Old 02-26-2015, 05:50 PM   #771
Annahra
Annahra's Avatar
Drives: 2014 WRB BRZ LTD
Originally Posted by Diode Dynamics View Post
I believe for automatic, car must be running and in Drive.
Yes. This really does require a second person to test function.
Annahra is offline   Reply With Quote
Old 02-26-2015, 05:52 PM   #772
qoncept
qoncept's Avatar
Pshhhh https://www.youtube.com/results?sear...iding+the+whip
qoncept is offline   Reply With Quote
The Following 3 Users Say Thank You to qoncept For This Useful Post:
amaciose (02-27-2015), Annahra (02-26-2015), Choco (02-27-2015)
Old 02-26-2015, 06:42 PM   #773
jflBRZ
jflBRZ's Avatar
Drives: WRB BRZ 6AT
Confirmed it's faulty (or not working 100%). Disconnected the module and put back the oem plugs and fuse relay, confirmed original DRL lights up on everytthing (including Neutal) other than Park. My BRZ's an auto...
jflBRZ is offline   Reply With Quote
Old 02-26-2015, 07:22 PM   #774
Porcupint
Drives: 13 GBS BRZ
Well got my car back and installed the module. Checked over the wiring between the two plugs and everything appeared to match up. Got it installed wires ran under the front beam. Must say that part was a bitch with big hands. Got everything in and tested and my driver side DRL doesn't come on while everything else (driver side boomerang and both passenger side boomerang and DRL come on). unplugged the driver side and put the stock connector back on and same shit minus the boomerang. So don't think this is a DD problem, but more of a "body shop forgot to plug the DRL's in" problem. So now I'm gonna figure out how to get to those and how they're wired in to check them.
I'll do a full write up once I get the other DRL fixed.
Porcupint is offline   Reply With Quote
Old 02-26-2015, 07:58 PM   #775
Blue-Sensei
Blue-Sensei's Avatar
Drives: '14 WRB BRZ LTD Turbo
[ame="https://www.youtube.com/watch?v=bOvVYZMENQI"]BRZ Always on module via DD - YouTube[/ame]
Made a vid showing how the lights are working(or rather not) on mine.
Blue-Sensei is offline   Reply With Quote
Old 02-26-2015, 08:02 PM   #776
Diode Dynamics
Diode Dynamics's Avatar
It does appear that you received a module with the wiring issue. We'll be in contact via email to get you a replacement right away.
John C.
Diode Dynamics
Old 02-26-2015, 08:03 PM   #777
Diode Dynamics
Yes, this module sends power to both DRLs at the same time, so the DRL on one side is probably not plugged in. Thanks for your understanding.
John C.
Diode Dynamics
Old 02-26-2015, 08:04 PM   #778
Blue-Sensei
Yup already talking with Phillip, made the video as a result.
Old 02-26-2015, 08:15 PM   #779
Diode Dynamics
Very peculiar. I think you said that the DRL did not light at all with the module? This module does not interrupt the factory DRL signal from going to the DRL.
If the module is bad, the boomerang won't light up as DRL, but the DRL will always light up as a DRL, as it just gets powered from the relay like normal. Power does not go through the module.
If possible, please try reinstalling and try it out one more time, now that you've determined when the DRL should be on.
The only other possibility is that the relay is bad, but that would be pretty amazing as these are new, quality relays right out of the box. Please also double check that the relay is in the correct location and plugged in fully. You should feel it "click" when you turn on DRL. If it does not, you might actually have a bad relay, but again, that would be incredibly unlikely.
This is getting pretty technical, so please call or email to continue the discussion, as we'll be able to respond much more quickly. Thank you.
John C.
Diode Dynamics
Old 02-26-2015, 09:45 PM   #780
Porcupint
Drives: 13 GBS BRZ
Yep. Knew it was something once the I tried the fog light and it didn't come on either. Pulled the fender liner and sure enough, harness wasn't plugged in. Plugged it in and all working perfectly now.
Old 02-26-2015, 11:52 PM   #781
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Managed to confirm that the pins are connected properly, 1 to 1. Since they were all color coded I didnt even need to remove the electrical tape. Same color went to same pin.
Hopefully my install goes perfectly.
The Following User Says Thank You to PandaSPUR For This Useful Post:
Porcupint (02-26-2015)
Old 02-27-2015, 08:13 AM   #782
Heero
Heero's Avatar
Drives: 2-door
Hi,
I'm wondering if you've corrected the issue in newer modules? Or if you check out shipped modules for the issue?
I am interested in ordering, but I would be bummed out if I ordered them all the way to Canada only to discover they were faulty.
Thanks
PS., how long does shipping to Canada generally take?
Heero is offline   Reply With Quote
Old 02-27-2015, 08:59 AM   #783
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Originally Posted by Heero View Post
Hi,
Thanks
Mine was one of the first shipped and has no issues.
DD said it was a very small number affected and they have since fixed the issue.
The Following 4 Users Say Thank You to Andrew025 For This Useful Post:
Choco (02-27-2015), Heero (02-28-2015), Jmonty (02-27-2015), Porcupint (02-27-2015)
Old 02-27-2015, 09:33 AM   #784
Porcupint
Drives: 13 GBS BRZ
This.
[Closed] Gauging Interest thread pansontw Cosmetic Modification (Interior/Exterior/Lighting) 49 08-27-2014 03:14 PM
So has anyone managed to get the BRZ Boomerang/parking lights to operate as DRLs? gt8613 BRZ First-Gen (2012+) — General Topics 18 04-27-2014 02:09 AM
Gauging Interest ISC Suspension Announcements, Contests, Giveaways 17 04-03-2014 09:44 AM
Jdm headlights - gauging interest Hawk77FT Exterior Parts (Aero, Lighting, Etc.) 7 03-31-2014 09:38 AM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 10:53 AM
