Old 02-24-2015, 02:11 PM   #113
nexusatm
nexusatm's Avatar
Drives: GT86
Its cool! I dream about this skill!
nexusatm is offline   Reply With Quote
Old 02-24-2015, 02:45 PM   #114
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
I'm not going to lie. It has been a LOT to take in. My suggestion, assuming you have OFT or are getting it, is to read everything you can by Steve99, then read as many posts as you can, then open up ROMRAIDER, and load all of the tunes you can into them and see the differences one by one.
There are calculations and Math that I am missing still and I don't even know where to start to look for them, but I am learning little by little. My first "tune" was actually to try to improve gas mileage and 3k torque dip. I ended up lowering the power pretty significantly, but my daily driver MPG (highway and street combined) was 35.6 mpg on 91 pump gas. That was +10 mpg over my normal.
Closest I've come to that while having any amount of power was with my exhaust leak... That was 28 and I was just afraid of the ultra-loud sound waking neighbors and getting me ticketed.
You can do this. If you spend the time to learn, you can do this.
Old 02-24-2015, 03:07 PM   #115
Koa
Originally Posted by Celadrielas View Post
Koa, What are Kode's / VGI's tools?
VGI's utility.. makes it MUCH easier to do OL/CL maf scaling, load/IAT comp corrections... even mafV re-scaling
http://www.romraider.com/forum/viewt...p?f=32&t=10481
For instance, I have re-scaled my MAFV scale in addition to the g/rev call
@Kodename47 's tuning tools thread, which contains knock correction spreadsheet
http://www.ft86club.com/forums/showthread.php?t=75710
Old 02-24-2015, 03:22 PM   #116
Celadrielas
You... this... it's so beautiful...
The Following User Says Thank You to Celadrielas For This Useful Post:
Koa (02-24-2015)
Old 02-24-2015, 04:02 PM   #117
Koa
forgot to link VGI's utility dl link > http://www.romraider.com/forum/viewt...p?f=32&t=10481
as far as my own tuning, it's going well. I just have to address my tip in knock and start hammering down the load comp and IAT table revisions. After that I'm pretty much set until I bite the bullet on a turbo system (my wrx smokes this thing so far.. that has to change)
Keep us posted on your tuning endeavors brotha
The Following User Says Thank You to Koa For This Useful Post:
Celadrielas (02-24-2015)
Old 02-24-2015, 04:12 PM   #118
Celadrielas
Hey, out of curiousity, how loud is your VVT? Even though mine is in "Great health", I am hearing what sounds like valve lash from 3500-4200 rpm since the OTS tune. I assumed it was normal, and when I asked about it it was confirmed as normal. But damn is it loud
TofuJoe (09-24-2016)
Old 02-24-2015, 04:22 PM   #119
Koa
I have that at certain loads over that range, too. It's normal AFAIK
Old 02-24-2015, 04:42 PM   #120
Celadrielas
Yea, I figured that's what it was. Thanks again
The Following 2 Users Say Thank You to Celadrielas For This Useful Post:
Koa (02-24-2015), TofuJoe (08-28-2016)
Old 02-24-2015, 04:48 PM   #121
steve99
Drives: FT86
i have cutted duct, mishimoto inlet hose (w/o sound tube), apexi panel filter, full exhaust(catless top speed pro-1 EL header, non stock over pipe, catless non-resonated front pipe, invidia N1 like catback). Is the OFT st 2 EL good for this config? I meen would i take some gains from custom e-tuning?
The oft stage2 EL tune should be fine
2 things that upset off the shelf tunes are changed intakes ie complete new intake that changes maf scaling, drop in filters and intake tube generally ok.
Your fuel assuming you have 91/93 usa fuel or equlivant available.
Old 02-28-2015, 09:28 AM   #122
Tor
Tor's Avatar
Drives: Toyota GT86
Does anyone know if AUTOMATIC rev match downshift will be available for M/T with OFT at some point?
Tor is offline   Reply With Quote
Old 02-28-2015, 09:51 AM   #123
s2d4
s2d4's Avatar
Originally Posted by Tor View Post
Does anyone know if rev match downshift will be available for M/T with OFT at some point?
Yes, heel toe works.
The Following 4 Users Say Thank You to s2d4 For This Useful Post:
CatDaddysBBQ (11-11-2015), eddieflyinv (02-28-2015), Kaotic Lazagna (02-28-2015), Shiv@Openflash (03-07-2015)
Old 02-28-2015, 11:36 AM   #124
Tor
Tor's Avatar
Drives: Toyota GT86
So does revving the engine up to 4k before releasing the clutch, but still launch control is included.
Any other takers?
Old 02-28-2015, 11:48 AM   #125
Trettiosjuan
Drives: GT86
Truly? They're gimmics, better to learn it properly yourself, and the absense of gimmics is why I like this car so much. It's pure.
Well, perhaps except for the ABS, TC and VSC but they're not gimmics, they keep you alive... and the latter two can be switched off in mere seconds.
Perfect blend of old school and some modernity.
Trettiosjuan is offline   Reply With Quote
Old 02-28-2015, 12:22 PM   #126
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
I think it would be tough to program into a manual because it has no way of predetermining if you're shifting up or down when the clutch is pressed in...it also has no idea how long it will take you to select your gear and let the clutch out so I think it'll be damn near impossible to put it into an OFT (or any other, for that matter) tune for the 6MT.
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 08:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 03:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
