#43 | |
Site Moderator
Drives: Stuff
Staggered setups with wider rear tires will just give this car more understeer, which is something very few people here want.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#44 | |
Site Moderator
Drives: Stuff
In this car I want neutral handling.. square setups are ideal for that. Until people are pushing serious power (which the majority in here won't be doing, regardless of how much people like to talk about it ) few people will need or want a lot more traction in the back. Some are already concerned about the rear having too much traction thanks to the EVO review ![]() Granted you aren't talking anything crazy with 8/9 setups and I'm probably biased more towards those who will be using the car for competition/track days.
-Dave
#45 |
Site Moderator
Drives: Stuff
That works too. It'll show clearance well enough and how it fits in the body work
![]() Thanks!
-Dave
#46 |
Proud of FR Layout
Drives: 2013 Scion FR-S 6MT
I agree with Dave, I will only run an equal wheel/tire width on all 4 corners since the car is so neutral. Body and suspension clearance be damned, Id rather set fire to the car than introduce more understeer.
#47 |
Drives: Rx7
great insight and info ... will definitely keep this in mind and advice the wheels manufacturer.
it really sucks the front have very limited room for wider wheels
#48 |
Sneakerhead
Drives: 2003 Honda Civic Si
do you guys have any aftermarket coils too see how much more room we can get? I'd want to rock at least 8.5 in the front and 9 or 9.5 in the back for my street setup. I'm planning to go with ccw so hopefully they can find a nice offset to get some kind of lip
#49 | |
Drives: Bugatti Veyron
#50 |
Gundam Meister
Drives: A Gundam
I def don't want or intend on getting a staggered setup. I want to run 17x8 which I think would be enough body and suspension clearance in the front. I think. I'm not sure what offset will be fine. 40-45 is ok?
#51 |
Site Moderator
Drives: Stuff
Depending on the overall tire diameter (ie if it's low enough not to rub the stock damper) and damper width you can lose space with threaded body coilovers. I've seen cars gain space and cars have less space. If the coils go lower than the tire then you are going to have less space, not more.
-Dave
#52 | |
Site Moderator
Drives: Stuff
Unfortunately it sounds like the high HP guys will have to run staggered. I highly doubt my BRZ will ever make too much more power.. sticky 215s or 235s will be plenty for me
-Dave
#53 |
Drives: Rx7
got some info from Japan.
look like a lot of people are running non-staggered. |
#54 |
Attack By Demons
Drives: 2022 BRZ (pre ordered)
thank you ravspec you just made my day..now I have in mind on what type of wheels I'll be doing
thanks for the specs and measurements
#attackbydemons #imcomingbackbish
#55 |
Drives: None
Thanks RavSpec
#56 |
Drives: BRZ(sold), STI
Someone should measure scrub radius first. I bet 38 offset is enough to change it from negative to positive, and then say hello to toe-out under braking and probably toe-in in turns.
| Wheel Directory: Work Emotion XD9 18x9.0 +38 / 18x10.0 +38 | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 124 | 08-01-2016 10:38 PM |
| Wheel Directory: Work Emotion XD9 18x9.0 +38 / 18x10.0 +38 | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 53 | 05-26-2015 11:39 AM |
| Wheel Directory: Work Emotion XD9 18x10.0 +38 | FRS8SIX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 05-22-2015 11:54 PM |
| Wheel Directory: Work VS-XX 18x9.0 +33 / 18x10.0 +33 | brunofrs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 29 | 11-08-2013 12:26 AM |
| Wheel Directory: Work Emotion 11R 18x9.5 +30 | autofashionfred | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 24 | 08-11-2012 01:39 AM |
