Old 01-26-2015, 04:37 PM   #43
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by jaorocks1 View Post
Basically got it down, also Prelude's have no blind spot lol, at least for me.
Lets be honest though, the poor vision in a Toyobaru while annoying also means that in a rollover the occupants won't be getting shorter, the Prelude (especially the ones I like [mk3], considering there wasn't a generation specified in the OP) might leave you a bit compressed.
Old 02-17-2015, 10:44 AM   #44
dustinkessler
dustinkessler's Avatar
Drives: 2013 WR Blue BRZ
I just sold my 5th gen Prelude...
I'll own another one in the next few years without a doubt.
dustinkessler is offline   Reply With Quote
Old 02-17-2015, 11:02 AM   #45
echo419
echo419's Avatar
Drives: 2014 BRZ Limited
Originally Posted by WazzuGrad View Post
You must be trolling.
No one actually comes on a FRS/BRZ forum and asks such a question seriously...
And in case you were not aware of this, the twins we not designed with high speed or drag times in mind.
Your comparing a FWD to a RWD.
/thread
neither were 4cycl FWD Hondas
Old 02-17-2015, 11:42 AM   #46
WazzuGrad
WazzuGrad's Avatar
Drives: 13 FRS (sold) 23 GR86
Fair point. What I meant is that majority of mini-vans nowadays will beat an 86 in a straight line, but its not what it was all designed for.
Out of the Honda brand, the S2k is the only fair comparison to the 86.
WazzuGrad is offline   Reply With Quote
Old 02-17-2015, 11:49 AM   #47
echo419
echo419's Avatar
I know what you mean. I was just making a dig at Hondas.
Old 03-05-2015, 11:44 AM   #48
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
FR-S/BRZ VS Prelude
The Twins are the better overall performance package, but the bias in this thread is ridiculous. People saying the Prelude "felt like it was going to fall apart"? Gee, I dunno, maybe you shouldn't compare a brand new car against a 15 year old car you drove 2-3rd hand after it was neglected by a previous owner.
I've already stated that the Twins are a better performance car, but I'll list a few things which are superior in the Prelude:
-reliability
-build quality
-engine in everyway (save fuel economy)
-suspension (double wishbone front & rear)
-Gear shifter (it's a honda nuff said)
The Prelude was, according to C&D, the best handling car one could buy for under $30k.
Unfortunately for the Prelude, it's 180 lb heavier than the Twins. And even worse, FWD.
And to whomever said VTEC is only good for fuel economic apparently doesn't know the first thing about Powertrain engineering.
Old 03-05-2015, 12:55 PM   #49
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
I'm going to chime in and say iVTEC, now is more geared to fuel economy compared to the VTEC YO! of yesteryear.
-Jack Burton
Old 03-05-2015, 01:21 PM   #50
WolfpackS2k
You're still oversimplifying. And the reason that happens is because not all VTEC is created equal
In the 90s when VTEC debuted it was employed on the NSX and Integra GS-R (XSi in Japan). What these two cars shared were engines with DOHC design. In those applications it was used to allow for extremely advanced cam timing at high rpms (by changing the cam profile itself with another set of oil pressure actuated lobes) that at low engine speed would be barely driveable. Not much later, VTEC started to show up on Civic and Accord engines (and later Acura engines). VTEC on these engines was tuned for fuel economy, as changes were limited due to the single cam design of these engines. It's easy to know which engines had this type of VTEC because they were all SOHC design. Of course, your average neanderthal Honda fanboi didn't know this and thus thought his Civic LX was awesome because it had VTEC
iVTEC developed this further by offering an continuously variable cam gear, which they called intelligent (hence the i).
Even this post of mine is oversimplifying things, but hopefully it gets the message across
Old 03-12-2015, 01:23 PM   #51
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Yeah, it's FWD but the Prelude's front suspension is superior to the twins so the front of the Prelude is better at doing work than the front of the twins and it should be too, after all, the front tires of the prelude have 2 jobs to do but still. The 92-96 Prelude is particularly brilliant in the handling department too.
Give them equal weight, equal tires and properly tuned suspension setups for their drive-train layouts along with some decent diffs and you'll be surprised how close the competition is, I guarantee it. In fact, for being both ~200BHP engines, the Prelude may have a power advantage on a long track due to fewer ponies lost in the drive-train.
But to say things like, "it's not even close" is myopic at best. It's definitely close.
PRO86 | WTCC | STL
The Following User Says Thank You to rice_classic For This Useful Post:
WolfpackS2k (03-16-2015)
Old 03-12-2015, 01:44 PM   #52
echo419
echo419's Avatar
you're forgetting one key factor in regards to the Prelude good sir....
