Old 02-27-2015, 05:03 PM   #799
dtrop
Drives: Wrb 2014 limited brZ
Originally Posted by Porcupint View Post
Your boomerang won't come on if the vehicle is in park unless your parking lights are on. That would be the position directly after auto on the BRZ stalk.
Some one seriously needs to document how DRL's work. Holy crap.
Manual cars: Turn your car ON. Leave your car in neutral, RELEASE the parking brake COMPLETELY. Check lights. On? Good. Off? Problem.
Automatic cars (you're going to need two people or a mirror): Turn your car on. Put car in Drive. Release parking break. Check lights. On? Good. Off? Problem.
If your car is parked, not on, parking brake pulled, not in drive, etc.. the DRL's won't turn on and neither will the boomerang.
You're not listening.
Prior to installing:
Automatic BRZ-I never use my hand brake. When i start my car in park, my boomerangs ARE ON. my light switch is ALWAYS on auto.
After installing: When I start my car, put it in park, my boomerangs are OFF
So....either the kit disables the boomerangs as parking lights on my automatic brz (HANDBRAKE DOWN), or there is something wrong.
dtrop is offline   Reply With Quote
Old 02-27-2015, 05:08 PM   #800
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Prior to installing... In stock-mode, it shouldn't turn on the boomerangs when your lights are in auto mode...
They go on either A) Headlights on on, or B) Parking lights are switched to on, OR C) When in auto, it is dark enough for the headlights to go on which means the boomerangs go on too.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
The Following 2 Users Say Thank You to DaJo For This Useful Post:
Annahra (02-27-2015), Porcupint (02-27-2015)
Old 02-27-2015, 05:10 PM   #801
dtrop
Originally Posted by DaJo View Post
Prior to installing... Stock doesn't turn on the boomerangs when you're in auto... They go on either A) Headlights on on, or B) Parking lights are switched to on.
Yes they do...................
Old 02-27-2015, 05:11 PM   #802
dtrop
Actually....I wonder if this has to do with me having an automatic remote starter....
let me go try
Old 02-27-2015, 05:15 PM   #803
dtrop
Mystery solved.......Having a remote starter turns the boomerangs on (prior to module install) while car is parked.
So when I used my remote (after module installation) to start my car, my DRLS turn on and my boomerangs.
Old 02-27-2015, 05:17 PM   #804
DaJo
FT86Club Vancouver
DaJo's Avatar
Yeah, likely because it's unoccupied, so it makes sense to have the parking lights set to on when remotely started for safety reasons.
2000 MR-S 5MT
2010-2012
Old 02-27-2015, 05:18 PM   #805
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
*facepalm*
The Following 3 Users Say Thank You to PandaSPUR For This Useful Post:
Annahra (02-27-2015), Husker BRZ (02-27-2015), Porcupint (02-27-2015)
Old 02-27-2015, 05:20 PM   #806
Porcupint
Drives: 13 GBS BRZ
Well then you have the extenuating circumstance. I have updated my post with that info.
Also assuming "after module" meant "aftermarket"
Porcupint is offline   Reply With Quote
Old 02-27-2015, 05:41 PM   #807
dtrop
Originally Posted by PandaSPUR View Post
*facepalm*
why facepalm? Whenever I have seen my car running while I wasn't inside of it, my boomerangs have been on. I just assumed that was the same for everyone. I didn't know the remote starter would influence the lighting.
Side note.....I ran the wiring underneath the airbox. Overall, the wiring is barely noticeable.
Old 02-27-2015, 05:44 PM   #808
dtrop
After module meant after I installed the always on module.
Old 02-27-2015, 05:56 PM   #809
Husker BRZ
Go Big Red!!
Drives: 2013 SSM BRZ Limited
I think he meant facepalm because you posted your module wasn't working properly and asked for ideas. And when you got ideas and multiple people stating OVER AND OVER that boomerangs aren't on while parked, you insisted they weren't listening or weren't right. Just my opinion, but glad you figured it out.
Husker BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to Husker BRZ For This Useful Post:
PandaSPUR (02-28-2015), Porcupint (02-27-2015)
Old 02-27-2015, 08:45 PM   #810
Diode Dynamics
Diode Dynamics's Avatar
Yeah, I think we're going to have to add a back side to the instructions!
Seems there's quite a bit of confusion. Understandable, just need to provide some clarification.
John C.
Diode Dynamics
The Following 4 Users Say Thank You to Diode Dynamics For This Useful Post:
Annahra (02-28-2015), Choco (02-27-2015), Husker BRZ (02-28-2015), Porcupint (02-27-2015)
Old 02-27-2015, 10:29 PM   #811
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Still waiting on my to ship???
Jmonty is offline   Reply With Quote
Old 02-28-2015, 12:20 AM   #812
livert
livert's Avatar
Okay, so I bought 12 sets for a group buy in Australia. Already messaged DD on facebook and waiting for response but in the meantime someone here might have an idea.
I have tested 3 sets on my car and none of them work. Situation after install for all 3 sets is exactly the same. My car is a RHD AUTO. After install all the lights work exactly as they did before install. When DRLs are on, boomerangs are off. When headlights and boomerangs are on, DRLs are off. On the 3rd setting (just above auto), the boomerangs are on and DRLs are off. I have not been able to get the boomerangs and the DRLs on at the same time. Handbrake has been lowered and lights have been tested in D, R, N, and P. So which of these is the problem?
1: I'm retarded and have missed something glaringly obvious.
2: These do not work with Australian RHD BRZs.
3: The 3 sets I tested are all part of the faulty batch (although the faulty ones seem to have the DRLs on when the headlights are on as previously reported).
Will also test a 4th set on a friend's manual BRZ here hopefully today/tomorrow.
livert is offline   Reply With Quote
[Closed] Gauging Interest thread pansontw Cosmetic Modification (Interior/Exterior/Lighting) 49 08-27-2014 03:14 PM
So has anyone managed to get the BRZ Boomerang/parking lights to operate as DRLs? gt8613 BRZ First-Gen (2012+) — General Topics 18 04-27-2014 02:09 AM
Gauging Interest ISC Suspension Announcements, Contests, Giveaways 17 04-03-2014 09:44 AM
Jdm headlights - gauging interest Hawk77FT Exterior Parts (Aero, Lighting, Etc.) 7 03-31-2014 09:38 AM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 10:53 AM
