Old 03-11-2015, 01:31 PM   #43
BobbyBlue86
BobbyBlue86's Avatar
Drives: Subaru BRZ
Originally Posted by wheelhaus View Post
Geez man, a little harsh? Changing tire size most certainly is not "asking for bad tire wear" and does not require a new alignment. 235 are only 2.8% taller and 20mm wider. That translates to about 3/8" taller diameter (3/16" taller radius, this is what matters mechanically), and less than a half inch on each side. Hardly a huge change. The wheel and tire are still pointing in the exact same direction.
The wheel alignment isn't dependent upon tire size until you get to extremes, which doesn't apply here. The new wheel and tire are still pointing in the exact same direction. The alignment numbers he had/has shouldn't create ANY abnormal wear after only 500 miles. I am still betting on the tires being worn more than he believed at first, especially if his friend's WRX was running more camber.
edit- And where on earth did you read that he only installed two wheels and tires?
I also have tires/wheels from a friends WRX; 225/45/17 that are on my car now and are wearing perfectly, no alignment necessary. I even had 20mm and 25mm spacers installed for a while, again no alignment necessary. A Tire Rack tech I spoke to recently says 225/45/17 is actually a recommended size for the 86 in their vehicle info database.
I did only replace the ones up front. The older tires were put up front so i could watch how the tread reacted. The new tires will go on before the weekend.
The idea was that I didnt want to put brand new tires on there and have them go bald in a few thousand miles thus repeating the cycle.
BobbyBlue86 is offline   Reply With Quote
Old 03-11-2015, 02:34 PM   #44
wheelhaus
wheelhaus's Avatar
Well then I stand corrected. I thought you installed all four, then swapped them around after you noticed the inner shoulder wear.
Old 03-11-2015, 07:55 PM   #45
wparsons
wparsons's Avatar
Originally Posted by ashtray View Post
Stock tires for the twins are 215/45/17, so going to a 235/45/17 setup without changing alignment is asking for bad tire wear. Its both a taller and wider tire.
Tire size will not change the alignment... people need to look at things logically before just spreading info.
Alignments are done at the wheel, not the tire. Changing tire size has zero affect on the alignment.
The only thing relating tire size and alignment is the range of alignment specs you can run without rubbing.
flickr
Old 03-12-2015, 01:12 AM   #46
jessiej
Drives: scion fr-s
The same exact thing is happening to me and I have stock wheels/tires. :|
jessiej is offline   Reply With Quote
Old 03-12-2015, 10:06 AM   #47
stevesnj
stevesnj's Avatar
guessing on here doesn't help, just take it to the dealer they will find the cause. May cost a little but better than making changes you don't need.
My 2016 Build thread
Old 03-12-2015, 02:48 PM   #48
BobbyBlue86
Drives: Subaru BRZ
Well its really more about me trying to learn more of why its happening.
Old 03-12-2015, 04:45 PM   #49
stevesnj
stevesnj's Avatar
Okay, just saying that there have been a lot of opinions to try on here and none seem to come to fruition so maybe a mechanic or dealer needs to step in. Anxious to find out what the cause is.
Old 03-13-2015, 01:09 AM   #50
BobbyBlue86
Drives: Subaru BRZ
I hear ya man. I'm going to the dealership tomorrow to get a 2nd opinion.
Though, I really do think that my judgement was at fault when I initially put the tires on and I didn't notice the tires being worn out like that. Which kinda sucks because I got the tires from my friend thinking I wasn't going to have to pay to put new tires on mine. Lol
Old 03-13-2015, 01:19 AM   #51
swarb
Thumbs down
yes, 100000000% sure. I am a mechanic by trade and have a good amount of attention to detail.
Old 03-13-2015, 10:25 AM   #52
BobbyBlue86
Drives: Subaru BRZ
Originally Posted by swarb View Post
yeah yeah yeah.......... Lol
Code P0351 Trouble shooting? Bahraini86 Issues | Warranty | Recalls / TSB 46 09-10-2017 05:07 PM
Stock mats/carpets wearing quickly? Vic_RSA AFRICA 1 12-22-2013 03:06 PM
Carpet wearing off ironsurfer129 Scion FR-S / Toyota 86 GT86 General Forum 30 07-29-2013 04:02 PM
Mats wearing out Gp1666 AFRICA 85 02-20-2013 07:40 PM
trouble shooting tim saylor Other Vehicles & General Automotive Discussions 0 07-01-2012 02:04 PM
