Old 03-04-2015, 10:25 PM   #281
tubsaub
tubsaub's Avatar
Has anyone running the greddy turbo kit with a bov used their tune?
tubsaub is offline   Reply With Quote
Old 03-05-2015, 12:26 PM   #282
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
I know we have quite a few customers running the Greddy kit that enjoy the tune, not sure if they'll see this and chime in here or not. That's a fun kit to tune for
Sincerely,
Zach
Old 03-08-2015, 03:34 PM   #283
raytrix
Drives: Series 10 FR-S
@sales@delicioustuning.com
I believe I finalized my setup that's going on the car in 1 week from now. Touge Factory will be contacting you guys soon to tune this setup.
Greddy T518Z turbo kit
Greddy Type FV BOV
Greddy Profec boost controller
Full exhaust upgraded (Motiv Over pipe, Motive Front pipe, Greddy Comfort Sport GTS V2 exhaust)
Injector Dynamics 725cc injectors
Denso 265lph fuel pump
What's a safe PSI I can run with this setup conservatively? 10/12/14 PSI?
raytrix is offline   Reply With Quote
Old 03-09-2015, 12:28 PM   #284
DeliciousTuning
Greddy Type FV BOV
On pump gas, 10-12 psi is the max we really recommend. On E85, you can safely increase that to around 16 psi provided you have adequate cooling modifications.
Sincerely,
Zach
The Following User Says Thank You to DeliciousTuning For This Useful Post:
raytrix (03-09-2015)
Old 03-09-2015, 02:02 PM   #285
xxscaxx
Drives: 2013 SWP BRZ
Zach,
Do you suggest that across all platforms regarding the cooling modifications if running e85 at a higher boost level? And if so, what modifications do you recommend? (guessing an oil cooler, new radiator).
I really never saw a need to upgrade my rad, I don't really drive my car hard that much (and didn't need to bc of my power levels at the time). I do have an oil cooler though it is the stock forester oil cooler and not an aftermarket one.
xxscaxx is offline   Reply With Quote
Old 03-09-2015, 03:26 PM   #286
DeliciousTuning
Originally Posted by xxscaxx View Post
Zach,
We recommend a quality oil cooler. If running any harder than spirited street driving, an air-liquid oil cooler is the recommended route. All advice is really going to be application specific. As far as the radiator we've found it to be highly efficient and don't see a need to upgrade it unless running very high power levels, 400+ whp.
Sincerely,
Zach
xxscaxx (03-09-2015)
Old 03-09-2015, 03:46 PM   #287
xxscaxx
Thanks Zach!
The Following User Says Thank You to xxscaxx For This Useful Post:
Old 03-09-2015, 11:02 PM   #288
raytrix
Sincerely,
Zach
Yup will be running purely on 93 Oct. So I'm guessing tune for 12psi but lower the boost controller to run 10psi all the time. When I feel like boosting up I can crank it another 2 psi.
Old 03-10-2015, 01:04 AM   #289
DeliciousTuning
You could definitely go that route. If you're only running 93 you could even use a boost controller and have 3-4 separate maps. 8, 10, and 12 would be a good spread. Honestly on most setups we see more power and responsiveness on pump gas from lowering the boost a bit and taking advantage of the timing left on the table. Helps with heat too.
Sincerely,
Zach
raytrix (03-10-2015)
Old 03-10-2015, 10:49 AM   #290
raytrix
Sincerely,
Zach
That's good info to know. Heat wise I having the hot side of the turbo all ceramic coated, the radiator upgraded to Koyo with SPAL fans and FBM fan shroud. Also have Greddy Circuit oil cooler on the car. I very much like the idea of 8-10-12 maps.
The Following User Says Thank You to raytrix For This Useful Post:
Old 03-12-2015, 11:58 AM   #291
DeliciousTuning
Refining even further this past week on the Flash & Go for you guys, good things to come. Will keep you all posted with more details.
Sincerely,
Zach
The Following 3 Users Say Thank You to DeliciousTuning For This Useful Post:
086A (03-13-2015), Efferalgan (03-14-2015), maxjedi (03-12-2015)
Old 03-13-2015, 11:23 AM   #292
Shit Luck
Drives: red frs
Angry
I got the car out yesterday as it finally got above 45 degrees.
car still wont idle consistently and stalls out when coming off throttle. infact It stalled 4 times in some stop and go traffic and wouldn't stay running after restarted without keeping my foot on the pedal...
Shit Luck is offline   Reply With Quote
Old 03-13-2015, 01:21 PM   #293
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
Forced induction? Vacuum leak?
Infamous Performance is offline   Reply With Quote
Old 03-13-2015, 03:14 PM   #294
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
I would say vacuum leak. Maybe under the intake manifold?
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! P&L Motorsports Forced Induction 9 03-26-2017 01:27 PM
Most *fun* forced induction bfrank1972 Forced Induction 45 12-22-2016 11:36 AM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Announcements, Contests, Giveaways 115 02-28-2014 12:38 PM
February Sale. All Delicious Tuning e-tunes are 10% off!!! Infamous Performance Announcements, Contests, Giveaways 19 02-28-2014 12:37 PM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Forced Induction 107 02-13-2014 11:36 AM
