Old 10-13-2014, 09:26 PM   #57
riironman
riironman's Avatar
Drives: asphalt fr-s
Is there instructions online on setup. Never used coil overs before and having a tough time dialing them in. I have them set to a softness of 9 clicks from soft. I have them set as the same as height as my eibach sportlines at 1.4" drop. . Feels like I hit harder or bottom out on the rears on bumps. Not sure if I know what I am doing
riironman is offline   Reply With Quote
Old 10-14-2014, 09:15 AM   #58
spdbydesign
spdbydesign's Avatar
Drives: 2010 Nissan GTR
Stiffen them up.
Set them at all the way hard, then back down.
The spring rates are so soft for road use, that even at their stiffest setting....it's still a a comfortable ride.
So the rule is start all the way stiff, then back off as your drop will allow to prevent them from bottoming out on the fender liner at your preferred drop.
spdbydesign is offline   Reply With Quote
The Following User Says Thank You to spdbydesign For This Useful Post:
Strife26 (03-08-2015)
Old 10-17-2014, 05:38 PM   #59
riironman
riironman's Avatar
Thank you. I will try that. I just had to relock the rears again. This time I I tightened them up bending the wrench and after used a large flathead screwdriver with a hammer to snug u them up more. Hopefully that works.
Old 10-24-2014, 11:27 PM   #60
PNW FRS
PNW FRS's Avatar
Update
Started getting some spring wind noise again... So at the suggestion of Steve (Ishii Motors - Bellevue WA), I tightened up the springs..
went from 6 in (top edge of upper perch to top edge of lower perch) to 5.75 in. - tightened everything, and spring wind noise is gone. These springs must have softened up a bit more... not so surprising since they were designed for a better street ride....
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 10-25-2014, 02:03 AM   #61
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Not sure if you read my posts about the spring binding, but I resolved my spring binding by installing Fortune Auto's Radial Spring Bearing. No issues in over 6 months.
ericmpena is offline   Reply With Quote
The Following User Says Thank You to ericmpena For This Useful Post:
Old 10-26-2014, 05:16 PM   #62
PNW FRS
PNW FRS's Avatar
No... I didn't see your post. I'll do a search and try to find your post. This is driving me nutz! Did about 300 miles yesterday after the latest tweak and the spring wind is back with a vengeance.
2013 Asphalt / MT
Olympia, Washington
Old 10-26-2014, 08:14 PM   #63
PNW FRS
PNW FRS's Avatar
Sigh...
OK... so I've reviewed your thread and it all makes a lot of sense. And... I guess any future buyers of SPD Coilovers may benefit if their supplier changes the design to use Torrington Bearings.
Eric: At least you got yours for free (the contest).... the rest of us paid to be BETA testers for SPD's entry into the coilover market. Now, I'll need to buy the bearings and go through the hassle of taking the front units off.... do the disassemble and install of the Fortune product... and then reinstall.
Notable: absolutely no documentation came with the SPD StreetPro Coilovers... and even after repeated (and unanswered) requests for some basic documentation on the struts, I'm having to use info (Web documentation and videos) to try and figure out the basic starting point for these. Not saying having some instructions would have eliminated the spring bind/wind noise, but having a point of reference for "defaults" would have been nice.
I'm out my original installation costs... and will need to spend $$ on aftermarket fix and labor for the reinstall.
So lesson learned here is that IF SPD offers this type of product again... buyer beware.
And so as to not end on a negative note... I still like the ride the SPD C/O setup provides... their design (spec) to be "street friendly" is not off the mark... but the spring bind(wind) noise just puts a damper (pun intended) on my overall satisfaction.
Update (edit): Re-set the front pre-load to best guess of "normal" -- measurement from top of upper perch to top of lower perch is 6.125".
