go_a_way1
Old 03-05-2015, 01:01 PM   #1667
Xuningshen
Drives: Subaru BRZ
Originally Posted by lastexile1987 View Post
So I have my brz in the shop getting my kit installed. Small issues, I bought the kit second hand and it is missing the PVC valve, firewall grommet and the vacuum tee was broken. Any one know if these parts are specifically designed by JR or if an off the shelf one would work?
off the shelf will definitely work. parts are parts, as long they are the same size. I'm sure they bought those specific parts from a manufacturer anyways. the vaccum hose is 4mm. I had a my guy measure it when I bought extra hose. so get a Tee that fits that.
and firewall grommet? nothing goes thru the firewall for install.
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
Old 03-05-2015, 01:42 PM   #1668
MidnightRunner
MidnightRunner's Avatar
Probably from where the stock "sound tube" fed into the passenger side firewall.
Sent from my LG-P769 using Tapatalk
There is no great genius without a mixture of madness - Aristotle
MidnightRunner is offline   Reply With Quote
Old 03-06-2015, 10:50 AM   #1669
Noob4Life
86 Noob
Drives: Firestorm FR-S
Sadly I didn't get the numbers I was hoping for but here's a dyno log I have. I should add that this car still feels amazing and it's definitely fast now!
Mod list on CA 91 oct:
-JRSC
-Omni 3 bar map
-Perrin LW crank pulley
-Rev Works UEL headers
-Nameless 2.5" catted op/fp
-OEM midpipe
-Nameless 3" axleback
That was the average 3rd gear pull. Ended up being about 233whp SAE corrected.
He suggested we do a couple 4th gear pulls as well. These are those. Again about 233whp SAE corrected, IDK why he gave my uncorrected dynos lol
NA dynos:
This dyno is from when I was NA and with a different tuner.
Mod list with CA 91 oct:
-OEM airbox with TRD filter
-Same parts as above
2 runs are with the stock tune and 2 runs are with the new tune.
Any recommendations on getting closer to 280 without switching fuels?
Noob4Life is offline   Reply With Quote
Old 03-06-2015, 11:11 AM   #1670
Raven604
Better header, Rev works is kinda meh from what I've seen
Raven604 is offline   Reply With Quote
The Following User Says Thank You to Raven604 For This Useful Post:
Noob4Life (03-06-2015)
Old 03-06-2015, 11:29 AM   #1671
Noob4Life
86 Noob
That's what I've been thinking, was thinking about tomei or JDL but not sure if the extra gains will be worth the price because I still want UEL. You think the nameless 3" midpipe will make a big difference? They claim 12hp FI.
Old 03-06-2015, 11:32 AM   #1672
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Sell your stock midpipe + nameless axleback and get a true 2.5" catback like the Dezod Motorsports catback
3" catback will be way too loud IMO
The Following User Says Thank You to ATL BRZ For This Useful Post:
Old 03-06-2015, 12:13 PM   #1673
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
I agree, sell and buy true 2.5! Def agree that 3" will be too loud.
ApolloSki is offline   Reply With Quote
Old 03-06-2015, 12:42 PM   #1674
CSG Mike
CSG Mike's Avatar
-JRSC
-Omni 3 bar map
-OEM midpipe
NA dynos:
You will make more power with the CARB tune, and stock header, judging from your before/after dynos.
Also, measure those crank pulleys, carefully, with calipers. Perhaps your're making less boost than normal due to a smaller crank pulley (I've seen it before).
Old 03-07-2015, 11:58 AM   #1675
autograph
autograph's Avatar
Drives: 6MT Hot Lava
hey guys I tried doing a search and didn't find much; what tire size are the folks with the JRSC running with for street use? 225? 235? 245?
autograph is offline   Reply With Quote
Old 03-07-2015, 12:03 PM   #1676
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
I ran stock ones for 3 months, note I use 245/45 mpss.
ScionOfHorus is offline   Reply With Quote
Old 03-07-2015, 12:32 PM   #1677
enivid
enivid's Avatar
Drives: WRB JR BRZED
I run 18 245's for street and 17 225's for track.
enivid is offline   Reply With Quote
Old 03-07-2015, 12:34 PM   #1678
dp1
driving smoother faster
Drives: Sold
225/45-17 mpss on 17x8. 225 also fits stock rims just fine. I use UTQG 100 rubber in 235/40-17 for ax/track - this size is less common and usually in stickier rubber.
IMHO anything bigger than 225 for street is for looks but 235/245 works also.
dp1 is offline   Reply With Quote
Old 03-07-2015, 03:06 PM   #1679
Lone Starr
Drives: WRB Limited
225/45/17 rs3 on 17x8 wrx wheels and 5mm spacer, street and track
So...at last we meet for the first time for the last time...
Lone Starr is offline   Reply With Quote
Old 03-07-2015, 09:06 PM   #1680
CSG Mike
CSG Mike's Avatar
We run anything from 225 to 255, depending on what we're testing. Compound range from 340TW all seasons to 100TW r-comps.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
