Old 03-04-2015, 08:29 PM   #1
N234
N234's Avatar
Drives:
Can the multi-display be expanded?
Convincing the display to give live oil temperature readings would probably involve some sort of programming or rewiring.
The display currently can show the odometers, temperature, average or instantaneous mileage. It is also aware of your gear position, rpm, and possibly more.
I don't know why Subaru hasn't included oil temperature, but I feel they should have.
I've lurked the interweb for months and found only tablet/app solutions. Does anyone share my interest in this? Has anyone had better luck finding information?
N234 is offline   Reply With Quote
Old 03-04-2015, 08:36 PM   #2
stugray
Drives: 2013 GBS BRZ Limited
if you replace the stereo with a ca-fi type of android unit, you can run torque on it.
The Following User Says Thank You to stugray For This Useful Post:
N234 (03-05-2015)
Old 03-04-2015, 10:13 PM   #3
Chimera
Drives: FRS
In theory yes, in practice, very difficult. I think that it's possible with a canbus ardino. I have seen kickstarters for them but nothing particular for the frs.
The Following User Says Thank You to Chimera For This Useful Post:
N234 (03-05-2015)
Old 03-04-2015, 10:17 PM   #4
N234
N234's Avatar
Drives:
Arduino?
Old 03-04-2015, 10:28 PM   #5
N234
N234's Avatar
Drives:
I've looked at that as well. It's definitely ahead of mounting an OFT to the dash.
Old 03-05-2015, 05:07 PM   #6
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
Originally Posted by N234 View Post
Arduino?
Its a microcontroller and development environment that is somewhat easier to use than more traditional microcontroller rigs. A lot of DIY stuff is made that uses it.
I looked into it. Getting the oil temp is easy. Controlling that display is hard(er). It is possible though. The ecutek guys have got it showing AFRs.
[ame="https://www.youtube.com/watch?v=6hI-Q8I14xw"]EcuTek RaceRom Air Fuel Gauge for BRZ/FRS - YouTube[/ame]
I got frustrated about this and built the thing in my signature (it is open source, etc. So, in theory you could build your own). I'm also going to be doing something else for the oil temp reading that I'll post about once it's done.
robot is offline   Reply With Quote
The Following User Says Thank You to robot For This Useful Post:
N234 (03-05-2015)
Old 03-05-2015, 07:50 PM   #7
Chimera
Drives: FRS
The project that I was referring to having seen:https://www.kickstarter.com/projects...cking-platform
Old 03-05-2015, 08:14 PM   #8
N234
N234's Avatar
Drives:
I've worked with arduino in the past! I will look into that can bus triple.
Thank you everyone!
Old 03-05-2015, 08:38 PM   #9
Chimera
Drives: FRS
I think at this time it's still in its infancy. But there's potential there I think
Old 03-05-2015, 09:25 PM   #10
N234
N234's Avatar
Drives:
Subota should just release an update.
My display shows Rev 00.
Old 03-05-2015, 10:15 PM   #11
wbradley
Sarcastic SOB
wbradley's Avatar
Someone needs to know how to program with Python for Arduino if I remember correctly. So, in theory a device that can take the data from the ECU and display it via the info display on the dash. Might just be easier to replace the display with something that can be drawn from an Android app. That would be one tiny LCD or OLED panel.People in the electronics field could do it but cost wise much better to not reinvent the info display interface. That likely involves chip architecture, ASIC stuff, etc.
. I have a Proclip mounted 7" Android tablet on my dash that works just fine. Most engineers prefer to work for $ and I doubt there is much to be gained financially from all this. If Subaru decided to enhance their info display it would make a lot more sense.
The WRX has a pretty extensive multi info display.
Old 03-05-2015, 10:44 PM   #12
stugray
Programming the arduino is most similar to Java.
I built an Arduino datalogger for my vintage racecar.
It logs AFR, EGTs, CHTs, oil press, oil temp, fuel press, throttle position, Tach, and some spares.
It logs locally to a mem stick, and controls the shift light and the Dash Warning light.
It also sends the data over USB to a droid phone that I use as a data display for realtime data, and a graphing feature.
It saves the data to a logfile as well.
That system (with a CAN shield) would do exactly what you are talking about (and then some).
robot (03-06-2015)
FR-S in multi-car pile-up 355rockit Scion FR-S / Toyota 86 GT86 General Forum 8 10-18-2014 12:55 PM
Eibach Multi Pro R1 batboygotoj Brakes, Suspension, Chassis 4 03-29-2014 06:54 AM
FS: Eibach Multi-Pro R2 JackSmiley Brakes, Suspension, Chassis 43 08-30-2013 01:28 AM
Eibach Multi-Pro-R1 VS KW v3 thebear21 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 04-10-2013 02:32 PM
Multi TPMS? Justin.b Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-11-2012 07:25 AM
