CANADA Canada
Old 03-13-2015, 02:34 PM   #1
Skegrider
Skegrider's Avatar
Drives: 2015 BRZ Sport Tech 6 spd
STI BRZ Springs
I know these are pricey. Seems around the $599 mark for a set of four. I have done some reading on lowering. I was not planning on doing this, as a full 1" drop might be too low for the roads around me. But a 15mm drop, that still has similar stock ride qualities would be great! I will be running a set of 18 X 8 35mm offset wheel's with 235/40 R18 tires. Will these still fit with a 15mm drop? And where can I purchase these STI springs from? Anywhere in Canada? Thanks.
Skegrider is offline   Reply With Quote
Old 03-13-2015, 03:10 PM   #2
gramicci101
Off Topic
There are other springs that are just as good for less money. STi charges more for the name. Look into Swift and RaceComp Engineering springs in the suspension section.
For the wheels, check the stickies in the wheel section for a fitment guide. I'm pretty sure yours will still fit with a very minor drop, but I'm not the expert.
Old 03-13-2015, 03:45 PM   #3
Skegrider
Skegrider's Avatar
Ic. I will look into the Yellow springs more. Thanks.
Old 03-13-2015, 04:00 PM   #4
Annahra
Annahra's Avatar
Drives: 2014 WRB BRZ LTD
I did the RCE yellows on my car because they work well with stock suspension and are very close to the drop with STI pinks. I'm super happy with it so far!
Annahra is offline   Reply With Quote
Old 03-13-2015, 04:12 PM   #5
wbradley
Sarcastic SOB
wbradley's Avatar
RCE springs + Pink spray paint = profit
The Following 3 Users Say Thank You to wbradley For This Useful Post:
Bergen23 (03-13-2015), Shedd22 (04-02-2015), wparsons (03-13-2015)
Old 03-13-2015, 05:19 PM   #6
wparsons
wparsons's Avatar
There's a place in BC that carries RCE springs as well.
http://www.dalesmotorsport.com/
flickr
Old 03-13-2015, 06:24 PM   #7
DimSumHero
DimSumHero's Avatar
Drives: 2015 Scion FR-S Halo
TRD Springs are cheap I knew quite a few guys in Calgary running them
DimSumHero is offline   Reply With Quote
Old 03-13-2015, 07:05 PM   #8
Skegrider
Skegrider's Avatar
I viewed these online at $949.00? Is this the right price? I will check out the place in B.C. Thanks!
Old 03-13-2015, 09:17 PM   #9
TRD springs should cost you no more then $300!
Old 03-14-2015, 12:22 AM   #10
Skegrider
Skegrider's Avatar
Thanks for the info guys. I emailed the supplier in BC. around 4:00. Waiting for a response. If anyone can confirm the RCE yellow springs will work with my above mentioned tire/wheel combo as well a 2015 BRZ, I will order a set. Haven't been able to confirm they fit a 2015. I assume they would. 20mm drop will remove the wheel gap nicely.
Old 03-14-2015, 07:00 PM   #11
wparsons
wparsons's Avatar
Springs are unchanged for 2015, so RCE yellows (or any other aftermarket) will fit perfectly.
flickr
Old 03-15-2015, 10:13 PM   #12
Skegrider
Skegrider's Avatar
Any other Canadian suppliers of RCE BRZ 20mm drop yellow springs? Been searching for a while with no luck.
Old 03-16-2015, 01:47 PM   #13
wparsons
wparsons's Avatar
They're the only ones I found back when I was looking. I ended up going with Swift springs because I could get them locally and save on shipping costs.
flickr
Old 03-16-2015, 02:14 PM   #14
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Just go with FT86 Speed factory, shipping ain't that bad and it's Canada Post also
EDIT: Also paid no duties
drewbot is offline   Reply With Quote
WTB: RCE yellow springs or eibach prokit lower springs fr/brz Gt86-turbo Want-To-Buy Requests 0 03-08-2015 04:18 PM
OEM BRZ Springs TilesMeague Brakes, Suspension, Chassis 1 01-20-2015 02:46 PM
AEM ET CAI and OEM Springs( VA) Nickd123 Engine, Exhaust, Bolt-Ons 2 12-06-2014 04:23 PM
Swift Sport springs/or any springs.. regrets ? rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-21-2014 10:10 PM
Which of the three springs? the Red Devil Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-19-2013 05:31 PM
