#813 | |
Drives: '14 WRB BRZ LTD Turbo
#814 | |
#815 | ||
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
Plus the fact that you went from always using remote start up and seeing boomerangs come on, but decided not to test using remote start up after doing the mod. Yea the DRLs confused me too at first. I had to read the manual to figure out which things were supposed to come on at what times. |
#816 | |
Drives: Wrb 2014 limited brZ
Why would I test it with the remote start? You still need a second person to make sure it works when you put it in drive... |
#817 |
| The Following 2 Users Say Thank You to PandaSPUR For This Useful Post: | Husker BRZ (02-28-2015), Porcupint (02-28-2015) |
#818 |
Drives: WRB BRZ 6AT
it's working!
I gave it another go like you suggested, it's working like it's supposed to: DRL and boomerang both on with car running and gear box in these positions: R, N, D.
I could've sworn the boomerang didn't come on when running and in N the other night, as I did the test the same way.… probably didn't plug something tight enough? have no idea…All is well right now. Thanks DD for creating this module. |
| The Following User Says Thank You to jflBRZ For This Useful Post: | Diode Dynamics (03-01-2015) |
#819 | |
Get off my case. Last edited by dtrop; 02-28-2015 at 12:07 PM. Reason: Add |
#820 |
SLO NO MO
I think DD's original advice needs to be heeded by everyone about to install this kit - before you perform the install, start your car up and see how it currently works. Understand what scenarios DRL comes on at, and what it looks like. Understand what the headlight normal operation looks like. Understand when the auto kicks in if you use that. Understand what any other 3rd party aftermarket modifications do to your lighting operation.
Now that you've got a good idea of all of that, install the kit and make sure that it performs as advertised for for when DRL functionality is on, and when normal headlight operation is on. If it's not working as you expect, unplug the harnesses and replug them making sure they're all snug. Still no good? Unplug the harnesses, the relay, and put it back to stock. Does it work in stock configuration? Yes? Time to give DD a call/email. This isn't directed to any individual in particular, but to all future kit owners who have yet to perform the install. |
| The Following 4 Users Say Thank You to Foobar For This Useful Post: | Diode Dynamics (03-01-2015), Husker BRZ (02-28-2015), PandaSPUR (02-28-2015), Porcupint (02-28-2015) |
#821 | ||||
Drives: 13 GBS BRZ
Honestly I'm still confused as to how you're saying they work. My understanding is that, prior to module install, your boomerangs only came on as parking lights when you used your remote start. But if you used the key to start it then they wouldn't? |
#822 | |
If I used my key to start (push button), I had no idea if my boomerangs came on since I would be inside my car. So having only visually seen my cars boomerangs come on while using the remote starter, I assumed they always turned on when regularly starting the car, but I was wrong. Honestly, however, from the factory there should be some sort of lighting on the front when you start you car without having to manually turn the parking lights on. |
#823 |
Drives: '13 WRB BRZ
Video:
[ame="https://www.youtube.com/watch?v=tTpvj21oOfQ"]Diode Dynamics Always On Kit on my EUDM 13' BRZ - YouTube[/ame] @Diode Dynamics: I received the kit today and installed it according to your instruction video. I was kind of worried about the kit not being working on an EUDM car, since I also experienced issues with the USDM TOMs Taillights, where some of the wires had to be switched in order for the taillights to work as intended. After installing the kit, I turned the car on and switched the lights off, which forces the DRL to light up. Now, as far as I know, the Boomerangs should also come on. They didnt. I then switched to "Auto" which turned the HIDs on, but the DRL didn't come on with them. Also after forcing the HIDs, the DRL stayed off. I switched both jumpers and tried if it works this way, but nope. Nothing enabled the kit. After this procedure I decided to make a little video to show it. I guess this Kit is just not working at all for EUDM (which makes me very sad, I SO want this to work )Any ideas? |
| The Following User Says Thank You to pr0xy For This Useful Post: | livert (02-28-2015) |
#824 |
Drives: 2013 Subaru BRZ, 1991 BMW 318is
Installed mine just now and they're working great, thanks for making this product @Diode Dynamics
| The Following User Says Thank You to nick_318is For This Useful Post: | Diode Dynamics (03-01-2015) |
#825 | |
Drives: brz
#826 |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
It shouldn't matter in this case as his DRL LED's are obviously on; theoretically with that module... if those are on, the boomerangs should be on as well.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
| [Closed] Gauging Interest thread | pansontw | Cosmetic Modification (Interior/Exterior/Lighting) | 49 | 08-27-2014 03:14 PM |
| So has anyone managed to get the BRZ Boomerang/parking lights to operate as DRLs? | gt8613 | BRZ First-Gen (2012+) — General Topics | 18 | 04-27-2014 02:09 AM |
| Gauging Interest | ISC Suspension | Announcements, Contests, Giveaways | 17 | 04-03-2014 09:44 AM |
| Jdm headlights - gauging interest | Hawk77FT | Exterior Parts (Aero, Lighting, Etc.) | 7 | 03-31-2014 09:38 AM |
| FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! | Sportsguy83 | Engine, Exhaust, Bolt-Ons | 10 | 08-30-2013 10:53 AM |
