Old 02-26-2015, 12:09 PM   #155
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
Originally Posted by toeout View Post
Once you hear the rod knock, there is no reason to baby it, the damage is already done. You gonna get a new short block and that's it, might as well clatter to the dealer's lot.
The only thing I'm curious about, is how often was the oil level monitored. I check mine weekly, at least, and I've never let it be lower than 1mm from max level.
IMO the only obligation for the owner is to keep the engine cooled and lubricated. If that's done, it better hold together, even if driven hard ( assuming engine is brought to working temp )
Oil level and pressure have been a big argument (as well as cams and timing). Though, one gauge that can really help is oil pressure. With all the medal shavings that appear in the oil that could possibly hinder the oil pump it might be a good idea for an oil pressure gauge. But that is just one assessment that is going around.
shiro is offline   Reply With Quote
The Following User Says Thank You to shiro For This Useful Post:
Tcoat (02-26-2015)
Old 02-26-2015, 12:41 PM   #156
ajc209
Drives: GT86 Cosworth
My point exactly!
I am sure that there are many out there that hold the opposite opinion but nobody has put any firm evidence on the table that there are the 100s of incidents being claimed by some.
The internet is a wealth of information but the flip side is that it is very easy too take too little or inaccurate data and run with it!
Sorry I missed the contrary part!
I have heard of a few cars here in the UK with similar issues but on a forum of thousands of people 0.01% is still 1 in 10,000
ajc209 is offline   Reply With Quote
The Following 2 Users Say Thank You to ajc209 For This Useful Post:
marky (02-26-2015), Tcoat (02-26-2015)
Old 02-26-2015, 01:06 PM   #157
marky
marky's Avatar
Drives: 2020 BRZ tS #54
Mod or stock?
Only if everyone that owns a frs/brz/gt86 are on this then will get an idea of the % lol.. I'm sure there's out there same issues but never been heard
Old 02-26-2015, 03:46 PM   #158
apexslider
Drives: 2013 BRZ Limited
Any one with a failure doing regular oil analysis? Or any oil analysis at all?
apexslider is offline   Reply With Quote
The Following User Says Thank You to apexslider For This Useful Post:
ajc209 (03-02-2015)
Old 02-26-2015, 04:19 PM   #159
Caspeed
Caspeed's Avatar
Drives: FRS-RS1, Triumph Speed Triple, Lola
Originally Posted by themadscientist View Post
Oh, lord, that sounds terrible. So are we reasonably certain the course of events is:
1. Oil is lost, but we haven't determined for certain the reason
2. Oil pressure drops as a result
3. Rod bearing fails
If that's the case then the rods are not the problem, but merely a victim, oil pressure is not the illness, merely a symptom and the true culprit is whatever is causing the oil loss.
I know I have no plans to modify my engine beyond things like free breathing and an oil cooler, but a triple stack of aftermarket meters are part of the plan, water temp, oil temp and oil pressure. Those are the basics and I have never trusted stock gauges.
Remember that installing an oil cooler is actually modifying the oil system and might lead to a warranty denial.. Just saying...
Caspeed is offline   Reply With Quote
The Following 2 Users Say Thank You to Caspeed For This Useful Post:
marky (02-26-2015), strat61caster (02-26-2015)
Old 02-26-2015, 04:35 PM   #160
redlne
Drives: BRZ, FD3S, Holden Calibra Turbo
Bearing failed in mine. It was 3000km overdue for service. Warranty was declined due to "degradation of oil due to not following service intervals". I requested a copy of oil analysis but they never did one. I was going to buy a WRX as well but Subaru can f*ck off now.
redlne is offline   Reply With Quote
Old 02-26-2015, 04:44 PM   #161
marky
marky's Avatar
Wow that sucks.. did you fix the car?
Old 02-26-2015, 05:02 PM   #162
tyrantcf
Drives: '16 WRX, CBR1000RR
In their defense, it was overdue... and clearly you weren't keeping an eye on the oil level...
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 02-26-2015, 05:16 PM   #163
HunterGreene
Hail Magnet
HunterGreene's Avatar
Yeah, no offense redlne, but the service interval is 7500 miles/12000 km and you exceeded it by 1800 miles/3000 km...you kinda screwed yourself on this one.
This is also part of the reason that I change my oil every 5000 mi/8000 km, so that if I forget/run over, its still within the recommended service interval. Sure, it costs a little more over the lifetime of the car, but its peace of mind.
It has priests in it?
The Following 3 Users Say Thank You to HunterGreene For This Useful Post:
marky (02-27-2015), RobertPaulson (02-26-2015), tyrantcf (02-26-2015)
Old 02-26-2015, 05:23 PM   #164
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
[Assuming all regular driving and sparse hard running, for instance a jaunt through some backroads and a handful of redline shifts per week] If <2,000 miles over the service interval is enough to kill this car then I doubt any will make it to 100k miles. That is a fatal flaw if it's true, a car that sensitive to varying levels of lubrication is a ticking time bomb.
Seriously there are used oil analysis suggesting that we can run to 10k service intervals with no issue.
Yeah what the guy did wasn't great but it's no reason for a catastrophic failue.
Edit: Links to members with oil analysis, agreed that not checking levels is super bad.
http://www.ft86club.com/forums/showp...88&postcount=2
http://www.ft86club.com/forums/showp...1&postcount=18
http://www.ft86club.com/forums/showp...7&postcount=27
http://www.ft86club.com/forums/showp...9&postcount=13
http://www.ft86club.com/forums/showthread.php?t=13286
http://www.ft86club.com/forums/showthread.php?t=19363
Old 02-26-2015, 05:28 PM   #165
tyrantcf
I'm sure the oil itself is/was fine at that mileage, I was more making the point about level. Unless he says otherwise, it sounds like he ran ~9,300 miles without a top off or even so much as a dipstick check. That's asking for trouble.
The Following 2 Users Say Thank You to tyrantcf For This Useful Post:
HunterGreene (02-27-2015), strat61caster (02-26-2015)
Old 02-26-2015, 05:40 PM   #166
Tank
Mumbler
Tank's Avatar
Drives: Sensibly
I checked mine right when I heard noises. Oil was at the full mark. ~4300 miles on this oil change (I use one of the tripometers for oil and the other for measuring mileage between fillups).
Tank is offline   Reply With Quote
Old 02-26-2015, 06:06 PM   #167
redlne
Was taken for service and picked up after hours. They didn't do service and said I never booked out for that.
Oil was full still when it failed.
Old 02-26-2015, 06:07 PM   #168
redlne
And it was my wife that drove it do it didn't get trashed.
Full Blown Stage 1 Short Block FullBlown Forced Induction 116 03-22-2019 07:29 PM
Upgraded short block installed? Yruyur Issues | Warranty | Recalls / TSB 13 01-28-2014 09:13 PM
Built B18B Short Block C130NAV Miscellaneous 0 01-04-2014 12:15 PM
FA20 oem Short Block 3k miles Area51 Engine, Exhaust, Bolt-Ons 29 09-13-2013 01:01 AM
WTB: short block or long block DOTman05 Engine, Exhaust, Bolt-Ons 2 07-14-2013 06:48 AM
