Old 03-01-2015, 03:18 PM   #43
themajesticone
themajesticone's Avatar
Drives: '13 UM86
Isn't elevation a huge factor? as well as temperature?
(hypothetical) If I get 200 bhp at 81 ft above sea level vs. someone who is 2,000 ft above sea level would be getting like 178 bhp right off the bat.
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 03-01-2015, 03:23 PM   #44
VroomVroom86
VroomVroom86's Avatar
Drives: 2013 Firestorm FRS MT
How much bhp would you get in space?
VroomVroom86 is offline   Reply With Quote
The Following 2 Users Say Thank You to VroomVroom86 For This Useful Post:
clayrush (03-01-2015), themajesticone (03-01-2015)
Old 03-01-2015, 03:39 PM   #45
themajesticone
Drives: '13 UM86
"Your BHP loss computed from your BHP of 200 at sea level and Elevation of 264000 feet is 1,584.00 HP loss."
= no bueno by my understanding.
The Following User Says Thank You to themajesticone For This Useful Post:
VroomVroom86 (03-01-2015)
Old 03-01-2015, 04:26 PM   #46
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
BHP loss at 2000ft would only be 12 not 22 so 188 BHP
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 03-01-2015, 04:27 PM   #47
themajesticone
Drives: '13 UM86
I can't do maths
Old 03-01-2015, 04:28 PM   #48
VroomVroom86
With that being said, what would be the bhp in space?
The Following User Says Thank You to VroomVroom86 For This Useful Post:
Old 03-01-2015, 04:35 PM   #49
Apoc
Apoc's Avatar
100% loss or 200BHP if no air. Even still your wheels would just spin and ET will tell you your car is slow.
“The World is Flat”
[||•]=(86)=[•||]
The Following User Says Thank You to Apoc For This Useful Post:
Old 03-01-2015, 05:05 PM   #50
themajesticone
Drives: '13 UM86
I think we've covered more..... ground than these vendors. Case closed.
Old 03-01-2015, 05:06 PM   #51
VroomVroom86
I think we've covered more ground than these vendors. Case closed.
Old 03-02-2015, 12:47 AM   #52
s2d4
s2d4's Avatar
Originally Posted by tennisfreak View Post
??? Can't tell if this is sarcasm or serious.
Are you trying to say that a before/after dyno is bs and the numbers are bogus??
You don't look at total HP dyno numbers but the delta of before/after to see the gain/value/result of your tune.
The graph I quoted showed the shelf OFT e85 tune to give just about zero gain over stock. IE waste of money.
Take it however you want.
It basically means you have no idea what you are on about, otherwise you would understand what I was getting at.
Old 03-02-2015, 07:37 PM   #53
shif7i7down
Erected Member
Drives: frs
Originally Posted by xuimod View Post
I know your trying to sell your product and make a sales pitch and put your product in the best possible light but that's not really true. For me, the torque dip was still very much present after I applied the OFT tune.
Btw OP, don't believe everything vendors tell you. Bottom line, they are trying to sell you a product. I've seen it many times from vendors here (oh, our turbo kit is super easy to install when the reality is its not that easy for a first timer).
Here is my dyno with E85 and the EL E85 tune. Big torque dip was still there.
BTW OP, don't believe everything forum members tell you. Bottom line, without a stock baseline graph, this is pointless. :P
anywho, i've used both the Openflash tablet and ecutek. it's really up to what you and your tuner prefers.., if you want to just run free canned tunes then the openflash has alot of free tunes that comes with it. other then that they can both be used to tune your car,
I don't think it's necessarily the tuning option that will give you what you want. it's the tuner.
shif7i7down is offline   Reply With Quote
The Following 2 Users Say Thank You to shif7i7down For This Useful Post:
cameronjones239 (03-03-2015), phrosty (03-03-2015)
Old 03-03-2015, 03:55 AM   #54
xuimod
Drives: 2007 MX-5 Miata, 2015 VW Golf GTI
Come help me make my car stock and give me $100 to dyno it ok? If not, then your post is pointless.
Also, you are essentially saying my original torque dip was 40 ft lbs? That's a really stupid thing to say. Show me 1 FRS/BRZ that has that kind of torque dip stock. Almost all have about 20 ft lbs torque dip stock.
Because you are not smart enough to read into the context of my post, my point was the vendor can't make a stupid blanket statement that an Open Flash Tablet canned tune will reduce the torque dip by 50% for everyone. I was calling him out on his sales pitch bullshit.
xuimod is offline   Reply With Quote
Old 03-03-2015, 04:06 AM   #55
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
As I already explained, the reduction of the torque dip means that the area of the dip is reduced. Not just the depth as you are interpreting it. I am referring to a area under the curve. Just just a single nominal value. I think that is more relevant to what we care about anyway, no?
You seem to be getting upset because of your lack of understanding. Others in this thread have tried to explain it to you. But you have responded with hostility and aggression. Maybe relax a little?
Shiv@Openflash is offline   Reply With Quote
The Following 7 Users Say Thank You to Shiv@Openflash For This Useful Post:
Annahra (03-03-2015), brandonblt2 (03-06-2015), cameronjones239 (03-03-2015), DC2R (03-18-2015), gramicci101 (03-03-2015), nunonuna (03-05-2015), VMRamos (11-25-2015)
Old 03-03-2015, 04:33 AM   #56
Simplicity
Simplicity's Avatar
Drives: 15' MT FRS
Basically if you have money to spare, get EcuTek if you want to get the most out of your NA car. If you're poor, then settle for the OFT.
Via Note 4 using Tapatalk.
Simplicity is offline   Reply With Quote
The Following 2 Users Say Thank You to Simplicity For This Useful Post:
DC2R (03-18-2015), JoeBoxer (06-22-2015)
Tune Reviews: My Experiences with OpenFlash, EcuTek, (TBD) ck-GT86 Software Tuning 41 01-28-2016 04:20 PM
Local tuning shops who will tune with OpenFlash Tablet? Silver Ignition NY / NJ / CT / PA 24 02-20-2015 08:08 AM
BRZ with header, overpipe and tune. OpenFlash / ECUTek before and after transition Engine, Exhaust, Transmission 54 07-16-2014 10:50 PM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 09:15 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
