Old 03-10-2015, 06:57 PM   #1
Mr_YUzU_FRS
Drives: 2015 Scion FRS RS 1.0
front right signal not working. help
Well last night I was on the highway I hit a small wood branch on my lower front right bumper. It made a small little scratch, I don't think enough to make any electrical damage, but not 100% sure. Now every time I signal right, the arrow blinker inside blinks super fast, I knew something was wrong. When I check the lights, the rear right signal is working but the front right signal light stays off. Anyone have this problem before? If not I will bring it to the dealership since its still under warranty.
Mr_YUzU_FRS is offline   Reply With Quote
Old 03-10-2015, 07:24 PM   #2
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Have you tried replacing the bulb? Or at least checked to make sure it isn't loose? The fast blinking is the car's way of letting you know that the bulb is burnt out, but it might just be loose.
Stang70Fastback is offline   Reply With Quote
Old 03-10-2015, 07:56 PM   #3
Tan
Tan's Avatar
Drives: '15 FR-S, '13 ILX
Take your good bulb from the left and plug it in place of the right.
If it works, buy her a new bulb.
Tan is offline   Reply With Quote
The Following User Says Thank You to Tan For This Useful Post:
Imrac (03-10-2015)
Old 03-10-2015, 10:23 PM   #4
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Usually a super fast blinker means the light bulb is dead. The resistance from the light bulb is gone. Maybe the branch knocked it out of place?
N1rve
Old 03-10-2015, 10:43 PM   #5
Well somebody has to say it!!!!!!
Old 03-10-2015, 11:15 PM   #6
gravitylover
^^ It's either that or he can only make left turns from now on.
Old 03-11-2015, 06:47 AM   #7
Mr_YUzU_FRS
I will check the bulb and wires to see if it's OK. I will update back. Thx
Left turn signal not working. klassick Issues | Warranty | Recalls / TSB 15 09-24-2016 01:47 PM
right front turn signal freezes. help! ayetothejay Cosmetic Modification (Interior/Exterior/Lighting) 20 08-17-2015 09:19 PM
Front turn signal/Parking Light and Side marker not working s14sleepyeyez Issues | Warranty | Recalls / TSB 1 10-19-2014 11:43 PM
Crystal eye tails turn signal not working. FRSfan111 Cosmetic Modification (Interior/Exterior/Lighting) 14 01-06-2014 06:54 PM
My front turn signal lights not working after shop installed LED DRL bezel speedy racer Cosmetic Modification (Interior/Exterior/Lighting) 6 10-11-2013 06:08 PM
