Old 03-12-2015, 08:41 PM   #1
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Who's tired of the "Pedal Dance" and wants to be in real control of their car?
So for those of us who track our car's a lot and start pushing the limits with tires and brakes have found out traction may be off on the dash but not inside the brains of the car holding you and your times back.
When Autocrossing who has hit the first turn to realize you forgot to turn the darn traction control off and have now just thrown away a very important run? I know I have....
Anyway this neat little box plugs into the ODBII port and disables the Traction/VSC completely. Leave it installed full time for the trailer queen race car, or plug in at the beginning of your fun filled day at the track or autocross.
The 86 Traction / VSC Eliminator for the Scion FR-S, Subaru BRZ, and Toyota GT86 is the perfect track accessory. This will fully disable traction and VSC without having to do the famous pedal dance.
This device AUTOMATICALLY places your vehicle into the famed "Pedal Dance" mode (without any dancing required). In this mode both Traction Control and Vehicle Stability Control are fully disabled.
The device plugs into the ODB II port.
To engage the vehicle needs to be stopped and the RPM at normal idle (not warming up) to dis-engage the VSC/TRAC.
When the ignition is off the device draws minimal power and can be left in place.
FT-86 SpeedFactory is offline
The Following 7 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
chas3wba0 (03-12-2015), DAEMANO (03-12-2015), fstlane (03-12-2015), ISDriven (03-24-2015), SeanRTR (03-13-2015), spdfreak (03-28-2015), swarb (03-12-2015)
Old 03-12-2015, 08:43 PM   #2
swarb
VICTORY! Can you unplug it afterwards and it will stay activated?
swarb is offline
The Following User Says Thank You to swarb For This Useful Post:
FT-86 SpeedFactory (03-12-2015)
Old 03-12-2015, 08:45 PM   #3
FT-86 SpeedFactory
Has to stay connected / plugged in to work.
Old 03-12-2015, 08:54 PM   #4
jvincent
jvincent's Avatar
Am I correct in assuming that when this is plugged in you lose the ability to datalog?
jvincent is offline
Old 03-12-2015, 08:56 PM   #5
TRD_Demon527
TRD_Demon527's Avatar
Drives: 2014 scion frs , 1987 toyota supra
what is the cost of this unit
TRD_Demon527 is offline
Old 03-12-2015, 09:03 PM   #6
chas3wba0
chas3wba0's Avatar
Drives: Yes
http://www.ft86speedfactory.com/mig-...ator-2007.html
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
chas3wba0 is offline
Old 03-12-2015, 09:07 PM   #7
TRD_Demon527
Not a bad price. I'll have to invest in this product for my first track day
Old 03-12-2015, 09:13 PM   #8
celica73
Meh. So much data acquisition is based on OBD input (see data log question above). If this had a pass-through I might jump on it. Even better if it allowed my OBD reader to be hooked up and was a right angle pass though (the BRZ OBD port isn't in a very good spot).
celica73 is offline
Old 03-12-2015, 09:26 PM   #9
FT-86 SpeedFactory
I agree data logging parameters is important but you shouldn't need that every single event/session especially when time matters.
All tuning and everything else should be long sorted out before your important runs or session is made.
Old 03-12-2015, 09:44 PM   #10
cjd
cjd's Avatar
Drives: 2017 BRZ
Uhhh, say what? So this isn't a useful tool unless you're already as good as you can get? I mean, I think it's pretty slick but that's a bit of a stretch.
I wonder of it could share the bus though... Y cable?
C
cjd is offline
Old 03-12-2015, 09:46 PM   #11
CSG Mike
CSG Mike's Avatar
The elimination of datalogging makes this completely useless to any serious trackday or autocross enthusiast...
Does it eliminate the e-diff and EBD as well?
CSG Mike is offline
The Following 12 Users Say Thank You to CSG Mike For This Useful Post:
BlaineWasHere (10-03-2015), Captain Snooze (03-14-2015), frssfo (04-06-2015), glamcem (03-13-2015), kster1 (03-12-2015), mkivsoopra (03-13-2015), Sleepless (03-13-2015), stugray (03-13-2015), tnle (03-14-2015), Valentino (03-25-2015), wparsons (03-13-2015), YouShallKnow (03-13-2015)
Old 03-12-2015, 09:46 PM   #12
CSG Mike
CSG Mike's Avatar
C
Most datalogging systems are not compatible with a Y splitter.
CSG Mike is offline
Old 03-12-2015, 09:54 PM   #13
cjd
cjd's Avatar
Drives: 2017 BRZ
Figured. I think just a bit more wait then... I still think the product is cool, just not for the serious enthusiast as you say...
cjd is offline
Old 03-13-2015, 09:55 AM   #14
D K
Stig's dark passenger
This should be able to be configured with a pass through function.
Can this be brought up with the manufacturer?
Furthermore, can this be built into the ecutek software?
D K is offline
The Following 2 Users Say Thank You to D K For This Useful Post:
CSG Mike (03-13-2015), raul (03-29-2015)
The "Pedal Dance" testing CSG Mike Tracking / Autocross / HPDE / Drifting 419 08-01-2023 10:46 PM
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open romin Engine, Exhaust, Transmission 468 11-26-2021 04:05 PM
Where to buy "heel/toe" shaped gas pedal? dookie11 Scion FR-S / Toyota 86 GT86 General Forum 56 01-22-2019 11:24 AM
Pedal Dance Device robot Tracking / Autocross / HPDE / Drifting 3 01-10-2014 09:26 AM
Additional "pedal dance" testing. CSG Mike Tracking / Autocross / HPDE / Drifting 55 08-27-2013 03:02 AM
