Old 05-17-2012, 11:51 AM   #43
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by RavSpec View Post
There are so much more space in the rear fender, and I think they purposely design it that way for larger rear wheel. I got almost twice the back spacing space rear vs front.
This is typical on RWD car like the S2000. I think we can even fit a 11.0 width in the rear.
Having owned an S2000 and driven fast ones, the fast setup is NON staggered. Most (every single one that I've seen/driven) fast S2000s (track/autocross cars I mean, not 600hp turbo cars) run 275s all around.
Staggered setups with wider rear tires will just give this car more understeer, which is something very few people here want.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-17-2012, 11:58 AM   #44
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Ill suggest 17x8 front but use 17x9 on the rear. Way too much room in the rear. Should take advatage of that and run a wider rear for more grip. Unless u don't plan on any power upgrade, then 17x8 is all u need.
I can adjust my driving with power upgrades to the extent I want power upgrades.
In this car I want neutral handling.. square setups are ideal for that. Until people are pushing serious power (which the majority in here won't be doing, regardless of how much people like to talk about it ) few people will need or want a lot more traction in the back.
Some are already concerned about the rear having too much traction thanks to the EVO review
Granted you aren't talking anything crazy with 8/9 setups and I'm probably biased more towards those who will be using the car for competition/track days.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-17-2012, 12:12 PM   #45
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Not yet .... I might test the 18x8 +35 , keep u updated.
That works too. It'll show clearance well enough and how it fits in the body work
Thanks!
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-17-2012, 01:00 PM   #46
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
I agree with Dave, I will only run an equal wheel/tire width on all 4 corners since the car is so neutral. Body and suspension clearance be damned, Id rather set fire to the car than introduce more understeer.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
The Following 2 Users Say Thank You to mattles For This Useful Post:
Calum (05-17-2012), civicdrivr (05-21-2012)
Old 05-17-2012, 01:23 PM   #47
RavSpec
Drives: Rx7
great insight and info ... will definitely keep this in mind and advice the wheels manufacturer.
it really sucks the front have very limited room for wider wheels
RavSpec is offline   Reply With Quote
Old 05-17-2012, 01:34 PM   #48
igorot
Sneakerhead
igorot's Avatar
Drives: 2003 Honda Civic Si
do you guys have any aftermarket coils too see how much more room we can get? I'd want to rock at least 8.5 in the front and 9 or 9.5 in the back for my street setup. I'm planning to go with ccw so hopefully they can find a nice offset to get some kind of lip
igorot is offline   Reply With Quote
Old 05-17-2012, 01:35 PM   #49
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
this
quik1987 is offline   Reply With Quote
Old 05-17-2012, 01:53 PM   #50
ZetaVI
Gundam Meister
ZetaVI's Avatar
Drives: A Gundam
I def don't want or intend on getting a staggered setup. I want to run 17x8 which I think would be enough body and suspension clearance in the front. I think. I'm not sure what offset will be fine. 40-45 is ok?
Old 05-17-2012, 01:55 PM   #51
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Depending on the overall tire diameter (ie if it's low enough not to rub the stock damper) and damper width you can lose space with threaded body coilovers. I've seen cars gain space and cars have less space. If the coils go lower than the tire then you are going to have less space, not more.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-17-2012, 02:01 PM   #52
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
This can be a good reason to run staggered (but only if traction is needed). If I had 400HP but could ONLY fit 8s up front then I'd have to run staggered and tune the suspension differently. On the other hand if you can fit 9", 10", etc wheels (whatever is actually needed for the required tires) then I'd prefer non-staggered.. wide tires reduce steering feel/turn in but I'd still rather have square setups (and wide front tires are good for braking, crap for wet weather though).
Unfortunately it sounds like the high HP guys will have to run staggered. I highly doubt my BRZ will ever make too much more power.. sticky 215s or 235s will be plenty for me
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-17-2012, 02:51 PM   #53
RavSpec
Drives: Rx7
got some info from Japan.
look like a lot of people are running non-staggered.
The Following 3 Users Say Thank You to RavSpec For This Useful Post:
civicdrivr (05-21-2012), Fly Guy (05-17-2012), raz0rbladez909 (08-17-2012)
Old 05-17-2012, 10:55 PM   #54
86design
Attack By Demons
86design's Avatar
Drives: 2022 BRZ (pre ordered)
thank you ravspec you just made my day..now I have in mind on what type of wheels I'll be doing thanks for the specs and measurements
#attackbydemons #imcomingbackbish
86design is offline   Reply With Quote
Old 05-17-2012, 11:12 PM   #55
eight_six
Drives: None
Thanks RavSpec
eight_six is offline   Reply With Quote
Old 05-18-2012, 12:24 AM   #56
dsgerbc
Drives: BRZ(sold), STI
Someone should measure scrub radius first. I bet 38 offset is enough to change it from negative to positive, and then say hello to toe-out under braking and probably toe-in in turns.
Wheel Directory: Work Emotion XD9 18x9.0 +38 / 18x10.0 +38 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 124 08-01-2016 11:38 PM
Wheel Directory: Work Emotion XD9 18x9.0 +38 / 18x10.0 +38 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 05-26-2015 12:39 PM
Wheel Directory: Work Emotion XD9 18x10.0 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 05-23-2015 12:54 AM
Wheel Directory: Work VS-XX 18x9.0 +33 / 18x10.0 +33 brunofrs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 11-08-2013 01:26 AM
Wheel Directory: Work Emotion 11R 18x9.5 +30 autofashionfred Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 08-11-2012 02:39 AM
