Polish Finish
• Increase Horsepower
• 3 Bolt Clamp System
EX-1013
Description:
• UPC: 757558509034
• Weight: 1.55 lbs
• Dimension: 9"(H) x 4"(W) x 4"(L)
• Inlet: 2.875 inch
• Outlet: 3.875 inch
• Length: 9 inch
• Resonated: Yes
• Cut: Slant
Product Features:
• Slanted Tip Shape
Next cheapest, and these are the ones I currently have, are the 2015 OEM exhaust tips, part #SU003-05273. They have a 4 1/4" outside diameter, are 5" long, secure to the tail pipe with 1 recessed bolt, and do not stick out beyond the bumper. Before ordering these I checked with a local Scion dealer who had a few 2015 FR-S in stock to make sure that they would fit my 2013. They do.
I purchased mine for $62.69 each + shipping from here: http://toyotaparts.bochtoyotasouth.c...ota/su00305273
I also ordered the sliding OEM arm rest, part #PT478-18130, from them for $156.80. Shipping for all parts was $17.40 UPS ground. Even with the snow in MA it only took 4 days for delivery.
The tips don't come with bolts, for the price they should. Luckily the bolts on my stock tips were in good shape and fit the new tips. I coated them with high temp silicon grease before installation. I have no plans to change out the stock exhaust.
Pics at end of post.
Only slightly more expensive than the 2015 OEM tips in total price are the JDM tips. Cheapest price I have found, so far, is $146./pair shipped on eBay. These look almost identical to the 2015 FR-S tips but are 8" long, so they are going to stick out a bit. Price would be decent if shipping was not so high. Is there a customs charge on these too??
Pics for comparison: http://www.ebay.com/itm/TOYOTA-86-Ge...97b62d&vxp=mtr
Most expensive are the Perrin tips. From Perrin: $196. + $16.48 standard post or $22.39 UPS ground shipping. http://perrinperformance.com/i-13324...-fr-s-brz.html
From FT-86 Speed Factory: $176.40 + $17.49 UPS ground shipping to TN.
http://www.ft86speedfactory.com/perr...d6f7c007edf145
From pics construction looks very good, 4" outer diameter, 6.25" long, and a 5 year warranty. It uses a clamp to attach it to the exhaust pipe, to those who have these, is the clamp visible from the back?
If you know of any other tips that will work with the stock exhaust pipes please post them.
Old 2013 OEM tips vs new 2015 OEM tips
Name:  Old vs new tips.1.JPG
Name:  Old vs new tips.2.JPG
Name:  Old vs new tips.3.JPG
Name:  New tips looking down.JPG
Name:  Old vs new tips.4.JPG
Name:  New OEM tips.JPG
RickyBobby is offline   Reply With Quote
Old 02-03-2015, 11:48 PM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
These exhaust tips should of came on the 2013 models.
N1rve
Old 02-04-2015, 12:25 AM   #3
kowasu.mono
kowasu.mono's Avatar
Drives: 2013 Subaru BRZ Limited (GBS)
Still waiting for D-shaped TRD-like exhaust tips. haha.
kowasu.mono is offline   Reply With Quote
Old 02-04-2015, 02:03 AM   #4
scarfo
Drives: gts 86
The funny thing is, in Australia you can't give away your stock Cat back which comes with the larger tips.
scarfo is offline   Reply With Quote
Old 03-15-2015, 03:33 AM   #5
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
I have a 2015 FRS but those pics you posted don't look the the 2015 OEM tips that I have.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 03-17-2015, 06:14 AM   #6
RickyBobby
They are the 2015 OEM FR-S exhaust tips, part number SU003-05273. From Scion's site: http://www.scion.com/cars/FR-S2015/g...ge=dualExhaust And here: http://www.ft86club.com/forums/showthread.php?t=80431
Post rear pics of your car.
More 2015 FR-S pics:
The Following User Says Thank You to RickyBobby For This Useful Post:
86geek (03-17-2015)
Old 03-17-2015, 12:37 PM   #7
86geek
86geek's Avatar
still looks tiny so i ordered new exhaust tips from amazon....the DC Sports one....thanks for posting 2015 pics.
Old 03-17-2017, 06:17 PM   #8
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
@RickyBobby did the 2015+ exhaust tip screw holes line up with the existing dimples which the bolts press against on your stock exhaust? I have JDM tips and from what I remember when I feed the bolts through to tighten down they don't exactly line up against the USDM dimples.
Old 02-01-2023, 06:57 AM   #9
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Reported
Old 02-06-2023, 11:29 AM   #10
Walkerkelet
Drives: Toyota Corolla
Which other goods you at the moment?
Walkerkelet is offline   Reply With Quote
ΘΘΘ Tomei Titanium Exhaust Systems ΘΘΘ Cat Backs, Front Pipes, Over Pipes and Headers FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 291 02-16-2017 10:37 PM
DC sport exhaust tips & Stock exhaust missbrz Engine, Exhaust, Bolt-Ons 1 01-10-2015 02:42 PM
Stock exhaust tips: bolt-on or welded? Fast_Freddy Engine, Exhaust, Transmission 3 06-13-2013 05:34 PM
***INVIDIA CATLESS AND CATTED FRONT PIPES IN STOCK! EXHAUST COMBO AVAILABLE*** genometuning Engine, Exhaust, Bolt-Ons 63 03-13-2013 12:48 AM
Wtb stock Exhaust tips oscarsturu Australia Classifieds 4 10-20-2012 11:44 AM
