Old 03-13-2015, 07:40 PM   #155
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
I let it seep until it was just barely coming out, and then buttoned it up. Car was absolutely level. I even double checked with a level on the door sill and pinch seam to make sure since I was getting nervous.
I never could feel it with my finger at all...which is what was making me nervous. Still not totally comfortable with it, but if it was still seeping out after cleaning the hole and threads with a rag...it had to have been full.
Working on diff now...
Apex_BRZ is offline   Reply With Quote
Old 03-13-2015, 08:17 PM   #156
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I wouldn't sweat it...if it was level, you put in at least 2.2L and fluid started to come out, it had to have been full.
Old 03-13-2015, 08:46 PM   #157
Apex_BRZ
I appreciate the feedback.
Rear diff went without a hitch. Almost exactly 1.1qts. Good to go.
Old 03-14-2015, 03:54 PM   #158
Apex_BRZ
Transmission is in bad shape. Either there is definitely somehow NOT enough fluid, or the car absolutely hates AMSOIL Manual Transmission and Transaxle Gear Lube.
Car is notchy in ever gear, slightly grinds 5th when I put it in, and I can slightly hear the trans whining when driving. It's never been like this. I don't know how in the world it couldn't have enough fluid, but something isn't right. I have .15qts left of the fluid, which I doubt will do any good.
Am I able to mix the trans fluid and AMSOIL Sever Gear fluid I put in the rear diff? I have plenty of that left.
Thoughts?
Old 03-14-2015, 07:55 PM   #159
Do not drive it. 100% do-over. Are you certain the car was level in roll as well as pitch?
Thoughts?
No. GL-5 is ok to use in non-synchromesh transmissions containing only steel components (racing, sequential transmissions) but the high-pressure additives will actually accelerate wear of synchros.
Old 03-14-2015, 08:55 PM   #160
JB86'd
JB86'd's Avatar
Drives: JAWS
Thoughts?
Drain that fluid,get some Motul 300, add 2.3 qts., call it a day.
JB86'd is offline   Reply With Quote
Old 03-14-2015, 09:24 PM   #161
CoupedUpSubie
Drives: 2013 BRZ Limited
I've had zero issues with Amsoil. I would highly recommend redoing the gear oil change. If you do go with amsoil again then I recommend getting the little pump made for gallon jugs of oil, it fits on amsoil quarts and can be found at NAPA and advance auto parts.
When you do drain it be sure to do so into an empty container the measure how much came out. That is the best way to see how much you had in there. Too much is just as bad as not enough.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 03-15-2015, 08:38 AM   #162
Apex_BRZ
I used a pump that I bought online that was suppose to fit any standard 1qt size container. The AMSOIL containers aren't standard size. In the end, I just transferred the fluid to another bottle and used that, which worked perfectly fine.
Car was absolutely level. Maybe I'll try the Motul. All gears are shifting fine now, but it still grinds going into 5th...which it never did before. So odd...
Old 03-15-2015, 11:47 AM   #163
CoupedUpSubie
Amsoil containers use the same openings as most gallon jugs of oil.
It's good to hear that its starting to feel better, I haven't driven my car much lately due to work and all the snow banks blocking my view getting out of the house. It has been over 10k miles since I put Amsoil in. I may do another change here pretty quick to see how things look.
Old 03-29-2015, 07:44 PM   #164
tazz786
Drives: 2015 scion FR-S
isnt this covered by the warranty? im having the same issue on my new 2015 with only 3000 miles
tazz786 is offline   Reply With Quote
Old 03-30-2015, 02:02 PM   #165
continuecrushing
grinding? Potentially.
Unless your trans REALLY grinds, I would try swapping fluid first before trying to convince the dealer they need to replace.
What issue are you experiencing?
Old 03-30-2015, 08:39 PM   #166
tazz786
whenever i make a left turn, and this is only when i start up the car, i feel a grinding/vibration/catching in the rear left wheel. After i turn it the first time it goes away after that until another cold start.
and i meant changing the differential fluid because thats what it seems like it is, if it fluid needs to be changed would the dealer cover that? or would i have to buy my own? its just a matter of saving 80 bucks.
Old 03-30-2015, 10:30 PM   #167
That's the Torsen mechanism locking down the diff. You can prove it for yourself. Tomorrow morning set yourself up so you can coast through the same corner. Zero grab.
Works as designed because racecar.
Old 03-30-2015, 11:20 PM   #168
tazz786
so the slight vibration is normal? i dont use my car for the track just a daily driver..i feel it when im pulling my car out of the driveway
differential, diy, fluid, transmission
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 02:23 PM
What Differential fluid is in your BRZ/FRS? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-12-2012 08:57 PM
Anyone change transmission lube yet? BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 08-21-2012 05:47 AM
FR-S quick reference and warranty / maintenance guide is up pkny Scion FR-S / Toyota 86 GT86 General Forum 15 06-20-2012 11:33 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
