| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Leaux Down Krewe
Drives: 2014 SSM Limited
"Low" is a relative term.
The build thread: http://www.ft86club.com/forums/showthread.php?t=31514 Follow me on IG: @rougarou86 |
#16 |
Drives: GT86
et35 isn't, but originally I was looking for et25 (I said in the original thread I was struggling to find anything LOWER than et35, not that I wanted et35) and I could hardly find any wheels with an offset that low so I assumed that was pretty low.
#17 |
If you want to keep the same size as stock, look at a set of rims that are 17x7 with an offset of +35. If you want slightly wider you could go 17x8 +35 and run a 225/45/17.
#18 |
Drives: 2014 WRB BRZ LTD
The problem is this is really hard to find except in replicas. I've been looking at options for a couple of weeks.
#19 | |
http://www.ft86speedfactory.com/whee...3/index-2.html http://www.ft86speedfactory.com/wheels-40/17x9-114/ http://www.ft86club.com/forums/showthread.php?t=37136 http://www.ft86club.com/forums/showthread.php?t=65113
#20 | |
Drives: '13 FR-S
They're also only 16lb a wheel, so that's another perk. |
| The Following User Says Thank You to CatDaddysBBQ For This Useful Post: | ChrisD (03-15-2015) |
#21 |
Yup +35 offset works well. A bit of poke I think with out negative camber up front. I have 17x8 +35 for my summer's.
| The Following User Says Thank You to D_Thissen For This Useful Post: | ChrisD (03-15-2015) |
#22 |
I heard spacers are fine for racing. Just my $.02
| The Following 2 Users Say Thank You to Ashikabi For This Useful Post: | CatDaddysBBQ (03-16-2015), ChrisD (03-15-2015) |
#23 |
Drives: GT86
Thanks for the help guys - ended up ordering some OZ Ultraleggera wheels with a 35 offset and .5 of an inch wider than stock wheels (so 17x7.5, et35).
So my existing 215 width tyres should still fit fine and the extra width and lower offset should make it sit roughly flush Will post some pics in my build thread once they're on: http://www.ft86club.com/forums/showthread.php?p=2169702
| Closest to OEM Wheels width and offset | impossible | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 08-23-2014 02:24 PM |
| WTB (SoCal) 17" (width and offset can vary) wheels | jonbonazza | Wheels and Tires | 0 | 02-28-2014 08:43 PM |
| FS:PRICE DROP UPDATE!! SOCAL: 2011 WRX WHEELS 17X8 +53 offset | Turboblades | Wheels and Tires | 5 | 09-26-2013 04:49 PM |
| how will +35 offset wheels fit | yetiFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 05-15-2013 05:33 PM |
