#57 |
What a load of crap.
| The Following User Says Thank You to s2d4 For This Useful Post: | nunonuna (03-05-2015) |
#58 | |
You'll see that there won't much difference.
#59 | |
Drives: 14 BSP Edelbrock BRZ
Look at a dyno comparison such as this one:
http://www.ft86club.com/forums/showthread.php?t=47001 Look at plot 2. If you draw a straight line on the red trace from 3200-4700 rpm and then calculate the area between that line and the stock torque curve that is the 'torque dip'. Do the same thing with the blue line (and make sure you subtract any area where the blue line is above the straight line!) and that is the torque dip for the 1.1 map. I would say Shiv's estimate of the OFT map's torque dip being 50% smaller pretty damn close. It's ok, maths are hard. Quote:
#60 | |
Erected Member
Drives: frs
Anywho, you can switch to any tuning option you like. No one is stopping you from doing so. just don't expect to much from a stock car and you won't be disappointed. Also, it might be a good idea to check if you actually flashed the e85 rom, your graphs look like stock power pulls., just saying. ![]() Edit: its also a good idea to pump e85 in your tank if you're running the e85 tune. .. < just ruling out possibilities
#61 | |||
Drives: 2007 MX-5 Miata, 2015 VW Golf GTI
I just don't like when vendors twist data in an effort to push a product. Quote:
#62 | |
Put more kindly, OFT is a budget tuning solution. OFT's software is quite buggy and its canned tunes are just ok. EcuTek is more expensive but has more features and is better supported (has a much bigger company standing behind it). Also, OFT's datalogging is pretty poor. It formats its datalogging in a way that other programs can't read. For example Virtual Dyno. OFT doesn't support Virtual Dyno but EcuTek (and like 20 other tuning programs) do support Virtual Dyno. Apparently OFT datalogs are in a weird formatting style that Virtual Dyno does not read. Why doesn't OFT just coordinate with Virtual Dyno, release a firmware update to make its datalogging compliant? That reaks of laziness on the behalf of OFT.OFT.... budget tuning solution, budget features. |
#63 |
Drives: 2013 FRS
Ok guys, don't feed the troll
#64 |
Honestly threads with titles like these usually devolve into flamebait and trolling rather quickly.
#65 | |
Drives: Raven FR-S 6M
“The World is Flat”
[||•]=(86)=[•||] Last edited by Apoc; 03-03-2015 at 10:16 PM. |
| The Following 2 Users Say Thank You to Apoc For This Useful Post: | Robert@Openflash (03-04-2015), Shiv@Openflash (03-03-2015) |
#66 |
The Fail Boat
Drives: CWP S.B.
openflash tablet vs ecutek tune
ecutec currently offers more if u gonna endup with serious build with lots cash to blow. Other wise OFT all day.
OFT need to improve the write time thou, some ppl are going with ecutek cuz its cheaper to do dyno tune with it. |
#67 | |
Drives: 2013 FRS
#68 | |
Not everyone wants to figure out how to make OFT's CSV files compliant for Virtual Dyno. Meanwhile almost 2 dozen other pieces of tuner software are compliant. Why doesn't Shiv just get with Virtual Dyno make it compliant out of the box like almost every other tuning software out there? That reaks of laziness. |
#69 | |
“The World is Flat”
[||•]=(86)=[•||] |
#70 |
Drives: 2013 FRS
| Tune Reviews: My Experiences with OpenFlash, EcuTek, (TBD) | ck-GT86 | Software Tuning | 41 | 01-28-2016 03:20 PM |
| Local tuning shops who will tune with OpenFlash Tablet? | Silver Ignition | NY / NJ / CT / PA | 24 | 02-20-2015 07:08 AM |
| BRZ with header, overpipe and tune. OpenFlash / ECUTek before and after | transition | Engine, Exhaust, Transmission | 54 | 07-16-2014 09:50 PM |
| Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 90 | 04-14-2014 08:15 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 01:19 PM |
