Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
10-09-2012, 06:16 PM | #1 |
Drives: 2013 Subaru BRZ
When to change the oil
I've been changing the oil in my cars about every 5k miles, and I have heard people say they change it every 3k. This article says oil lasts a lot longer;
http://www.edmunds.com/car-care/stop...-your-oil.html |
10-09-2012, 07:43 PM | #2 |
I'm having mine changed for the first time tomorrow. I have 1600 miles on my FR-S. I will change every 5,000 after that. The fact that Toyota gives you a free oil change after 7500 miles doesn't mean you have to wait that long. Do what ever you feel is best.
10-09-2012, 07:51 PM | #3 |
Drives: Subaroooo
I change my oil every 3k miles. Personally I feel its cheap insurance. I have no doubt that the oil can go much longer, but it does not cost much and after I change it, I just feel better inside knowing it fresh oil
The Following User Says Thank You to SubarooMike For This Useful Post: | gmookher (10-09-2012) |
10-09-2012, 07:55 PM | #4 |
Owner's manual says every 7,500 miles
10-09-2012, 08:00 PM | #5 |
anyone else going to run synthetic?
10-09-2012, 08:06 PM | #6 |
3.141592654
Drives: 2013 Galaxy Blue BRZ
It requires synthetic.
I did my first one at 1,000 and subsequent oil changed will be done every 5k. |
10-09-2012, 08:15 PM | #7 |
Member of the year - 2016
Drives: Scion FRS
For this car, every 5k miles to be safe. Just because the oil can LAST to 7,500 miles doesn't mean you have to bring it to that mileage.
10-09-2012, 08:34 PM | #8 |
Changed mine at 1000, will change q 5000 hereafter. Have had Toyota engines run well into 300,000 maintenance-free. Frequent oil changes are the key to longevity.
10-09-2012, 11:13 PM | #9 |
Oil quality has improved over the years. Any particular reason for changing more often than factory recommends? I don't think it helps anything.
The Following User Says Thank You to Capstan For This Useful Post: | fr-steezz (02-19-2019) |
10-09-2012, 11:26 PM | #10 |
depends how hard you drive it
10-10-2012, 09:11 AM | #11 |
Don't speculate. Follow the factory recommendations or do a used oil analysis with a TBN.
http://www.blackstone-labs.com/ -Dennis |
The Following User Says Thank You to bluesubie For This Useful Post: | gmookher (10-10-2012) |
10-10-2012, 09:27 AM | #12 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
You guys doing it at 3-5k are paranoid IMHO. If the manufacturer recommends 7500, it's because it can go for longer than that. Oil change intervals are designed with neglect in mind, so manufacturer recommended is still well before the oil is in the end of it's life. I wouldn't be surprised if the actual oil lasts around 9-10k miles without any significant differences. If you were a manufacturer of the car, would you tell your customers to change it at 7500 and risk their engines messing up then having to do warranty work becuase you told them the wrong thing? Did you know some Porsche models have 20k recommended intervals? The 3k interval dates back to the 1960s and is a myth today when it comes to newer cars. It relies on the fallacy that since you've been doing it at 3k all along and nothing bad has happened, therefore you're doing it right. That's flawed logic and tests by manufacturers have shown that it can last longer in a safe, reliable manner without compromising the life of the engine.
10-10-2012, 11:15 AM | #13 |
Drives: waiting on a 2021...
Of course, the manufacturer wants your motor to last past the warranty period. After that?
10-10-2012, 11:45 AM | #14 |
Bah, I like changing my oil and I have money to burn, so what's the downside?
The Following User Says Thank You to DR 86 For This Useful Post: | siXXtoes (10-10-2012) |
Similar Threads | ||||
When should i do an oil change? | Ayaz2589 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 112 | 03-15-2013 01:25 PM |
3,000 mi oil-change | prest1ge | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 38 | 10-29-2012 07:13 PM |
First Oil Change | Jehuty77 | CANADA | 14 | 08-09-2012 11:54 PM |
Took my car in for an oil change... | joshua | BRZ First-Gen (2012+) -- General Topics | 25 | 08-04-2012 09:32 PM |
When to do your first oil change, and why... | MrBodyMassage | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 07-17-2012 07:43 PM |
