Old 03-06-2015, 10:05 PM   #183
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Koa (03-09-2015)
Old 03-06-2015, 10:26 PM   #184
Blitzenn
Drives: Scion FR-S RS 1
Careful on the ethanol free gas. It may be listed as premium but it is usually 91 octane not 93. The manual (at least mine does) actually calls for 93 octane. I don't know if Ethanol free 91 is equivalent or not. I think not just because its listed at 91. That means it doesn't burn as hot as 93. You might have to put a booster supplement in a 91 octane tank of fuel.
The nice part about adding ethanol, or other alcohol based fuel, is that it burns hotter, combusts faster. Trouble with it is that it provides almost no lubricant and can burn the crap out of the engine depending on the percentage of it in the fuel. That's why it is limited to a percentage by most states at this point. You could burn 100% alcohol based fuel easy and have great performance (as drag cars can show you) but you would have to rebuild the engine at regular intervals. Most people don't want to do that lol. So 91 with a booster is probably better than 93 with ethanol, but its gonna cost you more to do.
Blitzenn is offline   Reply With Quote
Old 03-06-2015, 10:39 PM   #185
The manual says that 93 is recommended but a minimum of 91 is required. You do not need to add octane booster to 91. The 91 works just fine for daily driving but you do loss a very small amount of power so it would suck for any race/track application.
Oh and 93 doesn't "burn hotter" but burns better in a high compression engine since it doesn't pre ignite like lower octane gas does.
Old 03-09-2015, 04:13 AM   #186
Alexandr_Rychok
Alexandr_Rychok's Avatar
Drives: Subaru BRZ, Chevrolet Camaro
Gas Premium or regular
Also keep in mind that the higher the altitude you are in the less octane you will need. So at higher altitudes DO NOT use premium ever. Regular should work fine in our vans. Just stay away from "crappy" 2nd rate gas stations. Stick with the big names like Mobil/Shell, etc.
Alexandr_Rychok is offline   Reply With Quote
Old 03-09-2015, 09:09 AM   #187
navanodd
Drives: 2013 BRZ Sport-tech WRB
Yeah 91 is fine. I believe the car is retarding the ignition a bit, at least for me at sea level in the summer, but thanks to availability my car us unlikely to ever see higher than 91unless it goes on some really, really long road trips.
navanodd is offline   Reply With Quote
Old 03-09-2015, 10:43 AM   #188
HunterGreene
Hail Magnet
HunterGreene's Avatar
Source? And sorry, but recommending not using the gasoline that is required/recommended for these cars is just stupid, as any engine troubles you have would not be covered by warranty.
Or you're trolling, in which case, good job.
It has priests in it?
The Following User Says Thank You to HunterGreene For This Useful Post:
Tcoat (03-09-2015)
Old 03-09-2015, 11:43 AM   #189
Dude please it is 2015!
The car is intellectually challenging the ignition!
HunterGreene (03-09-2015), Koa (03-09-2015), meWant (03-16-2015), navanodd (03-09-2015), roddy (03-09-2015)
Old 03-09-2015, 03:32 PM   #190
navanodd
Sorry, we're a little bit behind the rest of the world on here on the east coast. Or at least that's what the lamplighter tells me.
Old 03-09-2015, 03:41 PM   #191
Oh ya I forgot where you were at!
Never mind.
Old 03-16-2015, 01:24 AM   #192
buckyislucky
buckyislucky
Drives: 2015 scion frs
i just got my frs 2015 and i have no idea what the dealer filled up with - but i lost alot of gas. maybe its because i havent driven manual in so many years and reving to high . my first car was a civic DX almost 9 years ago and havent driven manual since.
i filled up today and didnt know what to put as i have had mixed reviews here on the board... i went into a shell first sat there for 2 minutes then went across the street to petro to fill up 94 for 2 cents cheaper.
drove 100km today and it hasnt even hit the 3/4 mark. I'm guessing 94 is giving some more mileage. I dont want to be switching back and forth so im probably gonna stay with the 94.
ps... i didnt read all the posts so ill just add to more speculation
buckyislucky is offline   Reply With Quote
Old 03-16-2015, 01:58 AM   #193
diBreezy
diBreezy's Avatar
Drives: 2013 Raven FRS
e85
diBreezy is offline   Reply With Quote
Old 03-16-2015, 03:08 AM   #194
Obja
Obja's Avatar
Drives: Raven FRS/c5 Corvette
wow i miss the 86 owners from 2013...
these new people blow my mind
Obja is offline   Reply With Quote
The Following 4 Users Say Thank You to Obja For This Useful Post:
HunterGreene (03-16-2015), meWant (03-16-2015), Tcoat (03-16-2015), tennisfreak (03-16-2015)
Old 03-16-2015, 07:29 PM   #195
CambakerFt8677
CambakerFt8677's Avatar
Drives: 2013 Fr-s hot lava (rip) 2016 frs
well hope I can help, answer to your question run no less than 91 no more than 93 and DONT run e85 or any high octane unless your running a supported tune . Fuel quality is very important in modern engines and of course the fa20 being a high compression motor having the best performance is going to be required by you and only you putting the fuel recommended for the car in the car . Modern motors have sensors that detect knock (knock is bad) shitty fuel qualities and fuels that are not suppose to be used with stock ecu tunes can cause intense knock which can in the future cause severe harm to your engine, but that's another topic
CambakerFt8677 is offline   Reply With Quote
Old 03-16-2015, 07:43 PM   #196
Dude the question is 3 years old and has been answered about 191 times!
Did you even read beyond the first post?????
HunterGreene (03-17-2015)
uberstupid, use premium!, you can't fix stupid
Premium gas, or? NotlocTRD Scion FR-S / Toyota 86 GT86 General Forum 151 09-27-2017 02:56 PM
FRS arrival for regular customers question NWIguy Scion FR-S / Toyota 86 GT86 General Forum 20 05-05-2012 08:54 AM
Anyone have a pic of the regular seats? DuMa Scion FR-S / Toyota 86 GT86 General Forum 38 12-14-2011 12:29 AM
So is it a hatch or regular trunk? xantonin Scion FR-S / Toyota 86 GT86 General Forum 5 12-09-2011 07:26 PM
Consequences to Adding Regular Gas? iff2mastamatt Scion FR-S / Toyota 86 GT86 General Forum 34 12-06-2011 12:52 AM
