Old 03-03-2015, 12:51 AM   #6091
brianhj
Drives: 2017 Camaro 1SS
How important is the application of the flange sealant to the 4 posts that the laminova core sits on?
brianhj is offline   Reply With Quote
Old 03-03-2015, 08:11 AM   #6092
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Considering it's supposed to provide cushion for the core so that it won't rattle around or somehow become damaged, pretty important.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
The Following User Says Thank You to CK_Bladesmith For This Useful Post:
brianhj (03-04-2015)
Old 03-03-2015, 01:06 PM   #6093
brianhj
Also how long did it take to add the 2200 mL coolant to the intercooler? I added about 1300 mL so far with the pump running and it's at max level on the bottle. I tried squeezing the hoses
Old 03-03-2015, 05:27 PM   #6094
Kodename47
Kodename47's Avatar
Drives: UK GT86
The system takes a while to bleed. Getting some temperature in it seems to help too. You may find it better to do it over a couple of drive cycles as movement also helps.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-04-2015, 12:08 AM   #6095
brianhj
Yeah I tried letting it sit with the key in ignition on "on" position and let the pump run. Squeezing the hoses helped some. I still have almost 700 mL to add to make it 2200mL. Driving it helped too. Is it ok to continue to drive it without all the coolant in it? Gotta go to work tomorrow
Old 03-04-2015, 02:39 AM   #6096
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
hi guys, please add me to the owners list.. just installed/purchased a used kit. one question... where can I find the belt that works with a 70mm pulley? I got tuned today and it seems like I have a slight belt slip losing power on the top end... also a slight vacuum leak somewhere as my tuner had to tune very conservatively after noticing the AFR on idle.
video of dyno:
https://www.facebook.com/video.php?v...58407584604594
252hp and 215ft lbs with 91 octane.
mokinbird87 is offline   Reply With Quote
Old 03-04-2015, 02:53 AM   #6097
Kodename47
Kodename47's Avatar
Drives: UK GT86
Just keep an eye on it and top up if necessary. There's no issue, you just won't get optimal cooling. So long as the pump isn't running dry then you're good.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-04-2015, 12:25 PM   #6098
toast
Drives: 14 BSP Edelbrock BRZ
Known for burning oil AND a factory spec that says you can expect to burn half a quart per 3000 miles under normal driving I see as fine.
Sprintex says change the oil at 20k but people are finding the charger empty at 5k. That does not seem to be okay and the manufacturer has no response on the issue.
Unlike most people I'm not comparing dyno plots for the different types of FI as I shop, I'm comparing possible irritation levels. I love the AVO turbo kit but freaking hate exhaust leaks. I love the Innovate kit but there seems to be a decent number of seal problems as well as this vanishing oil.
Originally Posted by xxscaxx View Post
I guess you have never owned a Subaru motor before which are known for burning oil I understand the concern but there has been 0 issues (that I've seen at least) with this. There was one fellow who had it leaking from the pulley in the front of the charger but that's the only case I know of.
toast is offline   Reply With Quote
Old 03-04-2015, 12:28 PM   #6099
xxscaxx
Drives: 2013 SWP BRZ
I never said it was ok. I'm simply stating that it has shown to have 0 effect on any setup thus far. Its not really irritating to check the level of it more often. Its better practice anyways.
That being said, it is something that Sprintex should address. There is no excuse for having a 20k interval when it clearly will not make it to that point.
xxscaxx is offline   Reply With Quote
Old 03-04-2015, 12:29 PM   #6100
mokinbird87
BOXER FR
ok I searched around on the thread a bit.. is this the belt that I want for the 70mm pulley? Gates K061010?
Old 03-04-2015, 12:31 PM   #6101
CK_Bladesmith
Drives: Raven FR-S
When I pulled my blower off to check on everything, I drained all the oil and was still able to turn the rotors and get oil from the gear case on them. I'd wipe them off and then keep turning and more little spots of oil kept showing up. Definitely a sealing issue.
Old 03-04-2015, 05:22 PM   #6102
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Well I finally read this whole damn thread. It took a while. But to everyone who has posted anything of value, thank you. The information has been good. I am glad there where others who went first and found issues before me.
I am now a proud owner of a Sprintex 210/intercooled kit. I am buying supporting mods now and will install and tune in early April. I have an AX and track event in March that I want to run before I go FI.
Anyways, just wanted to say hello and thanks for the 278 pages of reading.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
The Following 2 Users Say Thank You to brzaapi For This Useful Post:
CK_Bladesmith (03-04-2015), stockysnail (03-04-2015)
Old 03-04-2015, 07:39 PM   #6103
mokinbird87
BOXER FR
can anyone please confirm for me Gates K061010 belt is the right size for the 70mm pulley? not gonna read 278 pages worth of stuff... I searched but could not find anything concrete. thanks.
Old 03-04-2015, 08:47 PM   #6104
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I'm currently using this exact belt. It's a pretty snug fit on the 69mm pulley. It'll be very tight on the 70mm pulley and I suggest getting another pair of hands to help hold the breaker bar (on the tensioner pulley) whilst you try and slip the belt on.
Fizz is offline   Reply With Quote
The Following 2 Users Say Thank You to Fizz For This Useful Post:
brzaapi (03-05-2015), mokinbird87 (03-05-2015)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
