Old 03-10-2015, 11:47 PM   #1
Joseph
Joseph's Avatar
Drives: Firestorm FR-S
Please help.. Car not accelerating
hey guys,
I recently blew a valve and had to get my spark plugs changed (long story). My local mechanic pulled the engine and changed the spark plugs, dropped the engine and everything seems good. Only problem is after turning on the car, it runs fine for 20 seconds or so before the RPMs dip and and it just doesn't accelerated. The car keeps giving me **EDIT: P1261** after running a diagnosis. Any ideas what could be causing the accelerations issue? Thanks again. Just didn't know where else to turn to since its been stumping us for a couple days.
Joseph is offline   Reply With Quote
Old 03-11-2015, 04:08 AM   #2
Speed2th
I love my series blue brz
Speed2th's Avatar
Drives: 2010 335d
did you use your gray key?
Speed2th is offline   Reply With Quote
Old 03-11-2015, 08:50 AM   #3
And P1612 means...?
Old 03-11-2015, 09:01 AM   #4
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by Joseph View Post
hey guys,
I think if you really want help, we need the rest of the story.
Old 03-11-2015, 09:03 AM   #5
wheelhaus
wheelhaus's Avatar
Get that code pulled and see what it is first. Could be something silly like a loose gas cap. I can't find anything regarding that code with a Subaru or Toyota, I found it for some Nissans regarding the immobilizer key not registering correctly with the car or something.
Old 03-11-2015, 09:19 AM   #6
Joseph
Joseph's Avatar
Sorry guys the typed the code wrong. The code is giving me is
P1261 DI Injector Circuit / Open - (Cylinder 1)
We checked all the circuits and wiring. Seems fine. We believe it could be a false connection with a ground wire 20 seconds after turning on the ignition but nothing seems visible
Old 03-11-2015, 10:40 AM   #7
fika84
fika84's Avatar
Would seem that when the mechanic took the engine out and put it back in that something got messed up with the wiring..? That would be my guess. Wiring problems SUCK! They take a lot of time to hunt down and fix. Hopefully it is something simple like a ground, but he might have to retrace all of his steps to figure it out.
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
Tcoat (03-11-2015)
Old 03-11-2015, 10:42 AM   #8
stugray
"Circuit Open" means tha the ECU is not detecting any current flow when it tries to fire a DI injector.
This could mean that there is a problem in the harness or an injector coil has failed.
Get a "noid light" (or build one) and connect it to each DI injector connector and see if it blinks.
If the noid light says that all the DI injectors are getting voltage/current then the problem is not the ECU or the harness.
Then you can check the coil resistance of each injector with a DMM.
The Following 4 Users Say Thank You to stugray For This Useful Post:
86to86 (03-11-2015), brandonblt2 (09-08-2015), fika84 (03-11-2015), Tcoat (03-11-2015)
Old 09-08-2015, 11:51 AM   #9
Cessblood
Boost equals pleasure
Drives: MT Raven FRS Lexus ES300 &Turbo tc
hey guys,
My friend got the P1262 code this weekend. Did you get everything fix? What was the end results?
Cessblood is offline   Reply With Quote
Old 09-08-2015, 11:55 AM   #10
If they just got the code and had done nothing to the car before hand it is in all probability an injector it's self that has gone bad.
Ultramaroon (09-09-2015)
Pulsing when Accelerating carma143 Issues | Warranty | Recalls / TSB 41 02-27-2015 08:29 PM
Ticking/Clicking noise when accelerating? Pineapple Issues | Warranty | Recalls / TSB 3 08-28-2014 03:29 PM
question regarding screeching sound when accelerating kudougw Scion FR-S / Toyota 86 GT86 General Forum 12 07-18-2014 03:37 PM
accelerating from a dead stop jarviz Scion FR-S / Toyota 86 GT86 General Forum 78 07-26-2012 02:11 PM
A/C Shifts off when accelerating hard? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 29 06-19-2012 12:24 AM
