CANADA Canada
Old 02-25-2015, 05:39 PM   #7687
AndrewE
Drives: Silver Corolla GT-S
Black FRS on Clyde at the body shop, looked to have read ended someone pretty good.
AndrewE is offline   Reply With Quote
The Following User Says Thank You to AndrewE For This Useful Post:
FRSToyota86 (02-26-2015)
Old 02-25-2015, 07:51 PM   #7688
Pbrown
Drives: 2013 Scion FRS Raven
That sucks and glad its not me.
Pbrown is offline   Reply With Quote
The Following 2 Users Say Thank You to Pbrown For This Useful Post:
FRSToyota86 (02-26-2015), KingGeo (02-25-2015)
Old 02-25-2015, 10:54 PM   #7689
roddy
roddy's Avatar
Drives: '13 Ultramarine
Originally Posted by pushrod View Post
It might take 5+ years, but I bet you will eventually have issues. It doesn't take much to destroy cats.
I think I stand alone as someone that doesn't care about the cricket noise at all. My car started doing it within 12 hours of bringing it home from the dealer.
meh...I've had the car since June 2012, and it's got somewhere around 70,000 kms on it so far. If I have to replace an O2 sensor in a couple more years, I can swallow that. If I poison the front cat in a couple of years... Awesome, I have a reason to finally nut up an put a header on it!
You're far from the only one who doesn't care about that godawful racket. I wish I could wrap my head around it, but I just can't do it. I'm a windows down kind of guy when the weather is warm/hot, and I rarely use my A/C. When I cruise through downtown or pull up beside another vehicle at an intersection, that sound echoing back at me just makes me angry.
Originally Posted by FRSToyota86 View Post
Once one of our master mechanics once mentioned to me that gas with ethanol and methanol content have the same lubrication qulaities as the gas with out... In summary as a result using a gas with ethanol content for an extended period of time may dry up the internal seals for the high pressure direct injection system and cause failures...
It seems like its a clever idea Roddy... I talked to him again he still recommends the Shell 91 and mentioned 2-stroke oil is made to mix with fuel and that the skidoo manufacturers are also moving away from adding 2-stroke oil... Bottom line as @pushrod say you might have issues with the O2 and cats... But I hope not... So let us know if there is any issues... By the way did you know what BMW is having the similar issues if not the same with their direct injection systems? They also recommend shell 91.
I'm a little confused by the first part of your post...did you mean to say they don't have the same lubricating qualities?
I'm not an automotive engineer or a mechanic (let alone a master mechanic), and I'm glad I'm not. I like working on my cars...if I worked on cars for a living, that's the last thing I would want to do in my off time.
The following is just my own experience and opinion...
I have no problem with Shell's 91. Some people say it doesn't work for them. In Ontario at least, it is "E0". It kills the crickets in my car every time. When the ambient temperatures are below 10C or so, there are no crickets regardless of fuel used. Once above that, the car runs noticeably better on the 94 with ethanol...unfortunately, that is about the same temp the crickets start to come out. They increase in volume and pitch as the temperature goes up. I don't add anything to my fuel tank below 10C-ish. Above that...only if I am using gas with ethanol in it.
Modern 2-stroke oils burn pretty clean. My snowmobile uses about 1L of injector oil per tank of gas (40L), so a 40:1 ratio give or take depending on how hard I ride it. When adding 2oz (~60ml) to the tank of my car (50L), the ratio is more like 840:1. negligible. I'm not gonna sweat it. Am I saying it is the solution? No. It is a Band-Aid at best, but in my case it works. If I develop any issues, I'll post 'em up.
I have heard of other manufacturers having issues with direct injection pumps and noises, but I don't specifically remember BMW. LOL, If I pulled up beside a $70K BMW and heard crickets that weren't coming from my car, I'd have to point and give 'em a Nelson laugh.
The Following 3 Users Say Thank You to roddy For This Useful Post:
86gt? (02-27-2015), FRSToyota86 (02-26-2015), Pbrown (02-25-2015)
Old 02-25-2015, 11:05 PM   #7690
Pbrown
Thanks Chris for the tip. I am planning on using 94 this summer with the new setup and will definitely give this a go.
The Following User Says Thank You to Pbrown For This Useful Post:
Old 02-26-2015, 09:19 AM   #7691
FRSToyota86
FRSToyota86's Avatar
oops I ment to say "dont" I will edit that out right away...
