CANADA Canada
Old 03-02-2015, 08:40 AM   #29
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Originally Posted by BRZZZZZZZZZZ View Post
Hory shet I had to drive my car on actual snow covered roads this morning, it is unbelievably unstable. I am thinking due to the alignment (zero toe, -3 degrees of camber) but it just darts everywhere on slipper surfaces...
It wasn't bad out in central New York on Saturday (18 degrees Fahrenheit and sunny, roads were dry) so I took the FRS from storage to my friends shop to install some parts. I had the same experience. My car has zero toe and max camber for crash bolts. You know its unstable when a 200 hp car gets sideways going straight in second gear on a dry road. Snow tires are a must even for cold temperatures.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
Tcoat (03-02-2015)
Old 03-02-2015, 09:49 AM   #30
HunterGreene
Hail Magnet
HunterGreene's Avatar
Originally Posted by Quentin View Post
I tried to get out of my flat, unplowed driveway with 7" of snow. I couldn't get out so I surrendered and parked it in the garage. It didn't help that my mother in law had been driving in and out of my side of the driveway in her RX350 and the packed snow froze. The Rav could get out with ease.
Sent from Tandy 400
um...our cars have approximately 5" of clearance, about 6" at the front lip. Which means that you're trying to snowplow if you were trying to make it out of your garage.
Btw, not sure if you have heard of this, but its called a shovel. You may want to invest in one.
It has priests in it?
Old 03-02-2015, 10:00 AM   #31
Lowered almost 1 1/2"s but with the proper tires on it I have plowed through up to 14" of untouched snow more then once with just the slightest flicker of the traction control light.
BRZZZZZZZZZZ (03-02-2015), HunterGreene (03-02-2015)
Old 03-02-2015, 10:01 AM   #32
HunterGreene
Hail Magnet
Yes, but you're crazy, and probably have snow tires, unlike the other guy.
The Following User Says Thank You to HunterGreene For This Useful Post:
Tcoat (03-02-2015)
Old 03-02-2015, 10:06 AM   #33
Yep and yep!
It is a blast though when you are driving down a road that 100s or even 1,000s of cars have already traveled and you are still plowing the snow! I just sing " I am the lowest, I am the lowest" and continue on my way (frequently while waving to the SUVs and pickups in the ditch).
Old 03-02-2015, 05:19 PM   #34
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Been fine for me. Only got stuck once when I was going a bit too fast around a corner and hit some glare ice and ended up in some deep snow that had built up on the other side but been good otherwise.
Lynxis is offline   Reply With Quote
The Following User Says Thank You to Lynxis For This Useful Post:
Tcoat (03-02-2015)
Old 03-02-2015, 06:21 PM   #35
Plowing the laneway! I don't need no stinking shovel.
Old 03-02-2015, 11:24 PM   #36
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
I have a shovel. I had a vasectomy 2 days prior to the snowfall. I, medically, wasn't allowed to shovel snow. When I was off restriction, I promptly shoveled my way out.
Quentin is offline   Reply With Quote
The Following 2 Users Say Thank You to Quentin For This Useful Post:
HunterGreene (03-03-2015), Tcoat (03-03-2015)
Old 03-03-2015, 09:55 AM   #37
HunterGreene
Hail Magnet
That right there is one procedure I am not looking forward to. However, after your story, I may consider getting it done during the warmer months to avoid snow issues
Old 03-03-2015, 10:51 AM   #38
Quentin
Most guys do it around March Madness. I'm not a basketball fan, so I didn't see the appeal of that timing. I thought about getting it done during World Cup last year. We weren't certain we were done with kids until this fall, though.
The procedure wasn't bad. They get you all hopped up on painkillers and then use local anesthesia. They do it right in the office. A week later, you don't feel any different... generally. Some people do have painful swelling and bruising. I just generally had to keep my 2.5 year old from bouncing all over me like she usually does.
Sent from Tandy 400
The Following User Says Thank You to Quentin For This Useful Post:
Old 03-03-2015, 11:09 AM   #39
Ok, this has now gone down in history as the most bizarre thread jacking!
Old 03-03-2015, 11:15 AM   #40
jvincent
jvincent's Avatar
Weird, the two forums I visit the most, this one and a golf forum, have both had vasectomy discussion come up in the last couple of days.
Back on topic, my skid plate has been getting a beating this year. But, it finally got warm enough for me to take the car through the wash to get rid of some of the 10lbs of salt salt that was caked on it.
Old 03-03-2015, 11:27 AM   #41
HunterGreene
Hail Magnet
Sent from Tandy 400
I actually heard the same thing--again, I agree that I don't have enough attention to basketball to really chose that time. I honestly have a ton of TV shows to catch up on, so I will most likely be doing that during any recovery time.
Old 03-03-2015, 11:27 AM   #42
Ya it was nice here on Saturday and it was about a 2 hour wait for a wash bay. Cars were lined up down the block near everyone I tried. Two guys even got into a fist fight at one because the dude pulled into a bay that the other guy figured should be his. I finally just said screw t and went through a touchless at 11 that night.
2014-2015 Winter Tire & Wheel Discussion Black Tire Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 153 07-02-2016 09:45 PM
Winter Tires worth it in Jersey for the remaining of this winter? Jfheisenberg Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-22-2015 10:58 AM
Aside from 2015 Acura NSX and Toyota Supra, what else in 2015? stockysnail Northwest 7 01-13-2015 02:30 AM
New 2015 Aozora, Going to need Winter Tires soon. Neokolzia Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 08-31-2014 12:04 AM
Nissan to enter 2015 24 Hours of Le Mans + 2015 FIA WEC mav1178 Other Vehicles & General Automotive Discussions 1 05-23-2014 10:47 PM