Old 03-12-2015, 09:46 PM   #53
GTSRolla34
Drives: 2014 BRZ Limited - 1986 AE86
The overall specs on the '92-'96 prelude are pretty close to those of the twins as far as size, weight and wheelbase are concerned. My brother's '92 Si lude has an H23 Bluetop and that makes my BRZ look like it's moving in slow motion. The prelude handles very well too. It's a very stable platform. A very good comparison with the twins. Discounting them because they are front wheel drive is a bit much, and regardless of how old their engine technology is, they still have a relevant impact on honda tuning today.
Prelude (92-96)
Wheelbase 2,550 mm (100.4 in)
Length 4,440 mm (174.8 in)
Width 1,765 mm (69.5 in)
Height 1,290 mm (50.8 in)
Curb weight 1,288 kg (2,840 lb)
86/FRS/BRZ
Wheelbase 2,570 mm (101.2 in)
Length 4,240 mm (166.9 in)
4,234 mm (166.7 in) (Subaru BRZ)
Width 1,775 mm (69.9 in)
Height 1,285 mm (50.6 in)
Curb weight 1,190–1,298 kg (2,624–2,862 lb) (Toyota 86)
1,251–1,273 kg (2,758–2,806 lb) (Scion FR-S)
2014 Subaru BRZ LTD - Dark Gray Metalic
1986 Toyota Corolla GTS - CA18DE Powered
http://club4ag.com/forums/viewtopic.php?f=7&t=1247
http://www.86garage.com/forums/viewt...hp?f=40&t=1459
GTSRolla34 is offline   Reply With Quote
Old 03-12-2015, 10:59 PM   #54
jaorocks1
jaorocks1's Avatar
Drives: 92 Prelude
Prelude (92-96)
86/FRS/BRZ
The 4th gen Prelude..... idk wth it is about this car that makes it so appealing for me. It looks plain, so inexpensive, oil leaks everywhere, the best part of having the car was that I didnt have to care about it all the time... I got my 92 Prelude for $2000 super fun toy just let your anger out lol no matter how you treat it it'll still be there waiting for you to do it again...
jaorocks1 is offline   Reply With Quote
Old 03-19-2015, 11:57 AM   #55
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
-reliability
-build quality
Reliability is good with the Prelude pre-100k miles. Beyond that, everything and I mean absolutely everything starts failing on them. My SO makes a living off of buying and selling these cars, parting them out, etc because of so many parts failures for the people who try and maintain them. Let us not even get in to the horrible automatic transmission issues. :/
Definitely not "reliable" in the long run. If you were an original owner and had one up through 100k miles then maybe I can see it. The current state of the cars now, there are other 20 year old cars which have lasted the test of time far better than Preludes. That is coming from an ex-prelude owner with a girlfriend who is addicted to them.
I can back up @rice_classic however. Performance out of them while they are running good is on par with the twins, which has 20 years of research and development on top of the Prelude. Once could say even better in straight lines with V-TEC.
BRZoomTX is offline   Reply With Quote
Old 03-19-2015, 12:19 PM   #56
rice_classic
A lot of the reliability is particular to the owners and the Vtec models are/were abused more.
I was the 3rd owner of a 1996 Si (non vtec 2.3L) and when I traded it in, it had 205k on it and I even put it on the track at 190k. I put 60k on it from when I bought it and the only thing I needed to do was the timing belt and water pump. The previous owner did the same with also a clutch. All electronics, A/C, sunroof, cruise.. all worked. Also mine was a 5sp for obvious reasons.
Now that's not to say I wasn't the exception that proves that rule but you are the first person who I've ever seen claim the preludes are garbage after 100k. But I've only owned one so I will just have to stroke my proverbial chin beard and say, "hmmm, that's interesting."
I think the 92-96 Vtec models probably have the performance advantage over the 97+ models.
PRO86 | WTCC | STL
R.I.P Prelude, hello FRS. (review) jaorocks1 Scion FR-S / Toyota 86 GT86 General Forum 49 08-12-2014 05:51 PM
SOLD! WHAT NOW?! PRELUDE/FRS eDmFrS Scion FR-S / Toyota 86 GT86 General Forum 19 03-21-2014 02:39 PM
Prelude at Thunderhill + Superlap Battle KCMachine Other Vehicles & General Automotive Discussions 7 12-02-2013 07:05 PM
BRZ vs. Prelude Si vs. S2000. . . Initial Thoughts iceman666 FR-S / BRZ vs.... 128 08-01-2013 05:54 PM
3rd Gen Honda Prelude Pics WheelFast Other Vehicles & General Automotive Discussions 11 04-05-2012 01:41 PM
