#127 | |
Drives: 2022 BRZ Limited
RaceChrono App for data and merge the video and data overlay with "RaceRender 3"
#128 |
Drives: 128i
Great thread - thanks! What peak temps are you seeing with the OEM oil cooler at the track?
#129 | |
| The Following User Says Thank You to glamcem For This Useful Post: | normancw (10-25-2014) |
#130 |
Professional Smartass
Drives: White Out FRS
#131 | |
| The Following User Says Thank You to glamcem For This Useful Post: | post_break (10-29-2014) |
#132 |
Drives: 2018 Subaru BRZ
Awesome build! Sub'd
On my fourth 86... and everything in between
| The Following User Says Thank You to Scracho For This Useful Post: | glamcem (11-23-2014) |
#133 |
Drives: '13 BRZ, '06 997, Other Things(TM)
Thread owns: very informative. Really like your setup!
| The Following User Says Thank You to Ganthrithor For This Useful Post: | glamcem (11-23-2014) |
#134 |
thanks
#135 |
Drives: 08 STI|15 BRZ|95 L Coupe
I know that you obviously prefer the Centrifugal Supercharger since you went with one but how do you think a positive displacement one (such as Sprintex or Cosworth) would perform? Would it be better for the corner exits due to its virtually flat torque curve? For the sake of argument let's say it has 255 wheel compared to your 273... Do you think that the difference in peak HP numbers would really affect your track times that much... Sorry for the noobie questions, I'm just stuck between the KW and a positive displacement system. I would really like to start tracking my car in a few years and need to start saving up for one so I have some time to decide I'm just curious on your opinion of the positives and negatives to each for track driving.
#136 |
Also on another note. What is your ground clearance for the Driveway Labs v1 rear diffuser? I am thinking of getting the V2 with the type 1 fins because I don't want my car to scream race car and I would like some rear down-force without having to mount a ridiculous rear wing... Also if this adds anything to the discussion I plan on grabbing some Bilstein B16 coil-overs and keeping the ride height as close to stock as possible which I believe is a 30mm drop with the B16's.
#137 | ||
For street, positive displacement might be more fun, since it will be completely opposite of centrifugal .. my piece of advice, there are already zillions of things that might go wrong when we track our cars so why take extra risk to gain a bit more low end torque? , especially when our cars barely see 4500 or below rpm at the track if we're not in the power band that's probably due to wrong gear for that certain cornerQuote:
| The Following User Says Thank You to glamcem For This Useful Post: | wsites (03-04-2015) |
#138 | |
Okay awesome! I really like the KW kit compared to the other centrifugals because, the Vortech just doesn't appeal to me (I start my car in below freezing temperatures, and voiding the warranty for doing so is just not okay with me.) The Jackson kit is nice because it is CARB legal but it is so unbelievably ugly... The thing that really sets the KW kit apart for me though is it using the secondary belt to power the compressor. I think this is an underrated feature, and I'm not sure why they don't put more emphasis on it. Also the dyno graphs, that I have looked at on other member's threads, just for some not so scientific comparison have shown me that the torque difference between the Innovate/Sprintex kit and the KW kit is not substantial above 3k and after around 4.5k the KW just takes off... Plus there is always the benefit of an air to air inter-cooler, which is much less maintenance than the Laminova style... Thank you by the way, this is all great information that I really needed to know moving forward! I'm trying to keep my car from looking like it came out of a Fast and Furious movie, but at the same time having enough down-force to keep it from skidding off the track at high speeds as I enter a turn... also...
| The Following User Says Thank You to wsites For This Useful Post: | glamcem (03-04-2015) |
#139 | |
You can also read this-if you haven't already, Drift Office and Bob are one of the most reputable tuner/performance shop so I would definitely hear his opinions http://www.ft86club.com/forums/showthread.php?p=1624913
#140 | |
One thing I have yet to find though is any information on if the KW kit is almost through CARB testing yet or not... You most likely don't know if they are or not, because I have yet to see any info on it anywhere but any insight you may have would be much appreciated!
| Supercharger Comparison: Innovate, Jackson, Kraftwerks, Vortech *Updated March 9 2014 | CSG Mike | Forced Induction | 281 | 02-25-2021 05:14 AM |
| Pneubs HKS Supercharged BRZ Build Thread | Pneub | Member's Car Journals | 62 | 03-30-2016 10:47 AM |
| Dezoris | FR-S Build | Supercharged & More | Dezoris | Member's Car Journals | 329 | 03-21-2016 05:48 PM |
| Morpheus, Scion dream Build. Supercharged FR-S by TuneCast | scionsalesjay | Member's Car Journals | 51 | 07-07-2014 01:05 PM |
| Supercharged Rocket Bunny Widebody Conversion Build Thread | RWDRIFT | Member's Car Journals | 278 | 01-06-2014 01:12 AM |
