Old 03-06-2015, 08:11 AM   #127
cjd
cjd's Avatar
Drives: 2017 BRZ
I've found no definitive answer, just that some known drivers were switching back to 245, and sidewall often comes up. In the case of the RE71 it's an inch of treadwidth over the 245 if TireRack's numbers are right.
255 is a lot of tire for sure, will have clearance though. Coilovers and 35 offset.
Thanks for the thoughts on the subject regardless. I still have a little time to ponder and wait for more data on the new tires.
C
Old 03-06-2015, 09:20 AM   #128
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Originally Posted by simpleisbest View Post
255 can rub the spring perch. Becomes a non-issue with the smaller coil over springs
Yup. Before my friend went to STX with his then stock BRZ, we borrowed another friend's 17x9 +42 PRF1 with 255 Z2s to test fit. The tire was going to rub.
G_Ride is offline   Reply With Quote
Old 03-06-2015, 10:35 AM   #129
Thorpedo
The SquadWhisperer
C
I've run 255/40 RE11A on 17x9+35 for two seasons now. No rubbing on stock suspension nor coils after a drop and -2.4 front camber. The added tire height was great for an extra few MPH but with my raised rev limit I'm going to bump back down to 245 I think to lower my CG and tire weight. As some others have noted however, the RE11A is not as wide in that size as some of its competitors.
That RE71s width is tempting though..... Pretty large for a 255.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 03-06-2015, 12:11 PM   #130
simpleisbest
Senior Citizen
Drives: Scion FR-S
Most people just do what they see other do. I suspect though, that those in STX that made a cognitive choice to move from 255 to 245 was because of how the RS3 reacts to a 9" rim. Likewise, if you were to use the Toyo, the 235 has been proven on a 9" rim. I wouldn't say that its a general rule that 245 is the "faster" size.
Most people don't like complicated, but when sizing the "fastest tire" for a particular size rim tire construction and compound really need to be taken into account. What works for a RS3 may not work for a Dunlop, for example.
simpleisbest is offline   Reply With Quote
The Following User Says Thank You to simpleisbest For This Useful Post:
tigermack (03-06-2015)
Old 03-07-2015, 06:55 PM   #131
knipple
Drives: 2013 Ultramarine Scion FR-S
I was running 255/40/17 on stock suspension with 17X9 et +35 RPF-1 and 1 degree of negative camber added. I had no issues with rubbing the spring perch.
knipple is offline   Reply With Quote
Old 03-07-2015, 07:29 PM   #132
Lithium
Lithium's Avatar
Drives: like an asshat
Had my first experience with the RE71R's and my first impressions are really really good. I'm going to do some alignment changes and suspension adjustments for next weekend as I had some slight under-steer while accelerating. I will be able to report some more in depth info when the time comes. All in all I grabbed the fastest raw time of the day ( the track was only 30 seconds long) on the RE71R's. Tires had great response/grip; the only complaint I have is the tires did require some warm up time (2 runs while temps were in the 70s) but should work perfectly during the summer. Tires even behaved really well for daily use, very comfortable.
Lithium is offline   Reply With Quote
The Following 10 Users Say Thank You to Lithium For This Useful Post:
bholliday (03-23-2015), cjd (03-07-2015), dp1 (03-14-2015), G_Ride (03-07-2015), Kostamojen (03-07-2015), racinric95 (03-07-2015), Rampage (03-07-2015), Shark_Bait88 (03-09-2015), the new guy (03-07-2015), Wepeel (03-10-2015)
Old 03-07-2015, 08:12 PM   #133
Kostamojen
Thanks for the review!!!
Old 03-08-2015, 12:13 AM   #134
simpleisbest
Senior Citizen
Drives: Scion FR-S
That due to offset. Most nationally competive STX builds I see run 17x9 +45.
While +35 probably looks cooler, but making the car wider +10mm wider each side is counter productive. If you tried to fit 255 using a +45 rim, it would make contact with the stock spring perch.
Old 03-09-2015, 04:19 PM   #135
renfield90
The Stig's German cousin
A lot of the talk coming from California this weekend is that the RE-71R is quite the ringer if temps are warm enough - apparently an STS Civic raw-timed a few of the top STU cars. The talk is big and bold enough to make me ever so slightly regret pulling the trigger on some star specs...it'll be interesting to see how the Rival S stacks up.
Old 03-09-2015, 04:37 PM   #136
Jawnathin
Drives: Toyobaru FRZ
I'm in NorCal and we had the Speedway CAM Challenge event over here. As a volunteer worker, we got to drive the course. A Nationals winning driver in a Nationals winning car was there and he was very very fast on them.
I'm not on the best of tires (300+ run RS3s) and I'm not at his level, but I was feeling pretty good compared about my times until I saw his runs. I've raw timed him in previous events but I got a thorough beating this time around.
Last Thursday I ordered RS3 V2s, they are still in route. By Sunday afternoon, I ordered a set of Bridgestones. Anyone want some unused 245/40/17 RS3 V2s?
I also got feedback from another trusted source on the East Coast. Just a local event, but he took #1 PAX over another National Champ. He hasn't done that before. I shouldn't hype them so close to the Tours (Go buy Hankooks and Dunlops!! ) but I think the RE71s are going to be the tire to have.
Jawnathin is offline   Reply With Quote
Old 03-09-2015, 05:12 PM   #137
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
just when you think you've got your tire situation figured out........
Old 03-09-2015, 05:16 PM   #138
conedodging
conedodging's Avatar
Drives: '14 BRZ
Well, given how the Toyos shook out, I'm not taking much stock in an STS civic being a good indicator of what tire would be good for our cars in the various setups.
*edit* I'm not saying it doesn't maybe have the potential to be "the one" this year, and I'm glad some of you are getting some to try out. I just feel that results from cars significantly different from our own shouldn't make me instantly regret buying RS3s.
conedodging is offline   Reply With Quote
The Following User Says Thank You to conedodging For This Useful Post:
AustinTX (03-09-2015)
Old 03-09-2015, 05:34 PM   #139
Jawnathin
At my event, it was a GS Focus ST. It was the 2014 winning car/driver. I've been fairly competitive in PAX and have raw timed him in previous events when we were all on RS3 V2s. My RS3 V2s have since been worn out (they are practice tires now) and his RE71Rs are fresh, but I got beat by over 1 second on a 55 second course.
The other reliable source was a CS RX8 outpaxxing a National Champ in a new WRX in DS on Z2SS. I was told the DS driver is looking for RE71Rs now.
Two different events.
Old 03-10-2015, 04:50 PM   #140
ViperASR
Drives: 2006 Honda s2000
Idk who you are, but I was at that event, know both of them well. I believe they have purchased the RE71R.
Only thing I saw at that event was that the tires fell off a bit with heat, his first 2 runs were his quickest. This was in FL with call it 85 degree heat on asphalt. Others have indicated different, so it will be interesting to see how that shakes out.
ViperASR is offline   Reply With Quote
Areddi's Autocross Video Thread Areddi Mid-Atlantic 130 05-17-2015 06:19 PM
Anyone DD 200 Treadwear Tires? CraftyObeseCrunchyKitty Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 01-09-2015 11:44 AM
Tire PSI for completely stock autocross? bladesamurai Tracking / Autocross / HPDE / Drifting 16 06-11-2013 10:07 AM
Autocross Tire Pressure on ZII's Areddi Tracking / Autocross / HPDE / Drifting 6 04-12-2013 08:37 PM
KW V3 autocross set-up thread -max- Tracking / Autocross / HPDE / Drifting 97 10-18-2012 08:02 PM
