Old 02-26-2015, 07:32 AM   #1
Stumpygt86
Drives: Toyota GT86. N/A for life
Tuning options for rallying
I am currently building an 86 for gravel rallying and wanted to know what a good tuning option is for the car.
It will have the ABS and air con removed. Would EcuTek or Open Flash have the capability of running the car without having a shitfit with those items removed? Or can you go with an aftermarket ECU if you are just wanting to run the engine without all the factory accessories? (has anyone done this?)
I know Motec have the M150 for this car but that is for when you have all the factory stuff still in the car.
The car must remain N/A under the rules here in Australia.
Just looking at options
Cheers
Stumpygt86 is offline   Reply With Quote
Old 02-26-2015, 12:47 PM   #2
acro
Drives: GT-86
Ecutek should be able to do all you ask without having a shitfit lol. It seems as if they pretty much have almost complete control over what the ecu can do.
Check delicioustuning
http://www.ft86club.com/forums/member.php?u=80186
they have done a number of rally cars it seems
http://www.delicioustuning.com/portfolio
acro is offline   Reply With Quote
Old 02-26-2015, 01:12 PM   #3
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Cheers
You shouldn't have a problem with running with the ABS and air conditioner removed. But I'm sure you will have a permanent brake warning light on your dash that a well placed piece of electrical tape should take care of
This should apply to any reflashing system you decide to use.
Shiv
Shiv@Openflash is offline   Reply With Quote
Old 02-26-2015, 01:30 PM   #4
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
Cheers
We've tuned several professional rally GT86's recently using the stock ECU and EcuTek/RaceRom with great success. There are a few things you will need to do to beyond flashing a tune to run without ABS, etc. without the ECU running in limp mode.
Here are a couple of links on here about the rally cars we tuned recently:
Professional Rally GT86, Peru:
http://www.ft86club.com/forums/showthread.php?t=74777
Specific about the tune/performance:
http://www.ft86club.com/forums/showp...97&postcount=3
Rally GT86 (Rally Spec-Built by Toyota New Zealand TR-86) with stock ECU and EcuTek/RaceRom:
http://www.ft86club.com/forums/showthread.php?t=78490
Please contact us via PM or email at tuning@circuitmotorsports.net for more information.
We look forward to hearing from you!
- Bob
Circuit Motorsports is offline   Reply With Quote
Old 02-26-2015, 07:14 PM   #5
Turdinator
Señor Member
Turdinator's Avatar
@Stumpygt86 I believe @86drift does some rally type events with his 86 in Sydney. Neal Bates has also toyed with the 86 a fair bit so you could probably give his workshop in Canberra a call (unless you are at a level where he may be your competition)
Lastly do you have a build thread? I'd love to see what goes into building a proper rally 86.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
86drift (03-01-2015)
Old 03-01-2015, 08:24 PM   #6
86drift
86drift's Avatar
Drives: Toyota 86 GT
I tune mine with BRZedit and can help you out with a tune.
As for ABS and VSC solution is very simple. Pull the fuse. Computer wont have a hissyfit.
You can also pull the AB fuse if you haven't taken them all out already. Removing AC isn't a problem either.
86drift is offline   Reply With Quote
Old 03-01-2015, 08:25 PM   #7
86drift
86drift's Avatar
I haven't updated it in a long time but here's my build thread:
http://www.bmsc.com.au/forums/bmsc-m...car-build.html
Tuning options near or in Cincinnati raven1231 Great Lakes 11 09-28-2014 09:10 PM
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 01:35 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 12:53 PM
What are the DIY tuning options? 86dreams Engine, Exhaust, Transmission 25 09-16-2012 10:59 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
