Old 02-21-2015, 11:15 AM   #211
Juggles
Drives: 2013 FRS
Not under warranty any more :\
A zen master once told me "Do the opposite of everything I say", so I didn't.
Juggles is offline   Reply With Quote
Old 03-02-2015, 04:19 PM   #212
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
My case with the same CEL was bad main motor harness connection.
Had to tighten the harness with plastic clamp/band. But unfortunately that plastic clamp gets loosen after long time idle heat.
Just try to move the harness by hand and if you get some more CELs after, other than P035X (or your P035X gets disappeared), then it is definitely bad harness connection.
I may suggest that that bloody harness is the weak point of toyobaru.
But this is only my case and it may appear quite specific.
I'd change my harness sometime.
And in my case i just feel vibration at around 5K (without any CELs popping out) when the harness connection is not ideal, and the vibration disappears (and the torque increases)after i stir the harness a bit.
Ondreiko is offline   Reply With Quote
The Following User Says Thank You to Ondreiko For This Useful Post:
86ft.lb (10-13-2016)
Old 03-02-2015, 07:23 PM   #213
FT86RGV
Can anyone confirm ignition coil #2 is driver side towards firewall? @smbstyle
I bought another coil and this will be second time I replace it in 3 months.
FT86RGV is offline   Reply With Quote
Old 03-02-2015, 09:08 PM   #214
Estey
Drives: Scion FR-S, Ultramarine
I used to get P0352 all the time. Whenever I was at WOT it would throw the code. But I recently tuned my car with an OFT, and I no longer have this problem. Im not sure if it was a problem with the ecu, but the engine is running smoothly now with no issues.
I do have a 2013 model, and I have never gotten the updated ecu flash. So im guessing that this problem was derived from the stock map.
edit: This got me thinking.. People are reporting coils failing within months of replacing them, but maybe its not the coils?
Estey is offline   Reply With Quote
Old 03-03-2015, 08:35 AM   #215
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Got a P0351 this morning! I'll figure it out when I get home tonight.
JimmyMac is offline   Reply With Quote
Old 03-03-2015, 09:12 AM   #216
JimmyMac
JimmyMac's Avatar
Forgot to mention...
Full exhaust. P&L cat less header (ceramic coated), P&L overpipe, P&L catted front pipe, and newly installed Tomei 80 exhaust (getting ready for turbo install). I also just installed the silencer as well on the tip. (Result of excessive back pressure?)
OFT Crawford BPB tune. TRD intake. 39k miles.
Old 03-04-2015, 05:17 PM   #217
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Confirmed
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 03-05-2015, 04:36 AM   #218
FT86RGV
Originally Posted by smbstyle View Post
Confirmed
Thank you. Hopefully this one will last longer than 2 months.
Old 03-05-2015, 12:28 PM   #219
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
Confirmed
@smbstyle Is cylinder #2 driver side and closest to the firewall or to the front of the car?
Trying to figure out the cylinder layout in my head since I just got a P0353 cel (cylinder#3) yesterday after a track event. Is the layout the same as the older Subaru engines?
Thanks,
Aaron
Nitro22 is offline   Reply With Quote
Old 03-05-2015, 01:33 PM   #220
gramicci101
Off Topic
Thanks,
Aaron
That is the correct order. Cylinder 3 is the passenger's side rear cylinder. It seems to overheat most frequently, probably due to its proximity to the header and cat. Aftermarket headers tend not to help at all, because the heat shields have been removed with the factory header.
The Following User Says Thank You to gramicci101 For This Useful Post:
Nitro22 (03-05-2015)
Old 03-05-2015, 01:55 PM   #221
Nitro22
Nitro22's Avatar
Thanks for the reply. That's what I thought. But when I saw smbstyle post on replacing his coil pack on cylinder 2, I was unsure about the layout.
-Aaron
Old 03-05-2015, 02:21 PM   #222
FT86RGV
So wait. Is #2 driver side towards the bumper? I plan on replacing it this Monday during spring break. I really need to know. Would make sense since I had thought I replaced what was #2 but could have been #4
Old 03-05-2015, 02:51 PM   #223
gramicci101
Off Topic
-Aaron
Romin (earlier in this thread) has had to replace all of them. The left side just seems to go more frequently than the right.
Yep. #1 is passenger front, #2 is driver front, #3 is passenger rear, and #4 is driver rear. I looked it up just to be sure, and found multiple references saying that.
Old 03-05-2015, 08:48 PM   #224
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Any idea if the coil pack numbering are the same regardless of LHD/RHD?
Fizz is offline   Reply With Quote
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Shutting off your "key-in-with-door-open" beeper -- it's very easy avusblue Cosmetic Modification (Interior/Exterior/Lighting) 2 08-13-2012 05:29 PM
