#1835 | |
Drives: 2014 Scion FR-S
#1836 |
#1837 |
Drives: Toyota GT86
I finally got the time to do the latest firmware update and I'm kinda sorry I did. I don't really see any improvements - however, I now have a few issues I never had before:
- I have an usb drive with music that's always connected; since the firmware upgrade, the player randomly switches from radio to the usb music - sometimes two minutes after I start the car, sometimes 10 minutes, sometimes not at all; - wi-fi does not automatically connect to my phone; although I have the tethering turned on, I always need to turn it off and turn it back on for the dashlinq to pick it up; really annoying - not sure, but I have the feeling that the unit is a slower than before; it was always a bit laggy, it seems to have gotten worse. |
#1839 | |
Drives: GT 86
#1840 |
Drives: Mazda Miata
yep, since dashlinq kills all 3rd-party apps before sleep anyway, I see no point in using it :\.
I'm not sure that you can actually program Tasker to restart an app after dashlinq sleep, because I dont see a way to distinguish which apps were running before sleep. |
#1841 |
Drives: Mazda Miata
On unrelated subject:
I'm now working on an app, that would fine tune music volume in relation with car speed, and do it in a smart way. I saw such function in various stock head units, maybe gt86s have it too, I don't know. I found several similar apps on Play Market, but they all do not allow to manually change volume when they are running, volume just instantly jumps back to a programmed value. My app can change its behaviour in response to manual volume change. The whole reason why it interests me is because soundproof of my car is not perfect and if on a full stop 14-16 volume level is enough, while driving I need to constantly turn volume up and sometimes even down (maybe it's just my lazyness). This app does it all by itself. If anyone is interested, I will get back to you when I'll have somewhat finished version. |
#1842 | |
Drives: 13 Subaru BRZ
| The Following User Says Thank You to ybotspawn For This Useful Post: | petr (03-16-2015) |
#1843 | |
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
#1844 |
Drives: GT 86
Anyone have any experience connecting a reverse camera? Im having a lot of trouble at the moment
#1845 |
Drives: 2013 GBS BRZ Limited
Haven't got around to it yet. What's the problem?
#1846 |
SLO NO MO
#1847 |
Need to buy a camera but keep forgetting what is needed.
#1848 | ||
Drives: Mazda Miata
I don't think so.
How to connect a rear view camera to an infotainment system? (Dashlinq4) On another topic: I found a way to improve music autostart on boot. Since global variables in Tasker are saved between reboots, you can use them to save last used music source. Here's example if you use only music player and radio, and want either of them to run after every boot. 1) Create new Profile, select Application, select Radio, press back 2) select New task, enter its name, press V 3) Create new Action, choose Variables, then Variable Set 4) Enter variable Name, it must start with % and uppercase letter, for example %Radio, then enter value in "To", type "1" or "on", does not matter, then press back and back again 5) Create another new Profile, select Application, select your music player (Poweramp), Back, New Task, New Task Name 6) new action, Variables, Variable Clear, in the Name put previously chosen name (%Radio), back and back 7) Another (last) Profile, choose Event, Device Boot, press Back 8) New task, New task name, new Action, Task, If 9) in Condition put your variable name (%Radio), select operator (~ button in the middle), choose Isn't Set 10) new Task, App, Launch App, your music player (Poweramp), Back 11) new Task, Media, Media Control, in Cmd select Play, then press Back Well, something like that, I don't know how it will behave if you switch between radio and player more than one time, but for me for now it will be enough. And finally: If you'r not happy with built-in music player and don't want it to run every time you insert USB stick Disabling standard USB music app |
| REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo | SHIFTER | Electronics | Audio | NAV | Infotainment | 16 | 06-13-2017 06:23 PM |
| Android, bluetooth, Music, and the FR-S stock pioneer stereo | JayNutter | Electronics | Audio | NAV | Infotainment | 27 | 12-18-2014 03:54 AM |
| How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 | SHIFTER | Electronics | Audio | NAV | Infotainment | 29 | 04-07-2014 04:58 AM |
