#57 |
Drives: asphalt fr-s
Is there instructions online on setup. Never used coil overs before and having a tough time dialing them in. I have them set to a softness of 9 clicks from soft. I have them set as the same as height as my eibach sportlines at 1.4" drop. . Feels like I hit harder or bottom out on the rears on bumps. Not sure if I know what I am doing
#58 |
Drives: 2010 Nissan GTR
Stiffen them up.
Set them at all the way hard, then back down. The spring rates are so soft for road use, that even at their stiffest setting....it's still a a comfortable ride. So the rule is start all the way stiff, then back off as your drop will allow to prevent them from bottoming out on the fender liner at your preferred drop. |
| The Following User Says Thank You to spdbydesign For This Useful Post: | Strife26 (03-08-2015) |
#59 |
Thank you. I will try that. I just had to relock the rears again. This time I I tightened them up bending the wrench and after used a large flathead screwdriver with a hammer to snug u them up more. Hopefully that works.
#60 |
Update
Started getting some spring wind noise again... So at the suggestion of Steve (Ishii Motors - Bellevue WA), I tightened up the springs..
went from 6 in (top edge of upper perch to top edge of lower perch) to 5.75 in. - tightened everything, and spring wind noise is gone. These springs must have softened up a bit more... not so surprising since they were designed for a better street ride....
2013 Asphalt / MT
Olympia, Washington Last edited by PNW FRS; 10-25-2014 at 01:40 AM. |
#61 | |
Drives: Subaru BRZ Limited
Not sure if you read my posts about the spring binding, but I resolved my spring binding by installing Fortune Auto's Radial Spring Bearing. No issues in over 6 months.
| The Following User Says Thank You to ericmpena For This Useful Post: | Strife26 (03-08-2015) |
#62 |
No... I didn't see your post. I'll do a search and try to find your post. This is driving me nutz! Did about 300 miles yesterday after the latest tweak and the spring wind is back with a vengeance.
2013 Asphalt / MT
Olympia, Washington |
#63 |
Sigh...
OK... so I've reviewed your thread and it all makes a lot of sense. And... I guess any future buyers of SPD Coilovers may benefit if their supplier changes the design to use Torrington Bearings.
Eric: At least you got yours for free (the contest).... the rest of us paid to be BETA testers for SPD's entry into the coilover market. Now, I'll need to buy the bearings and go through the hassle of taking the front units off.... do the disassemble and install of the Fortune product... and then reinstall. Notable: absolutely no documentation came with the SPD StreetPro Coilovers... and even after repeated (and unanswered) requests for some basic documentation on the struts, I'm having to use info (Web documentation and videos) to try and figure out the basic starting point for these. Not saying having some instructions would have eliminated the spring bind/wind noise, but having a point of reference for "defaults" would have been nice. I'm out my original installation costs... and will need to spend $$ on aftermarket fix and labor for the reinstall. So lesson learned here is that IF SPD offers this type of product again... buyer beware. And so as to not end on a negative note... I still like the ride the SPD C/O setup provides... their design (spec) to be "street friendly" is not off the mark... but the spring bind(wind) noise just puts a damper (pun intended) on my overall satisfaction. Update (edit): Re-set the front pre-load to best guess of "normal" -- measurement from top of upper perch to top of lower perch is 6.125". - Spring bind(wind) reduced... not eliminated... ordered the Torrington Bearing... and making arrangements with my wrench to do the install... oh joy... I get to spend more money... (sigh)
2013 Asphalt / MT
Olympia, Washington Last edited by PNW FRS; 10-27-2014 at 10:35 PM. |
#65 |
Added Torrington Bearings
http://www.ft86club.com/forums/showp...2&postcount=52
This seems to be a good solution for the coil bind (wind) noise. We'll see how well it holds up over time and miles. Update... the grinding noise from front right.... finally tracked down the issue... Found the offending nut on the end link (at one of the adjusting ends...) that was tightened the wrong way!! Instead of being tightened down onto the shaft, it was tightened UP to the ball joint -- "grinding" against the outside of the ball joint. Fixed... and now the suspension is QUIET!! Wow.. what a learning experience!
2013 Asphalt / MT
Olympia, Washington Last edited by PNW FRS; 11-22-2014 at 12:45 AM. |
#66 | |
Drives: 2015 Subaru BRZ Series.blue
Just want to appreciate!
I am noW a fan of spdbydesign! EDIT: Changed my T to a W. WTH! I totally meant to say "now" lol! Last edited by Strife26; 03-08-2015 at 12:12 AM. Reason: Typo |
#67 | |
I changed out struts once being a computer nerd and it was easy enough except the car was recently in a light wreck that bent the frame or forks idr but it made one of them a pita! Very doable. The hardest and scariest part was the springs, but it doesn't look like you need to touch them so I would say its super easy! Also, youtube it! There are some out there I have seen and it looks easy. |
| The Following User Says Thank You to Strife26 For This Useful Post: | Carlitoz3 (03-08-2015) |
#68 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
| Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped | GuerillaRacing | Brakes, Suspension, Chassis | 149 | 05-12-2015 05:53 PM |
| Top Speed street cat back for sale & free oem exhaust/headers (DALLAS) | h4nh | Engine, Exhaust, Bolt-Ons | 1 | 01-25-2014 09:41 PM |
| Is Speed Density tuning required for under 400HP street driven cars | vgi | Software Tuning | 35 | 12-03-2013 06:29 PM |
| New Tein Street Flex Coilovers - Review and Initial Impressions | RallySport Direct | Announcements, Contests, Giveaways | 6 | 02-18-2013 12:06 PM |
| Cusco Street Zero-A & Street Spec A Coilovers - In Stock And Ready To Ship | Enjuku Racing | Brakes, Suspension, Chassis | 0 | 09-12-2012 05:12 PM |
