Old 03-05-2015, 05:52 PM   #3095
Model Citizen
Lacking brains
Drives: frz
i have an sti oil sandwich plate into t fittings in my radiator hoses.
last year at track days in new england summer weather it was helpful but a bit lacking, in a 15-20 minute session i could eventually get the temps into the mid 250s. Running heat on full out the windows did make a difference in taking advantage of the coolant oil cooler.
a bit of backing off would quickly get them into the 230-240 range, maybe a better radiator would help? maybe not. Keep in mind new england is also not exactly a hot climate,
however at autox i felt the coolant sandwich plate was perfect since it would allow for cooling down after runs in the grid while stationary and the oil getting to temp faster at the start of a session.
i was running Pennzoil platinum 5-30 last year, had no issues, may run it again this year, may not.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 03-05-2015, 07:16 PM   #3096
Andreas83
Andreas83's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by fteightysix View Post
We Just installed the Ultra rad in a C38 car this past weekend, its a tight fit, but did fit. We have not ran the lines for the oil cooler yet, But the coolant would keep the oil temps at the proper level and would not need a tstat for it.
Can you share any more info on this?
What fitting are you planning to use on the top port for the oil cooler?
I got my ultra radiator and test fitted it a couple of days ago.
This thing is massive.
Its going to be a really tight fit for the top oil hose.
Do you know what sort of threads the ports in the radiator has?
I eyeballed it to 1/2" NPT, but I am not sure.
Skunk2 did not provide any info at all, so this will be a DIY.
I am hoping that I will be able to use a non thermostatic mocal sandwich adapter I already have.
I will have to install it with the fittings pointed against the back, with 90deg fittings.
Hopefully it will be room for it.
My motor is out for a rebuild, so I wont know before I get it back together.
Andreas83 is offline   Reply With Quote
The Following User Says Thank You to Andreas83 For This Useful Post:
DAN_BRZ (03-05-2015)
Old 03-05-2015, 07:29 PM   #3097
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
this might be helpful for those of you with the ultra rad
http://www.spencerfabrication.square...relocation-kit
it tilts the rad forward some to help with clearances.
Freeman is offline   Reply With Quote
The Following User Says Thank You to Freeman For This Useful Post:
Andreas83 (03-05-2015)
Old 03-05-2015, 09:32 PM   #3098
CSG Mike
CSG Mike's Avatar
Originally Posted by post_break View Post
In 55F weather coolant stayed around 165F, too cold for me.
Yeah the oil cooler isn't perfect, but for someone like me who doesn't track my car regularly it's perfect. Keeps the oil in check for bashing on it on the street.
For the track I'd have to run a thicker weight oil and pit when temps got away.
Which is why I said the air to oil coolers are for track users.
I would not even recommend it for casual tracking, once a year.
Old 03-06-2015, 07:34 AM   #3099
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
What's the deal with the c38 blower? Some dude is offer ing a hardly used kit for super cheap. Is the c38 a bit on the fence for a stock motor? I can't understand why his kit has not sold
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 03-06-2015, 03:07 PM   #3100
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
Ive had a C38 with around 18-19psi on a stock motor for 10k now.. I dont track and i dont personally beat on it daily, ive done alot of pulls, The only issue i have really, is the Auto trans doesn't care for it. Shifting kinda does what it wants, not sure if its the tune, or the power. Sometimes it shifts right away, sometimes i can short shift and the trans shifts 1500-3k rpm later. I do have new Amsoil fluid and looking into the SSP products to get rid of that. I did run through a belt in the first 1k miles but i was running a pulley setup that they told me the belt wouldnt last. the last 9k has been on the same belt with zero issues.
As far as the Ultra Radiator is concerned, when the customer is ready, we are taking it down to hose specialty shop here in vegas and having them make up custom hoses, the guy claims he will have a fitting to fit in there without cutting.. There is not a lot of room but he said he has a fitting that will work.. when we get it done, we will for sure post up what is used
-Thomas
86SPEED is offline   Reply With Quote
Old 03-06-2015, 03:15 PM   #3101
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
So in a couple weeks I'm installing a c38 with stock fuelling on my auto transmission. So with the stock pulley what psi should I expect the blower to push? I'm going with moto East tune with a 4 bar map sensor. The only reason I ask is it seems everyone is showing different boost levels with the same set up.
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
Triumphrider is offline   Reply With Quote
Old 03-06-2015, 03:23 PM   #3102
Calum
That Guy
Drives: 2013 asphalt FRS MT
-Thomas
Do you know what the cooler consists of?
Old 03-06-2015, 03:44 PM   #3103
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
@Boofneenee
From what I gathered, the C38 blower will make less boost in the low RPM range compared to the C30 (maybe look at dyno charts). Up top, the C38 will pull much faster. C38 will also require bigger injectors and maybe a bigger fuel pump.
projek_01 is offline   Reply With Quote
The Following User Says Thank You to projek_01 For This Useful Post:
Boofneenee (03-06-2015)
Old 03-06-2015, 05:32 PM   #3104
nlopez
Originally Posted by gmsii View Post
6 steps to the CARB approval process
1. Submit paperwork to ARB of intent
2. Get response from ARB with “OK” to test
3. Follow procedure (put kit on car following install instructions) bring car to test facility
4. Test facility runs car
a. Test runs made
b. Revisions made
5. Test info sent to ARB for approval
6. ARB Executive order issued
Kraftwerks is currently at step 4b with the BRZ kit, we had to make one revision thus far and the car will be going back to the lab next week. If it passes, generally it takes 4-10 weeks for all the paperwork to go through at which point we will be issued an exemption number.
Dave, would you happen to have an update since there's a bit of skepticism from existing customers if you'll ever get approval.
nlopez is offline   Reply With Quote
Old 03-06-2015, 06:07 PM   #3105
SPCorBUST
SPCorBUST's Avatar
Might want to tag whoever Dave is.
That quote is from Nov 25 last year, which is 3 1/2 months ago, the process having been started long before that and silent since.
Regardless, some folks were told it was approved. Buuuuuuut, it wasn't...
If they get it soon though, great! Took long enough.
SPCorBUST is offline   Reply With Quote
Old 03-06-2015, 06:24 PM   #3106
nlopez
@gmsii is Dave Hsu the owner of Kraftwerks/Skunk2 hence the Vendor status
Old 03-06-2015, 06:39 PM   #3107
SPCorBUST
SPCorBUST's Avatar
Posted in June.
Bumped on February 4th.
Bumped on March 1st.
Finally decided that I'd waited for CARB long enough.
9 months goes by fast...
The Following 3 Users Say Thank You to SPCorBUST For This Useful Post:
Freeman (03-06-2015), juliog (03-08-2015), mit_peid (03-06-2015)
Old 03-06-2015, 06:42 PM   #3108
SPCorBUST
SPCorBUST's Avatar
Yep, I'm aware of the vendor status.
He's not the only one that uses that account. Jeff Giovino does too.
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