- Spring bind(wind) reduced... not eliminated... ordered the Torrington Bearing... and making arrangements with my wrench to do the install... oh joy... I get to spend more money... (sigh)
2013 Asphalt / MT
Olympia, Washington
Old 10-27-2014, 09:15 AM   #64
ISDriven
ISDriven's Avatar
Drives: chill
I like your car, looks good!
ISDriven is offline   Reply With Quote
Old 11-13-2014, 11:36 PM   #65
PNW FRS
PNW FRS's Avatar
Added Torrington Bearings
http://www.ft86club.com/forums/showp...2&postcount=52
This seems to be a good solution for the coil bind (wind) noise. We'll see how well it holds up over time and miles.
Update... the grinding noise from front right.... finally tracked down the issue...
Found the offending nut on the end link (at one of the adjusting ends...) that was tightened the wrong way!! Instead of being tightened down onto the shaft, it was tightened UP to the ball joint -- "grinding" against the outside of the ball joint. Fixed... and now the suspension is QUIET!!
Wow.. what a learning experience!
2013 Asphalt / MT
Olympia, Washington
Old 03-07-2015, 11:51 PM   #66
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
Just want to appreciate!
Originally Posted by spdbydesignchris View Post
I appreciate the compliment. There's no point in selling a customer a mis-matched product for their needs.
I'll be completely open here and tell you that when we first started working on this project, I wanted a "Cadillac" quality ride.
I wanted soft and plush, something I would want to daily drive and not come home feeling back pain from every bump in the road.
From there, we worked on spring rates and valving to meet that goal.
This car rides like a luxury car now, and you'd be amazed at the before and after....coming from stock suspension.
However, when going soft, you compromise cornering to an extent, while gaining excellent straight line traction.
These would serve great for weekend drag strip visits, where the car will squat and go.
A stiffer suspension that is more track focused would simply spin the tires from the initial shock of the launch, resulting in poor 60 ft times.
I hope this explains the design goals for this suspension and more closely targets the ideal customer for this product.
Just wanted to say I am in love with Chris after reading on 2 forums (no homo). I plan to purchase the turbo within the next couple months and he responds a lot and seems to be very honest.
I am noW a fan of spdbydesign!
EDIT: Changed my T to a W. WTH! I totally meant to say "now" lol!
Strife26 is offline   Reply With Quote
Old 03-07-2015, 11:54 PM   #67
Strife26
Strife26's Avatar
Originally Posted by Carlitoz3 View Post
Very good review!
Honestly if I had won it wouldn't have been this detailed with pictures
I just have a few questions about aftermarket coils:
- Will I have a clicking sound when making turns in the future?
- Some people end up with their steering wheel not lined up when installing coils. Why is that?
- Not the best with cars, 1-10, how difficult is it to put on coil? 10 being hard.
I read that an alignment is 100% recommended after springs OR coil-over installs.
I changed out struts once being a computer nerd and it was easy enough except the car was recently in a light wreck that bent the frame or forks idr but it made one of them a pita! Very doable. The hardest and scariest part was the springs, but it doesn't look like you need to touch them so I would say its super easy! Also, youtube it! There are some out there I have seen and it looks easy.
The Following User Says Thank You to Strife26 For This Useful Post:
Carlitoz3 (03-08-2015)
Old 03-08-2015, 12:00 AM   #68
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by Strife26 View Post
I am not a fan of spdbydesign!
You're not the first one to say that.
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
Top Speed street cat back for sale & free oem exhaust/headers (DALLAS) h4nh Engine, Exhaust, Bolt-Ons 1 01-25-2014 09:41 PM
Is Speed Density tuning required for under 400HP street driven cars vgi Software Tuning 35 12-03-2013 06:29 PM
New Tein Street Flex Coilovers - Review and Initial Impressions RallySport Direct Announcements, Contests, Giveaways 6 02-18-2013 12:06 PM
Cusco Street Zero-A & Street Spec A Coilovers - In Stock And Ready To Ship Enjuku Racing Brakes, Suspension, Chassis 0 09-12-2012 05:12 PM
