Old 03-12-2015, 06:39 PM   #29
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
If going with the Jackson racing kit what other additions should I get to the package... I'm going to get an oil cooler what else would you recommend ?? I have an AT
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 03-12-2015, 06:45 PM   #30
CSG David
CSG David's Avatar
If you track, autocross, or see yourself doing elevated runs even on windy roads, that oil cooler is going to keep your engine oil temps and performance consistent. You don't really need an AT oil cooler unless you are shifting a lot. Other than that, no other required modifications are necessary. The kit is a bolt-on, flash, and go.
If you do end up driving faster, you should consider brake pads and brake fluid as the next upgrade, but that's only because you're going to be dissipating more energy than before while slowing down.
Old 03-12-2015, 08:45 PM   #31
sprintamx
What are your power and daily drivability goals? Research whether you might need fuel injectors and a pump to handle increased flow on e85; research the value of installing a catless header; research installing an upgraded MAF and a wide-band o2 sensor for more precise tuning and power; research whether you'll want a flex fuel system if you plan to move between e85 and standard pump gas.
None of this stuff is necessary with the JRSC. As the CSG guys have said time and time again: install, flash and go really does work with this setup. The good thing is you can easily and happily use the well developed JR tune, or just as easily go with a 3rd party tuner like Delicious or Moto-East, etc. Personally, I opted for several upgrades and had Moto-East do the full install. Excellent work and tuning.
The point of all this is that the JR kit is very plug 'n play and a complete solution in its own right, but if you want to tweak, there's lot of easy options too.
Enjoy!
sprintamx is offline   Reply With Quote
The Following 2 Users Say Thank You to sprintamx For This Useful Post:
CSG Mike (03-12-2015), Jackson Racing (03-12-2015)
Old 03-13-2015, 08:12 AM   #32
ScionFR-S
ScionFR-S's Avatar
Exclamation
My goals are to add some more power to add to the fun of my daily driving. I don't autocross or go on windy roads as I live in NYC... I have installed hawk hps pads about four months ago and very happy with them. I will look into getting SS brake lines, Motul brake fluid, maybe new slotted and drilled rotors. I have already a catless open flash UEL header, Perrin overpipe, motiv hfc front pipe stock mid pipe and Greddy axleback exhaust. I will stay on 93 octane and not transfer over to e85 at all bc it's not available near me
Goals are to have a bad ass car that's fun and can beat most punks who want to see what this little car can do. ** I also have an AUTO FRS will that be a problem with this kit ?
Old 03-13-2015, 08:13 AM   #33
ScionFR-S
ScionFR-S's Avatar
I never go over 80-90 mph ... Very very rare that I do bc if I hit one pothole then im DONE haha I like to get my 0-60 time was down ... Acceleration is what I'm into
Old 03-13-2015, 09:50 AM   #34
D K
Stig's dark passenger
There is no downside besides costs - to running a 38 vs 30.
Bone stock engine, mild tune, 100% reliable so far at over 10 trackdays.
D K is offline   Reply With Quote
Old 03-13-2015, 10:02 AM   #35
enivid
enivid's Avatar
Drives: WRB JR BRZED
There seems to be a downside. A local tuner in my state did a c38 86 and called it "a bit laggy". A bit laggy for an extra 20hp? Pass.
enivid is offline   Reply With Quote
Old 03-13-2015, 11:43 AM   #36
D K
Not sure who your tuner is, but last time I checked on wikipedia, superchargers didnt have any lag.
You can run much lower boost for the same power.
D
Old 03-13-2015, 12:49 PM   #37
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Just as the title says any info is appreciated... I'm daily driving not tracking the car so I'm not looking to go above 300hp with a big blower. I'm asking more about the longevity of the kit and which one would be more suited to last a long time without prematurely blowing the engine. Obviously shit happens but wondering which is my best bet from your experience
I would also recommend you to search, search and search some more.. another good advice would be asking tuners and read owners' threads, this is a serious investment , FYI, this is a comparison thread posted by DriftOffice :
http://www.ft86club.com/forums/showthread.php?p=1624913
I've been using KW kit for track days (standard size SC and pulley) and can't be happier, although the differences are small, being able to drive the car if belt snaps, upgrade-ability, bigger Intercooler (results in lower IATs proven in the test) , and the customer service experience is just great.. oh almost forgot to mention, it was also cheaper when group buy was offered, and obviously there are a lot more KW owners, for the reasons I mentioned above, good luck
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
swarb (03-15-2015)
Old 03-13-2015, 01:22 PM   #38
sw20kosh
Drives: 2013 Black FR-S
Belts are not supposed to snap on a properly designed system. I haven't heard of any JRSC belts snapping. I have heard of more than a few KW belts snapping though...
The Following User Says Thank You to sw20kosh For This Useful Post:
ATL BRZ (03-15-2015)
Old 03-13-2015, 01:46 PM   #39
CSG David
CSG David's Avatar
If you're looking for some potent setup, SS lines and slotted/drilled rotors for the street don't do anything special. Based on those bolt-ons, you will need to have a tune done on your car. Most tuners here do Speed Density tunes. The tuning done on our car is a hybrid MAF/MAP setup.
Old 03-13-2015, 01:50 PM   #40
D K
Same here.
People keep talking about the hypothetic possibility of being stranded when the belt breaks.
Has any JR owner been stranded due to a belt snapping? Any other reason?
Hat about NA guys when their belt snaps?..?
Has that happened?
If your belt was to snap, I think you would have bigger fish to fry at that point.
We are prototyping the 38 for JR and I have to say its been dead nuts reliable.
And thats a pre production unit..
D
The Following User Says Thank You to D K For This Useful Post:
Old 03-13-2015, 02:00 PM   #41
wootwoot
Drives: FRS
Agreed. I have read of KW owners going through belts every 3k. I have also talked to others that never had an issues. But I have never heard of a JR belt snapping. Just saying... And KW also promised a CARB tune was going to happen literally years ago. That's what I was waiting for before I purchased. Had to move on. In my mind there is little to compare. One looks good, the other performs good. Take your pick.
The Following 2 Users Say Thank You to wootwoot For This Useful Post:
ATL BRZ (03-15-2015), sw20kosh (03-13-2015)
Old 03-13-2015, 02:29 PM   #42
D K
I dont want to throw anybody under the bus here because I belive both are good units.
But, when I spoke with Rotrex directly, they advised me to stay away from a cog belt.
They said DEFINITELY dont hit a had rev limiter with a cog belt.
That is my experience and YMMV
The Following 4 Users Say Thank You to D K For This Useful Post:
ATL BRZ (03-15-2015), CSG Mike (03-13-2015), The Racers Line (03-13-2015), wootwoot (03-13-2015)
Supercharger Comparison: Innovate, Jackson, Kraftwerks, Vortech *Updated March 9 2014 CSG Mike Forced Induction 281 02-25-2021 04:14 AM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Kraftwerks C38 Supercharger Kits with EcuTek - In Stock Super Sale!! rickspecd Forced Induction 10 01-03-2015 07:11 PM
Kraftwerks / Jackson Racing SC kits with Radium Dual Catch cans setup? OICU812 Forced Induction 7 10-14-2014 12:36 AM
