Old 02-19-2015, 12:36 PM   #15
Shit Luck
Drives: red frs
ready to sell my boosted fa20 11k on the motor and 1k boosted with jdl stuff.
I see a 1uz in my future.
Shit Luck is offline   Reply With Quote
Old 02-19-2015, 02:50 PM   #16
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I love the 1UZ, and it sounds amazing. @Manji - do you have any other details on your build? What transmission are you going with?
I've considered putting one of these in my IS since it bolts right in using GS400 mounts. I wouldn't mind having two cars powered by the same engine
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 02-19-2015, 03:12 PM   #17
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
You can use whichever box you like really. W series, R series, V series. Few guys make the setups (bell/fly/clutch) to do so. This guy here is good. http://convertmotorsport.co.nz/ He does kits for all the above boxes to UZ. He might also do a tremec setup. If he doesn't SURFAB does. I almost went that way but got a good deal on a new r154.
Manji is offline   Reply With Quote
The Following User Says Thank You to Manji For This Useful Post:
civicdrivr (02-19-2015)
Old 02-19-2015, 03:53 PM   #18
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Awesome, thanks. Those headers look amazing btw.
What engine management are you running?
Parting out HERE
Old 02-20-2015, 09:07 PM   #19
aagun
Drives: 86
Originally Posted by Manji View Post
I keep seeing 2jz swaps coming up on my news feed, and don't get me wrong I think that's great, but really surprised more aren't going 1uz TT.
2jz's come with a manual box, and factory turbo, 1uz's don't have either. But the aftermarket has shown these to not be issues.
You can buy bellhousing conversion kits to bolt the good toyota manual boxes to a 1uz.
The early generation 1uz's (non vvti) have proven time and time again to reliably take 600hp+ unopened, twice that if built.
1uz pros over 2jz
1000cc more displacement
75kg lighter
Cheaper
Shorter
Depending on your plans with the 1uz, governs which gen you buy. The early gen model (non vvti) have a stronger bottom end. If you don't want to build them, and just use stock motors, get an early gen.
If you're going to build it, get the vvti model. It has a far better head, but the rods are weaker.
So, why don't more people put 1uz's and twin turbo them, compared with 2j swaps, in other platforms? The 1uz is a big bitch. But again, remember it's quite a bit lighter than a 2jz. It's because there isn't the room. A lot of cars barely have room the 1uz itself, and need horrible "block hugger" headers to fit in, certainly not enough room for turbos.
BUT, the beauty of the gt86 is that it has a boxer. So the engine bay is very wide. Easily wide enough for a 1uz and a gtx28 or gtx30 either side of it.
1uz turbo setups are becoming more and more popular in the drift scene over here. Because of the reasons above, strong but still cheap. But the ones I've seen are in silvias, and because their bay isn't wide enough for TT, they have to do this ugly 8 into 1 setup with the turbo forward of the motor.
Here's a front on shot of my car. Look at the room we had for the headers. Easily enough room for a pair of snails.
Someone do it!
did u use custom drive shaft ??
and what about radiator and oil filter??
is 3uz better option then 1uz ? not only the torque
i am planning v8 Toyota if it easy swapping with less cost
aagun is offline   Reply With Quote
Old 02-20-2015, 10:54 PM   #20
inertia
inertia's Avatar
Wouldn't it be more expensive to go the route of a 1UZ vs. 2J? Just saying.
inertia is offline   Reply With Quote
Old 03-12-2015, 10:35 PM   #21
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
1UZ's can be had DIRT cheap in comparison to 2JZ's... $500 or less for a motor...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 03-12-2015, 11:40 PM   #22
inertia
inertia's Avatar
What about the mount kit, custom drive shaft, trans, wiring harness, etc..
Old 03-13-2015, 07:33 AM   #23
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Motor swaps for cheap on this platform isn't available for the average person yet. Period.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
The Following 2 Users Say Thank You to slicktop For This Useful Post:
civicdrivr (03-15-2015), MokSpeed (03-13-2015)
Old 03-13-2015, 08:14 AM   #24
AJPG
Drives: 22RE, FA20, 4G63
Originally Posted by MokSpeed View Post
This.
I wouldn't even contemplate it until my motors sees close to fill up the catch can
Fix.
AJPG is offline   Reply With Quote
Old 03-13-2015, 12:03 PM   #25
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
man, and I was just gonna swap motors after work today too
The Following User Says Thank You to continuecrushing For This Useful Post:
Koa (03-14-2015)
Old 03-14-2015, 04:32 PM   #26
Koa
Sweeper
Koa's Avatar
shutter but I thought we were gon put in the 2jayz in ur rig after tea easy peasy
The Following User Says Thank You to Koa For This Useful Post:
continuecrushing (03-15-2015)
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
LED swap Skorov AUSTRALIA 28 09-23-2014 09:46 PM
BRZ Swap!!!! EnviedIke Engine Swaps 59 07-30-2014 06:32 PM
Looking for an STi Swap Doug@WGP NY / NJ / CT / PA 31 11-27-2012 12:54 AM
2UR-GSE Swap czar07 Engine Swaps 9 08-29-2012 01:43 PM