It sounds like its perfect for those with headers...
Thanks for the tip again
Vortech V3 Supercharger| 12 PSI|E85 MotoEast Flexfuel kit|Crawford AOS| Mishimoto Oil Cooler|3"Perrin Resonated CBE| 3" JDL Front/Over Pipe|OpenFlash Performance Headers|Exedy Stage 2 Ceramic Clutch |Yonaka Coilovers|17x9 O.Z. Wheels| 245/40r/17|TRD Brake Pads|Perrin Master Cylinder Brace |ChaseBay SSBrake Lines|CF Side Fins|OEM Shark Fin Athena|Yospeed Console Plaque|R/T Shift Knob|Fog Lights|Backup Camera|Navigation| |TRD Quickshifter|Motul Gear Oil|
FRSToyota86 is offline   Reply With Quote
Old 02-26-2015, 09:36 AM   #7692
Pbrown
groundhog day
-20 with wind chill of -29. The gradual warming trend has begun.
FRSToyota86 (02-26-2015), roddy (02-26-2015)
Old 02-26-2015, 10:11 AM   #7693
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Gotta keep thinking Spring!!
Here's a sneak at some work playing with Google Sketchup last night.
Slick is offline   Reply With Quote
The Following 6 Users Say Thank You to Slick For This Useful Post:
FRSToyota86 (02-26-2015), jhx741 (02-28-2015), normancw (02-26-2015), OrangeGuitar (02-26-2015), Pbrown (02-26-2015), RabidWalrus (02-26-2015)
Old 02-26-2015, 12:31 PM   #7694
Chico
Drives: '14 BRZ WRB
Don't do it, Slick. I keep telling you, you're fast enough as is.
Just noticed your times at CMP....both times are very impressive! Nicely done.
http://www.ft86club.com/forums/showt...t=38865&page=9
Chico is offline   Reply With Quote
The Following User Says Thank You to Chico For This Useful Post:
Old 02-26-2015, 12:39 PM   #7695
normancw
normancw's Avatar
Drives: 128i
I agree, save your money! Actually, take what you're planning and do it to my car!
normancw is offline   Reply With Quote
The Following User Says Thank You to normancw For This Useful Post:
Old 02-26-2015, 01:28 PM   #7696
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
Pretty cool. Just needs a bunch of "NO STEP" stickers.
pushrod is offline   Reply With Quote
Old 02-26-2015, 02:24 PM   #7697
Slick
Slick's Avatar
Lol, you guys are awesome.
Goal is 2:25 this year, someway somehow..
Gotta prep for Ontario1500.
Old 02-26-2015, 04:16 PM   #7698
Pbrown
to expand and validate what Chris has explained.
[QUOTE=roddy;2146029
Someone on the forum suggested trying a TC-W3 rated 2-stroke oil, so I did. I found that as little as 1oz makes a difference (about the same difference as 4-5oz of Lucas treatment), and ~2oz kills them completely. It does not effect performance at all. I have not had any catalytic converter or O2 sensor issues either, and using such a small amount, I don't expect I will.[/QUOTE]
Just had a talk with our forklift maintenance guy who is also a car enthusiast about this situation. Has a 26 old mustang gt that he babies more than our cars. Was also a ford mechanic for many years and really knows his stuff. Was surprised that the crickets appear moving up to 94 from 91 and said that adding the minimal amounts of two stroke oil to a tank of gas is not going to have any ill affects.
On a frightening note, perhaps the mod bug never ends as he just bought a new manifold for his car for $1500 US just because. Which in turn led him to buy the supporting parts as well. Not a good omen going forward.
FRSToyota86 (02-28-2015), roddy (02-26-2015)
Old 02-26-2015, 06:56 PM   #7699
HeadBanger
HeadBanger's Avatar
Drives: '14 Subaru BRZ
@Slick what time do you plan on closing up shop tomorrow? I have a job interview in the city and though I might swing by afterwards.
Life's too short to drive a boring car
HeadBanger is offline   Reply With Quote
Old 02-26-2015, 09:24 PM   #7700
Slick
Slick's Avatar
Hi Corey, I'm in the shop all day tomorrow, till about 5:30pm usually. Feel free to drop by! I'll probably jump out for lunch so just send me a FB message before you come over.
